Ga door naar hoofdinhoud
iPhone 8 Screen Replacement
Wat je nodig hebt
Video overzicht
    1. iPhone 8 Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 8 Screen Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 8 Screen Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 8 Screen Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 8 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 1 van 3 iPhone 8 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 2 van 3 iPhone 8 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 8 Screen Replacement: stap 4, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 4, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 4, afbeelding 3 van 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 8 Screen Replacement: stap 5, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 5, afbeelding 2 van 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 8 Screen Replacement, Heat the display: stap 6, afbeelding 1 van 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 8 Screen Replacement, Separate the display: stap 7, afbeelding 1 van 2 iPhone 8 Screen Replacement, Separate the display: stap 7, afbeelding 2 van 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 8 Screen Replacement: stap 8, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 8, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 8, afbeelding 3 van 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 8 Screen Replacement: stap 9, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 9, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 9, afbeelding 3 van 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 8 Screen Replacement, Screen information: stap 10, afbeelding 1 van 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 8 Screen Replacement: stap 11, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 11, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 11, afbeelding 3 van 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 8 Screen Replacement: stap 12, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 12, afbeelding 2 van 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 8 Screen Replacement: stap 13, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 13, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 13, afbeelding 3 van 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 8 Screen Replacement: stap 14, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 14, afbeelding 2 van 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone 8 Screen Replacement: stap 15, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 15, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 15, afbeelding 3 van 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 8 Screen Replacement, Disconnect the battery: stap 16, afbeelding 1 van 2 iPhone 8 Screen Replacement, Disconnect the battery: stap 16, afbeelding 2 van 2
      Magnetic Project Mat
      $19.95
      • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
      • Two 1.3 mm screws
      • Two 2.8 mm screws
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      • Remove the bracket.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 8 Screen Replacement: stap 17, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 17, afbeelding 2 van 2
      • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
      • Don't pry against the logic board, or you may damage the charging circuitry.
      • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 8 Screen Replacement, Disconnect the display and digitizer: stap 18, afbeelding 1 van 2 iPhone 8 Screen Replacement, Disconnect the display and digitizer: stap 18, afbeelding 2 van 2
      • Use the point of a spudger to pry the lower display connector out of its socket.
      • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 8 Screen Replacement: stap 19, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 19, afbeelding 2 van 2
      • Use the point of a spudger to disconnect the second lower display cable.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 8 Screen Replacement: stap 20, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 20, afbeelding 2 van 2
      • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 8 Screen Replacement: stap 21, afbeelding 1 van 2 iPhone 8 Screen Replacement: stap 21, afbeelding 2 van 2
      • Use the point of a spudger to disconnect the front panel sensor assembly connector.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 8 Screen Replacement, Remove the display assembly: stap 22, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 8 Screen Replacement, Remove the home/Touch ID sensor bracket: stap 23, afbeelding 1 van 2 iPhone 8 Screen Replacement, Remove the home/Touch ID sensor bracket: stap 23, afbeelding 2 van 2
      • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
      • One 1.2 mm screw
      • Remove this screw first. Excess pressure may bend the home button bracket if you remove the 1.3mm screws first.
      • Three 1.3 mm screws
      • During reassembly, be careful not to overtighten these screws, or your home button may not work.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: stap 24, afbeelding 1 van 3 iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: stap 24, afbeelding 2 van 3 iPhone 8 Screen Replacement, Disconnect the Touch ID sensor: stap 24, afbeelding 3 van 3
      • Use an opening tool to pry under the left edge of the home button cable connector to disconnect it from its socket.
      • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 8 Screen Replacement, Remove the Touch ID sensor: stap 25, afbeelding 1 van 1
      • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
      • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
      • Don't overheat the display. It should be slightly too hot to touch comfortably.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 8 Screen Replacement: stap 26, afbeelding 1 van 3 iPhone 8 Screen Replacement: stap 26, afbeelding 2 van 3 iPhone 8 Screen Replacement: stap 26, afbeelding 3 van 3
      • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 8 Screen Replacement: stap 27, afbeelding 1 van 1
      • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
      • To reinstall, first feed the cable through the hole in the front of the display as shown.
      • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone 8 Answers community for troubleshooting help. Or if you’re in the market for a new device, consider getting a refurbished iPhone 8 from our friends at Backmarket!
430 andere personen hebben deze handleiding voltooid.
Adam O'Camb
224.788 Reputatie
416 handleidingen geschreven
39Gids Commentaar
And do you just wing it for the front camera, proximity sensor etc ?
kyle - Antwoord Deel
This guide assumes you’re replacing the entire display assembly, with those parts included. If you bought a bare display then yes, you’ll have to transfer those additional components over, and that’s beyond the scope of this guide—although as mentioned in the introduction, we’re working on adding guides for those additional components as well.
Jeff Suovanen - Antwoord Deel
wait a second… Are you saying that when we change the screen it is also necessary to change the front camera?
Caio Antonius - Antwoord Deel
@eitantonius A lot of new screens come with a replacement front camera already installed. They cost a bit more, but make the job easier. You can save a few bucks if you buy a stripped-down display, but you’ll need to go through some additional steps to transfer the original front camera (and a few other components) from your broken screen to the new one.
I cracked the camera glass (housing) on the back of the phone. Is it possible to replace without replacing the entire back of the phone/case?
Chris - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 48
Afgelopen 7 dagen: 378
Afgelopen 30 dagen: 1,528
Altijd: 654,139
