Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
20 Vragen Bekijk alle
Replacing Hard drive iPod Classic 60 Gb
iPod Classic 60Gb Model A1099
If I replace the hard drive in my 60Gb iPod Classic with a 240GB Toshiba MK2431GAH hard drive, do I follow the same directions as the standard hard drive replacement?
Is dit een goede vraag?
Score 1
1 Opmerking
Do you have the fat or thin drive?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
That drive should work. Here's how to do it:
iPod 4th Generation or Photo Hard Drive Replacement
Here's how to do it: https://www.youtube.com/watch?v=dYZqTvlT...
Was dit antwoord nuttig?
Score 3
Yes-as long as it's the same connection (which it is), it will work. But if you haven't bought that drive already, I recommend this: https://www.amazon.com/Samsung-850-EVO-I... + https://www.amazon.com/SMAKN-mSATA-PCI-E...
Score 2
1 Opmerking:
This drive solution is far cheaper and reliable than that HDD.
door
Yes, assuming the connector is the same on both hard drives, and that it is compatible with the iPod (some of them have a limit as to how much memory they can see).
You might also consider replacing the HDD with an SD card, I've done this myself recently and it makes a noticeable difference. This is the shop I bought the kit from:
https://www.iflash.xyz/store/
Score 1
Voeg je antwoord toe
macdale4 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 1,066
