Ga door naar hoofdinhoud
iPhone 8 Front Camera and Sensor Cable Replacement
Wat je nodig hebt
  1. iPhone 8 Front Camera and Sensor Cable Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Front Camera and Sensor Cable Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 8 Front Camera and Sensor Cable Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Front Camera and Sensor Cable Replacement: stap 5, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 5, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 Front Camera and Sensor Cable Replacement: stap 6, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 6, afbeelding 2 van 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Front Camera and Sensor Cable Replacement, Heat the display: stap 7, afbeelding 1 van 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone 8 Front Camera and Sensor Cable Replacement, Separate the display: stap 8, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement, Separate the display: stap 8, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone 8 Front Camera and Sensor Cable Replacement: stap 9, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 9, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 8 Front Camera and Sensor Cable Replacement: stap 10, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 10, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 10, afbeelding 3 van 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  11. iPhone 8 Front Camera and Sensor Cable Replacement, Screen information: stap 11, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone 8 Front Camera and Sensor Cable Replacement: stap 12, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 12, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 12, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 8 Front Camera and Sensor Cable Replacement: stap 13, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 13, afbeelding 2 van 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  14. iPhone 8 Front Camera and Sensor Cable Replacement: stap 14, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 14, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 14, afbeelding 3 van 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  15. iPhone 8 Front Camera and Sensor Cable Replacement: stap 15, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 15, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  16. iPhone 8 Front Camera and Sensor Cable Replacement: stap 16, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 16, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 16, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
  17. iPhone 8 Front Camera and Sensor Cable Replacement: stap 18, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 18, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone 8 Front Camera and Sensor Cable Replacement, Disconnect the display and digitizer: stap 19, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement, Disconnect the display and digitizer: stap 19, afbeelding 2 van 2
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  19. iPhone 8 Front Camera and Sensor Cable Replacement: stap 20, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 20, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the second lower display cable.
  20. iPhone 8 Front Camera and Sensor Cable Replacement: stap 21, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 21, afbeelding 2 van 2
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
  21. iPhone 8 Front Camera and Sensor Cable Replacement: stap 22, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
  22. iPhone 8 Front Camera and Sensor Cable Replacement, Remove the display assembly: stap 23, afbeelding 1 van 1
  23. iPhone 8 Front Camera and Sensor Cable Replacement, Remove the earpiece bracket: stap 24, afbeelding 1 van 1
    • Remove the three Phillips screws securing the top earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.8 mm screw
  24. iPhone 8 Front Camera and Sensor Cable Replacement: stap 25, afbeelding 1 van 1
    • Remove the earpiece speaker bracket.
  25. iPhone 8 Front Camera and Sensor Cable Replacement, Move the front-facing camera: stap 26, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement, Move the front-facing camera: stap 26, afbeelding 2 van 2
    • Lift the front facing camera up out of its socket and swing it out of the way.
  26. iPhone 8 Front Camera and Sensor Cable Replacement, Remove the earpiece speaker: stap 27, afbeelding 1 van 1
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.8 mm screw
    • One 2.3 mm screw
  27. iPhone 8 Front Camera and Sensor Cable Replacement: stap 28, afbeelding 1 van 1
    • Remove the earpiece speaker.
  28. iPhone 8 Front Camera and Sensor Cable Replacement, Remove the front camera and sensor cable: stap 29, afbeelding 1 van 1
    • Heat an iOpener and apply it to the upper edge of the display to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
  29. iPhone 8 Front Camera and Sensor Cable Replacement: stap 30, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 30, afbeelding 2 van 2
    • Use the point of a spudger to gently pry the proximity sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
  30. iPhone 8 Front Camera and Sensor Cable Replacement: stap 31, afbeelding 1 van 2 iPhone 8 Front Camera and Sensor Cable Replacement: stap 31, afbeelding 2 van 2
    • Slide the tip of a spudger underneath the ambient light sensor flex cable, and lift the sensor out of its housing.
  31. iPhone 8 Front Camera and Sensor Cable Replacement: stap 32, afbeelding 1 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 32, afbeelding 2 van 3 iPhone 8 Front Camera and Sensor Cable Replacement: stap 32, afbeelding 3 van 3
    • Slide an opening pick underneath front camera cable assembly, separating the adhesive holding the camera and sensor cable.
  32. iPhone 8 Front Camera and Sensor Cable Replacement: stap 33, afbeelding 1 van 1
    • Remove the front camera and sensor cable.
Conclusie
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help.
43 andere personen hebben deze handleiding voltooid.
Arthur Shi
221.537 Reputatie
441 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
17.637 handleidingen geschreven
4 opmerkingen
true tone will stop working with a non-native front camera!
Timofey Mikhailenko - Antwoord
How can fix it?? Icopy??
Kyle -
La guida è perfetta così come il ricambio. Il mio iPhone aveva il sensore di prossimità guasto. In 30’ è tornato come nuovo! Grazie!
Nicola Sforza - Antwoord
true tone now doesn't work
Adam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 27
Afgelopen 7 dagen: 164
Afgelopen 30 dagen: 1,032
Altijd: 64,445
