Ga door naar hoofdinhoud
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
My Screen show some vertical lines
in a particular area it always shows vertical green lines.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Anoop, it would help if you would post an image with you question. From your description, it does sound like a TAB error and can only be fixed with very special (and expensive, tools. If it is a tab error, the best fix would be a replacement.
Was dit antwoord nuttig?
It can either be a hardware of software problem, lets check it one by one. First try to download the updated driver from your machine`s manufacturer`s website then install it. If the problem still persist then its defiantly the hardware level problem which is caused by faulty LCD cable of r joint so you can further take it to some hardware shop.
Voeg je antwoord toe
Anoop zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 792
