Ga door naar hoofdinhoud
iPhone 8 Plus Rear-Facing Cameras Replacement
Wat je nodig hebt
  1. iPhone 8 Plus Rear-Facing Cameras Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Plus Rear-Facing Cameras Replacement, Opening Procedure: stap 2, afbeelding 1 van 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  3. iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 3, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 3, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 3, afbeelding 3 van 3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 4, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 4, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 4, afbeelding 3 van 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and for the bottom of the screen to open.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 5, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 5, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 6, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 6, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 6, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 7, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 7, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 7, afbeelding 3 van 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  8. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 8, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 8, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 8, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  9. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 9, afbeelding 1 van 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  10. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 10, afbeelding 1 van 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  11. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 11, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 11, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 11, afbeelding 3 van 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  12. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 12, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 12, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  13. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 13, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 13, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 13, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  14. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 15, afbeelding 1 van 1
    • Remove the lower display cable bracket.
  15. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 16, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 16, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  16. iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: stap 17, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement, Display Assembly: stap 17, afbeelding 2 van 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  17. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 18, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 18, afbeelding 2 van 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  18. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 19, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 19, afbeelding 2 van 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  19. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 20, afbeelding 1 van 1
    • Remove the bracket covering the front panel sensor assembly connector.
  20. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 21, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 21, afbeelding 2 van 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  21. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 22, afbeelding 1 van 1
  22. iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: stap 23, afbeelding 1 van 2 iPhone 8 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: stap 23, afbeelding 2 van 2
    • Remove the two Y000 screws securing the rear camera connector cover bracket:
    • One 1.4 mm screw
    • One 1.4 mm (nonferrous) screw
    • This screw tends to not be attracted to a magnetized screwdriver. Make sure to reinstall it in the correct place—a magnetized screw may interfere with the compass.
  23. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 24, afbeelding 1 van 1
    • Remove the bracket.
    • Remove the two screws securing the rear camera module cover plate:
    • One 1.8 mm Phillips screw
    • One 2.7 mm (nonferrous) standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
  24. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 26, afbeelding 1 van 1
    • Remove the cover plate from the rear camera module.
  25. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 27, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 27, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 27, afbeelding 3 van 3
    • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  26. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 28, afbeelding 1 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 28, afbeelding 2 van 3 iPhone 8 Plus Rear-Facing Cameras Replacement: stap 28, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up the rear-facing camera assembly from the top edge of the iPhone.
    • If you have trouble, switch to the point of your spudger and lever the camera out from its top right corner.
  27. iPhone 8 Plus Rear-Facing Cameras Replacement: stap 29, afbeelding 1 van 1
    • Remove the rear-facing camera assembly.
Conclusie
41 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
405.391 Reputatie
258 handleidingen geschreven
iFixit Lid van iFixit
Community
140 Leden
16.877 handleidingen geschreven
5 opmerkingen
Worked Amazing! I feel so accomplished doing this myself! Thanks for the Step By Step guide! I can’t wait to fix something else now!
Ryan Carnahan - Antwoord
I completed this repair on this iPhone 8 Plus after I damaged the cameras myself. I managed to succeed in chipping off all of the back glass panel of the phone successfully. Removing this shattered panel was the hardest iPhone repair job I have ever done. At the very end, I attempted to wiggle off the metal housing over the cameras that was originally part of the back glass. After removing this housing, I discovered that I had damaged both cameras. In retrospect I should have removed the cameras from the inside of the phone before prying off this housing.
The back glass removal is the most impossible task for this phone and should be attempted only by crazy people with an appetite for pain. I will document with a “repair story.” —CW
cpwittenberg - Antwoord
Any idea on what the cable running beside the camera to the right is for? Mine is broken and can’t seem to figure out what it is for.
Heather Clinton - Antwoord
I'm also wondering what that cable running beside the camera to the casing is used for. I can't find the correct screw to fix the cable to the casing as I have purchased a replacement cable and want to install it correctly. What screw dimensions and type of screw fits that cable to the casing?
ahjohl -
Does anyone know if you can 'extend' the camera connector cables? I'm trying to make a bespoke CCTV system from old iPhone I have lying around using manythings...
Adam Sheldrake - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 138
Afgelopen 30 dagen: 500
Altijd: 37,797
