Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
Can I swap the monitor between 2012 and 2011 model?
Hello I have a MacBook Pro (13-inch, Early 2011) with broken screen, everything else is working. My friend has a MacBook Pro (13-inch, Mid 2012) without logic board and hard disk, he can give me the screen. The question is: Can i put a macbook pro 2012 screen in 2011 macbook pro?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hey marcinjak9 ,
I can't find anything explicitly stating that they're compatible, but according to this Answers thread: "I'm trying to find the difference between 661-5868 and a 661-6594", someone was able to swap an early 2011 display on to a mid 2012 MBP. I imagine that it should work the other way as well, but don't quote me on that. The actual procedure of replacing the display is the same across both models, so it definitely can't hurt to try it!
MacBook Pro 13" Unibody Early 2011 Scherm Afbeelding
Handleiding
MacBook Pro 13" Unibody begin 2011 Vervanging van het scherm
Moeilijkheid:
Moeilijk
1 hour
MacBook Pro 13" Unibody Mid 2012 Scherm Afbeelding
Handleiding
MacBook Pro 13" Unibody mid 2012 Vervanging van het scherm
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yes i've noticed the same procedure of relpacing but i wanted a confirmation.
And swap logic board from 2011 to 2012? it's possible?
door
Voeg je antwoord toe
marcinjak9 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 189
