Ga door naar hoofdinhoud
Nintendo 2DS Motherboard Replacement
Wat je nodig hebt
  1. Nintendo 2DS Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo 2DS Motherboard Replacement: stap 2, afbeelding 1 van 2 Nintendo 2DS Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Hinge the upper rear panel upwards and outwards to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo 2DS Motherboard Replacement: stap 3, afbeelding 1 van 3 Nintendo 2DS Motherboard Replacement: stap 3, afbeelding 2 van 3 Nintendo 2DS Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo 2DS Motherboard Replacement, Rear Panel: stap 4, afbeelding 1 van 1
    • Remove the ten Phillips screws attaching the rear panel.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo 2DS Motherboard Replacement: stap 5, afbeelding 1 van 1
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo 2DS Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo 2DS Motherboard Replacement, Remove Side Panels: stap 7, afbeelding 1 van 2 Nintendo 2DS Motherboard Replacement, Remove Side Panels: stap 7, afbeelding 2 van 2
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo 2DS Motherboard Replacement, Unscrew Motherboard: stap 8, afbeelding 1 van 1
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
    Vraag FixBot
    Voeg opmerking toe
  9. Nintendo 2DS Motherboard Replacement, Remove Top Panel: stap 9, afbeelding 1 van 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: stap 9, afbeelding 2 van 3 Nintendo 2DS Motherboard Replacement, Remove Top Panel: stap 9, afbeelding 3 van 3
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
    Vraag FixBot
    Voeg opmerking toe
  10. Nintendo 2DS Motherboard Replacement, Remove Motherboard: stap 10, afbeelding 1 van 2 Nintendo 2DS Motherboard Replacement, Remove Motherboard: stap 10, afbeelding 2 van 2
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
34 andere personen hebben deze handleiding voltooid.
Fina Beauchamp
3.383 Reputatie
6 handleidingen geschreven
Cal Poly, Team 70-1, Forte Winter 2015 Lid van Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Leden
36 handleidingen geschreven
13Gids Commentaar
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - Antwoord Deel
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Demon09 - Antwoord Deel
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - Antwoord Deel
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David - Antwoord Deel
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 127
Afgelopen 30 dagen: 577
Altijd: 68,300
