Inleiding
Use this guide to remove and replace the dual rear cameras in the iPhone 8 Plus. The rear camera assembly consists of two individual modules: one wide-angle camera and one telephoto camera.
Note: This guide instructs you to completely detach the display cables and remove the display assembly in order to better access the rear cameras—however, it's possible to remove and replace the rear cameras with the display cables still connected. Advanced readers may skip disconnecting the display in order to save time, as long as the display is properly supported and the display cables are not damaged.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Gereedschap gebruikt in deze stap:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
One 1.4 mm screw
One 2.7 mm screw
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
Remove the two Y000 screws securing the rear camera connector cover bracket:
One 1.4 mm screw
One 1.4 mm (nonferrous) screw
46 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Worked Amazing! I feel so accomplished doing this myself! Thanks for the Step By Step guide! I can’t wait to fix something else now!
I completed this repair on this iPhone 8 Plus after I damaged the cameras myself. I managed to succeed in chipping off all of the back glass panel of the phone successfully. Removing this shattered panel was the hardest iPhone repair job I have ever done. At the very end, I attempted to wiggle off the metal housing over the cameras that was originally part of the back glass. After removing this housing, I discovered that I had damaged both cameras. In retrospect I should have removed the cameras from the inside of the phone before prying off this housing.
The back glass removal is the most impossible task for this phone and should be attempted only by crazy people with an appetite for pain. I will document with a “repair story.” —CW
Any idea on what the cable running beside the camera to the right is for? Mine is broken and can’t seem to figure out what it is for.
I'm also wondering what that cable running beside the camera to the casing is used for. I can't find the correct screw to fix the cable to the casing as I have purchased a replacement cable and want to install it correctly. What screw dimensions and type of screw fits that cable to the casing?
ahjohl -
Does anyone know if you can 'extend' the camera connector cables? I'm trying to make a bespoke CCTV system from old iPhone I have lying around using manythings...
