Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
Not Charging! Maybe bad charging Port
Hi,
My daughters dsXL is not charging. I think the charging port in the back of the ds is bad. I need to wiggle it around and even doing the the light doesnt come on. How much to fix. TY
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I would definitely recommend calling a local shop to get their pricing, but if you're just looking for a round about figure, if it is the charging port that is the problem, the replacement cost where I work should be around $100 in most cases. Many times with the cost of those devices, it tends to be more economical to buy a new device versus having it repaired. Hopefully this answers your question.
Was dit antwoord nuttig?
Score 1
@vtownhog , Fil, This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. In case you would like to attempt the repair yourself or a handy family member/friend, find below a link to show disassembly and a link showing the charge port being replaced in the 2DS. If port is undamaged, it may just need resoldered to board. If not wanting to attempt the repair pop into a local computer repair shop and get an estimate. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button
Nintendo 2DS Motherboard Replacement
https://www.youtube.com/watch?v=igtyKdmp...
Score 1
Voeg je antwoord toe
Fil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 523
