Ga door naar hoofdinhoud
iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer
Wat je nodig hebt
  1. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Pentalobe schroeven: stap 1, afbeelding 1 van 1
    • Ontlaad, voordat je begint de telefoon uit elkaar te halen, je batterij tot onder de 25%. Een geladen lithium-ion batterij kan in brand vliegen en/of exploderen als deze per ongeluk wordt doorboord.
    • Schakel je iPhone uit voordat je begint deze uit elkaar te halen.
    • Verwijder de twee 3.4 mm lange Pentalobe schroeven aan beide kanten van de Lightning-poort.
    Make sure you use the correct screw driver tip to remove these screws, which for the iPhone 6s Plus is the P2, otherwise you may strip the tip of the screw making it 10 times harder to remove. If once the screw is lose, it will not come off, use a magnet to remove it.
    Miguel Perez - Antwoord
    If I do it by myself, will it damage the water resistant strip?
    I know iphone 7 have it ,but I am not sure 6s plus have it.
    Ganqian Zhu - Antwoord
    iPhone 6s has an adhesive gasket under the display, similar to the iPhone 7—however, it doesn’t add much in the way of waterproofing since the 6s has non-sealed openings in other parts of the phone. Water resistance on the 6s is primarily internal (seals around the logic board connectors, etc.). It may still be worthwhile to replace the adhesive on the 6s in order to help keep the display firmly seated so it doesn’t move/wobble at all under pressure, but the phone will continue to work fine whether you replace the adhesive or not.
    Jeff Suovanen -
    Salve nella procedura iniziale di smontaggio display con la ventosa non è menzionato il fatto di scaldare i lati del display per “ammorbidire” la striscia che incolla il display alla scocca.
    Non è necessaria la cosa o è consigliabile ?
    grazie
    Hello, in the initial disassembling procedure with the suction cup, it is not mentioned how to heat the sides of the display to "soften" the strip that glues the display to the body.
    Is not the thing necessary or is it advisable?
    thank you
    Daniele - Antwoord
    You’ve probably received your answer by now but for future enquirers, it does help the process of taking the screen off if heat is applied to the screen. If you have a hair Dryer use that on a low setting to heat the edges of the screen until it’s almost too hot to touch then slip very thin metal spudger around the edge to cut the adhesive. The carefully lift the screen with the help of the spudger and continue with your repair
    Cheers Wayne
    Wayne Lyell -
    How do I know that the Battery has ZERO Charging Cycles on it when it arrives ? Is there a (downside) to Higher Capacity batteries ? It is INCREDIBLY DIFFICULT to maintain a “Zero Chinese Products Lifestyle”, so how do I know that I’m not getting a deficient Chinese battery, potentially a refurb. battery ?
    integritybuilders - Antwoord
    When your repair is complete, you can use coconutBattery to check your new battery stats and cycle count. (A properly tested battery may already have a charge cycle or two on it.) Avoid higher capacity batteries on iPhones—they’re generally either gimmicks, unsafe, or both. As far as the quality of the part, that comes down to how much you trust your supplier and whether they guarantee the product.
    Jeff Suovanen -
    So I need to empty the battery to zero percent?
    johnpatrickanat - Antwoord
    Below 25%, exactly as stated in the instructions. There’s no benefit to draining it further than that, and in fact you’ll slightly shorten the service life of the battery by draining it all the way to zero. Follow the instructions exactly as written—if you go off-script, you’re a lot more likely to break something.
    Jeff Suovanen -
    So my screen shattered completely and the screen first had colored lines on tge while right side then it went out completely. If i get an lcd and digitizer replacement I'd that oing to fix it
    shellietheleo - Antwoord
    I would initially recommend a well-lit, comfortable area and placing the screws on a white piece of paper with the screw sizes written down (apparently there are magnetic mats, also). Also, I found placing the phone on a paper towel is good so that if a screw is dropped, it will lessen the likelihood of bouncing away.
    Lou Fazio - Antwoord
    I recommend that, before you even lift a screwdriver or plug in the hair dryer, get a piece of paper and a pencil. As you unscrew and remove the parts, write the size and/or number for that step and put them by their label. I also used a microscope to identify the screw heads (I'm 75 and my vision is not what it used to be). Laying them out in order, I just went backwards when putting them all back in. I used an anti-static cleaning cloth instead of paper, but I should think they both will work.
    N.B.: my kit had a nice pretty blue plastic sheet with a black outline on it. It was only when I put the whole phone back together and was packing up the supplies and tools that I realized it was a replacement gummi seal. A LABEL WOULD BE VERY USEFUL HERE!
    I am a retired engineer, and aside from the size of the bits and bobs, it was a piece of cake! Thanks...you saved me $75!
    P. Roberts - Antwoord
  2. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Het tapen van het scherm: stap 2, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Het tapen van het scherm: stap 2, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Het tapen van het scherm: stap 2, afbeelding 3 van 3
    • Als het glas van je scherm gebroken is, kun je het verder breken van het glas en lichamelijke schade tijdens de reparatie voorkomen door het glas te beplakken met tape.
    • Leg overlappende stukken doorzichtige tape over het scherm van de iPhone totdat het volledig is beplakt.
    • Dit zal ervoor zorgen dat de glasscherven bij elkaar blijven en dat er een structuur wordt geboden bij het eruit duwen en tillen van het scherm.
    • Draag tijdens de reparatie een veiligheidsbril om je ogen te beschermen tegen mogelijk vrijkomende glasscherven.
    • Als het gebroken scherm het onmogelijk maakt om een zuignap vast te laten zuigen op het scherm, kun je proberen een sterk stuk tape (zoals ducttape) dubbel te vouwen in een handvat, dit op het scherm te plakken en zo het scherm omhoog te tillen.
    Tape doesn’t hold. suction cup doesn’t work. Tape folded over doesn’t work as a handle. I’ve used 3m’ s Gorilla duct tape. The glass is so shattered I cant get a point started to remove the glass. Phone has been in an otter box for years. dropped it and shattered glass while replacing case. Now what?
    Martin Speedy - Antwoord
    When all else fails, you can superglue your suction cup (or tape) to the display, wait for it to cure, and pull.
    Jeff Suovanen -
    I had issues getting the suction cup to stick on my cracked screen, so I tried using scotch tape (only tape I had around), but it didn’t work. This best thing I did was to forcefully pry the screen off (I wasn’t worried about damages because it’s already cracked) with the spudger. I think its best to find something stickier (like Duct Tape) and used that to lift up the screen.
    Definitely surprised how sticky the adhesive was.
    Jeffrey Robinos - Antwoord
    When using packing tape: the suction won’t hold well with the overlapping pieces, so add a square of tape where you want to put the suction cup, so it will provide an unbroken surface for the seal.
    Christa - Antwoord
    It’s amazing how a heat gun or hair dryer makes life easier to soften up the adhesive. Then use a thin iSesame opening tool to get in under the screen (start @ 90 degrees/vertical either side of the home button & slowly go horizontal) the need to use suction cups. Run the opening tool along the front and down both sides to cut the adhesive before trying to lift the screen.
    Cheers Wayne
    Wayne Lyell - Antwoord
    I didn’t have a hair dryer so I (gingerly) used an iron over some wet coffee filters (I mean , it is waterproof) . Then, quickly dried i off with paper towels, used gorilla tape and my fixit metal splunger . worked like a charm .
    MajorCouillon - Antwoord
    What about baby cracks? skip to step 3 or not…
    Andruw Holland - Antwoord
    As others have mentioned, suction cup and tape doesn’t work. I used the blade of a box cutter (watch fingers) and inserted just below and right of home button. Then moved spudger along the crack to tear adhesive/seal. Easy peasy.
    Stephen Smith - Antwoord
  3. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Openingsprocedure: stap 3, afbeelding 1 van 1
    • Het is een optie om de onderkant van de iPhone gedurende een minuut te verwarmen met het gebruik van een iOpener of een föhn.
    • Warmte helpt de lijm die het scherm bevestigt te verzachten, waardoor het openen van de telefoon makkelijker zal zijn.
    This is important. I’ve serviced a lot of iphones/ipads for my family as a hobby in the past.
    The adhesive was so tight, I cracked the screen trying to pull it/pry it off.
    I highly suggest heating at least the bottom edge enough to soften the adhesive
    garbage911garbage - Antwoord
    I didn’t have an iOpener, nor a heat gun; however I do have a small personal size hand pillow filled with feed corn. Two minutes in the nuke machine got it plenty warm, and smelled like fresh popcorn too.
    bradiac - Antwoord
    I would suggest that you are not shy with the hairdryer. A high heat on the bottom of the phone for at least a minute, if not more, if required.
    Mark Taberham - Antwoord
  4. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 4, afbeelding 1 van 1
    • Het openen van het scherm van de 6s Plus zal ervoor zorgen dat er een strip aan lijm rondom de rand van de telefoon los zal komen. Zorg dat je, als je de lijm wilt vervangen, vervangende lijm klaar hebt liggen voordat je verdergaat. Het is mogelijk om de reparatie te voltooien zonder de lijm te vervangen en je zult hierbij geen functies inleveren.
    • Druk een zuignap op de linker onderhoek van de schermmodule.
    • Als je scherm gebarsten is, kun je het beplakken met een laag doorzichtige tape zodat de zuignap zich wél vast kan zuigen. Als alternatief kun je de tape ook gebruiken in plaats van de zuignap. Als het alsnog niet lukt, kun je de zuignap aan het scherm vastlijmen met behulp van secondelijm.
    take out screws first!!
    Yoav Karmon - Antwoord
    Make sure you use the right screw driver tip for i phone 6s Plus, which is the P-2. If the screw will not come off once is lose, try using a magnet.
    My cracked screen prevented the suction cup from sealing. SOLUTION: With a piece of clear packing tape across the screen, the suction cup will seal and pull.
    Jim Cowles - Antwoord
    I broke my iphone screen in the first step!
    Pierre Bertram - Antwoord
    This screen removal step got more wrestley than I anticipated. The adhesive is quite strong. I used a flat-ended razor tool that I have to begin the prying - I don’t know how I would have got it started without this.
    Ok - just got my battery replacement kit and even got the opening kit for added insurance just in case. Settled down to startwork after carefully cleaning my (immaculate) screen - no scratches or anything, with rubbing alcohol, removing screws and warming with a hair dryer, only to find the suction cup provided in the kit is worse than useless! It won’t stick to the screen well at all. When it does - it pops off at the lightest pull :-( Now what do I do to get this started?!
    CoffeeCup - Antwoord
  5. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 5, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 5, afbeelding 2 van 2
    • Trek de zuignap omhoog met een stevige, constante kracht om zo een kleine opening tussen het voorste paneel en de achterste behuizing te creëren.
    • Je loopt het risico de schermmodule te beschadigen als je te hard trekt. Oefen net genoeg druk uit om een kleine opening tussen de schermmodule en de achterste behuizing te creëren.
    I had a shattered front glass panel so I could not get the suction cup to seal properly. I tried a couple of different ways to get good suction but to no avail. I eventually used a Stanley knife to pry up the corner so I could get the spudger into the opening.
    John Architzel - Antwoord
    A really high quality packing tape over the entire screen will usually be enough to use the suction cup on a shattered screen.
    djwooten -
    I used a suction cup on each side to provide counter traction. I braced the iphone between my knees and pulled apart while my helper inserted the spudger
    jkanne - Antwoord
    This was by FAR the most difficult part of this whole thing. I confess the spudger was not cutting it so I used a butter knife to get into the small opening first, then used the spudger to go around the screen.
    Julie Sanchez - Antwoord
    Hey everyone, if you never have done this part before be aware there is an extremely strong adhesive around the lip of the screen and once again is extremely strong. I had to get a friend to insert the pry/pick into the small gap while I used one hand to brace the phone down and the other to pull the suction cup without it digging into my hand. Go slow, it took me 5 tries because I didn’t realize how strong the adhesive was.
    bartmistrot - Antwoord
    I also had a badly cracked lower screen - that glass was actually threatening to pull off the phone in chunks during this step, even with packing tape. Resorted to @j2arch’s tip and inserted a utility knife vertically into the seam between the display and phone body. Was able to lever the glass enough to get the spudger in there.
    Jason Augustyn - Antwoord
    I have replaced sevrel screens for my sister in law and my niece. The packing tape has worked every time and that’s with it Shattered and pieces already falling out. You have to make sure the packing tape goes to the edge of the screen but doesn’t touch the frame. I have the plier like screen remover and use that it is much easier to remove the screen by your self with that tool. I also have the little finger suction cup that comes with the kit here. I bought the plier suction cup tool When I had to replace the screen that had the pieces of the screen missing and I don’t regret spending the extra money for that it has made a world of difference. I do this as a hobby it’s not a job for me. The electric divide repair kit from Lowe’s is also a very good kit to help. If you’re only going to do it once the kit that comes with the package is a great deal from ifixit. Well worth the money to spend the little extra to get the kit if you all ready don’t have the tools.
    Brent - Antwoord
    If you try to use the spunger near the home button and try to pry it can crack your screen. This happened to me.
    Jeffrey - Antwoord
    Same thing happened to me. This should be a big warning in these steps. If you have a small to moderate crack in you screen, but you weren’t planning on replacing the screen at the same time as another repair inside, there’s a risk of damaging the screen further and making it inoperable.
    DW7ACCT -
    I found it easiest to use two suction cups. One on the front as directed, and a second one on the back. Give the spudger to your assistant, and have them slip it in place while you pull the display from the case.
    gordojenkins - Antwoord
    I gave up with the suction cup as it wasn't working for me with a cracked screen. Having heated the bottom of the phone with a hair dryer with a high heat for a good minute or so, I used a safety scraper (essentially a razor blade in a holder) along the bottom of the phone to separate the screen from the body of the phone. I used the scraper vertically between the bottom of the screen and the phone body and levered it sufficiently so that I could fit the spudger between the screen and the phone body. My experience when I first used the spudger around the frame was that the cracks in the screen caused the screen glass to separate from the frame, so I had to re-do it and ensure that the screen frame was separated from the phone body.
    Safety scraper:
    https://www.amazon.co.uk/Unger-CD170-Win...
  6. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 6, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 6, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 6, afbeelding 3 van 3
    • De beste en meest veilige plek om te wrikken is de inkeping in het voorste paneel, net boven de hoofdtelefoonjack.
    • Steek het platte einde van een spudger, terwijl je druk op de zuignap houdt, in de gecreëerde opening, direct boven de hoofdtelefoonjack.
    This was by far the hardest part of the repair for me. Getting leverage while finding a way to prod with a spudger is a challenge in coordination. I used a second spudger with point holding the phone down by the headphone jack, with the other end of the spudger anchored to my desk.
    drpotter - Antwoord
    When warmed, the suction cup was useless. Using the tip of a knife blade, was able to get it separated enough to insert spudger.
    hutland - Antwoord
    For me this was the most time consuming task. I used a hair dryer for heating. I found a very tight adhesive. For a moment I thought of abandoning my efforts and take the assembly to a professional repairman. But as they say, patience is a virtue.
    After fiddling for about 20 minutes, I achieved a barely noticable opening. So I decided to change the strategy. Instead of applying heat all over the base, I preceeded with small steps with heat concentrated near the opening. I applied intense heat only for about 15 to 20 seconds and immediately working with spudger. It took about an hour to completely open the case. It worked.
    Thanks for reading.
    - Mr Gamma
    Gamma Pailvan - Antwoord
    I also struggled with this step. Lots of heat, 3 different suction cups, I finally could see a small gap... much too thin to fit even a piece of paper into. A video on another site said it was the easy way. I used a sharp craft knife barely into the seam between metal and glass and pried slightly. And it started up. Still a pain freeing the rest of the adhesive. Perhaps the adhesive really sets up over the course of 5 years? I have it hinged open now, so onto the next steps.
    Mark Tollefson - Antwoord
  7. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 7, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 7, afbeelding 2 van 2
    • Kantel je spudger lichtjes terwijl deze in de opening zit om zo de opening tussen de schermmodule en de rest van de telefoon te vergroten.
    just changed the screen, but due to the tape along side the screen , it is best to heat a little so the glue losses and you can get the screen off better, like indicated
    Bart Blanckaert - Antwoord
  8. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 8, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 8, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 8, afbeelding 3 van 3
    • Schuif de zijkant van de spudger, terwijl je stevig aan de zuignap trekt, onder de linker onderhoek van het scherm.
  9. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 9, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 9, afbeelding 2 van 2
    • Schuif de punt van je spudger langs de linkerkant van de telefoon omhoog, tussen de schermmodule en de achterste behuizing.
  10. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 10, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 10, afbeelding 2 van 2
    • Steek het platte einde van je spudger onder de rechterkant van het scherm.
    • Schuif de spudger langs de rechterzijde omhoog.
  11. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 11, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 11, afbeelding 2 van 2
    • Gebruik een plasticen openingstool om de achterste behuizing vast te houden terwijl je de zuignap naar boven trekt om de telefoon te openen.
    • Verwijder het scherm nog niet volledig, aangezien deze aan de bovenkant van de iPhone nog vastzit door middel van datakabels die je zo kunt beschadigen.
  12. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 12, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 12, afbeelding 2 van 2
    • Trek aan het kleine lipje op de zuignap om deze van het scherm te verwijderen.
    Remember to apply the screen gasket on the re-assemble. The gasket is provided in the kit but not mentioned here on the instructions.
    Won Hong - Antwoord
    There’s a link to the entire gasket replacement procedure in Step 21.
    Jeff Suovanen -
  13. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 13, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 13, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 13, afbeelding 3 van 3
    • Pak de schermmodule voorzichtig vast en til deze op om de telefoon te openen. Gebruik de klemmen aan de bovenkant van het scherm als een scharnier om de telefoon te openen.
    • Open het scherm totdat deze ongeveer een hoek van 90º beschrijft en laat het scherm vervolgens leunen op een voorwerp, zodat je aan de telefoon kunt werken.
    • Open het scherm niet meer dan 90º—deze is namelijk nog steeds verbonden aan de bovenkant van de telefoon door middel van de scherm-, digitizer-, en voorste camerakabels, welke makkelijk kunnen scheuren.
    • Je kunt bijvoorbeeld een elastiek gebruiken om de schermmodule te verbinden aan een voorwerp, waardoor deze rechtop blijft staan. Dit voorkomt ook dat je de kabels onbedoeld en te veel belast.
    • Je kunt creatief zijn, je kunt ook een blikje drinken gebruiken om het scherm open te houden.
    if the display cables are damaged how can you tell ?
    Smiley McSmilebot - Antwoord
    In theory, I like the idea of propping up the screen with a rubber band and box/soda can like this, but after ripping the FaceTime camera cable twice, I realize that this method puts too much stress on the cable because it places the screen so far back. Even in this photo, you can see that the cable is taut. I’d recommend just holding the screen with your free hand to put the least amount of stress on that cable as possible.
    Ben Estabrook - Antwoord
  14. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Batterijaansluiting: stap 14, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Verwijder de twee Phillips schroeven die het plaatje op de batterijaansluiting aan het logic board bevestigen, met de volgende lengtes:
    • Eén 2.9 mm lange schroef
    • Eén 2.3 mm lange schroef
    • Zorg dat je, tijdens deze reparatie, bijhoudt welke schroef waarvandaan komt, zodat je deze op de juiste plek weer terug kan schroeven. Zo voorkom je schade aan je iPhone.
    FYI - I used some blue painters tape wrapped around a piece of cardboard to hold the screws and brackets in place, in order, so they did not get lost. Some of those screws are MICROSCOPIC so be careful!
    I also suggest having very good lighting, even a camping headlight for hands-free well lit work space. You will thank me later :-)
    Use the bit labeled “PH000”.
    Joe Teichert - Antwoord
    PH000 bit just wants to free-spin in the 2.3 mm screw. no bite in the head at all. had no difficulty removing the 2.9 mm screw with the same Phillips. had to abandon battery replacement effort.
    Benjamin Stalcup - Antwoord
    For this part, neither PH000 or Y000 worked. Technically, it’ll set you back 31$ because you will need the PH00 screwdriver for this part, and the part where you need to open the screen. They have ph00 screwdrivers in every hardware store and even ifixit.com. just know that they put the wrong screwheads for you
    Jack Daniel - Antwoord
    Do not lose track of which hole these screws go into. They MUST be put back into the correct hole that they came out of. If not, you will get the dreaded “long screw damage” on the mainboard, and that will be the end of the show.
    Just remember where these screws go, and it will be fine.
    Harry McDow - Antwoord
    Ended up employing a Philips #0 from a regular jeweler/precision kit on the 2.3mm screw. Bits seem a bit off for this step.
    Vance Bell - Antwoord
  15. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 15, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 15, afbeelding 2 van 2
    • Verwijder het plaatje bovenop de batterijaansluiting.
    Does it matter if the brackets arent put back in the phone? I bought a used phone and brackets are missing. Thanks!
    Coupon Crazy - Antwoord
    Auch die Abdeckung ist angeklebt. Also mit etwas Vorsicht und Geduld rangehen.
    eckhardd@icloud.com - Antwoord
    If you have forgotten your High School German -
    The cover is also glued. So take some care and patience.
    Glen Paetz -
    My bracket actually has a black wire connected on the underside that is attached to the metal bracket (with screw) below it in the picture. I decided to leave it on and just move it to the side.
    Victor Ng-Thow-Hing - Antwoord
  16. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 16, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 16, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 16, afbeelding 3 van 3
    • Gebruik de punt van een spudger om de batterijaansluiting los te koppelen door deze in een rechte beweging omhoog te duwen van het logic board.
  17. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 17, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 17, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 17, afbeelding 3 van 3
    • Duw de batterijaansluiting weg van het contact om zo te voorkomen dat deze tijdens de reparatie per ongeluk contact maakt en de telefoon mogelijk inschakelt.
    When putting the new battery in, make sure to line up the plug and not to the top of the battery… our battery was smaller so the plug would NOT have lined up if we used the top of the battery. ALSO, the plug was NOT 90 degrees so we had to finagle the plug. Also, make sure there is a clear CLICK when you plug in the connector or it may not work. Ours went in but guess didn’t go far enough so we had to take the screen off and push it harder until we heard the “click” then it worked fine.
    Won Hong - Antwoord
    There was some black goop/glue around the battery connector, and when I lifted the old connector, some of that glue fell into the receptacle. It was easy to fish out (with magnifying glass and tweezers) but if you don't catch it, you may not get a good connection.
    Steerpike - Antwoord
  18. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Schermmodule: stap 18, afbeelding 1 van 1
    • Verwijder de volgende Phillips schroeven:
    • Drie 1.3 mm lange schroeven
    • Eén 1.6 mm lange schroef
    • Eén 3.0 mm lange schroef
    • Het is tijdens het weer in elkaar zetten van je telefoon essentieel om deze 3.0 mm lange schroef in rechter bovenhoek van het plaatje te plaatsen, aangezien deze schroef op iedere andere plaats het logic board zou kunnen beschadigen.
    I really don't see value in removing screen use box and rubber band keep at 90 degrees.
    John Parker - Antwoord
    I leave screen on as well for this. - Tho I prefer a 45 degree lean.
    Thor -
    I just changed my battery and also left the screen attached. I was lucky enough to get all 3 adhesive battery strips out clean so I didn’t have a struggle with the battery coming out. If I was going to need to get rough with it I was going to take the screen off at that point.
    Michael Gross - Antwoord
    To keep track of screws, draw a quick outline of the display cable bracket/cover, with five dots where screws should be. Drop the screws on the corresponding dot. Helps if you use magnet pad.
    Christa - Antwoord
    Better yet, print out the pictures from the iFixit website, and use clear tape (“Scotch tape”) to TAPE the screws onto the place in the picture where they belong.
    Tom -
    Which screwdriver from the kit do I use for which screw?
    Shiva Sharma - Antwoord
    I made a mistake and unscrewed the screw just north north west of the one circled in yellow. Of course I lost the screw. Can anyone give me any guidance about this? what does the wire connected to it do? What is the size of the screw, in case I have to replace it?
    P.S. This is another reason to consider the possibility of NOT removing the screen just to replace the battery: removing the screen presents a additional possible headache, especially for people like me with bad eyesight who probably shouldn’t be doing this in the first place.
    Tom - Antwoord
    It is a 1.4 mm Phillips screw holding the NFC bracket in place.
    Larry Lynch -
    I didn’t think this was necessary, bit I see it relieves stress on the front-facing camera and sensor cable connector; I did not disconnect the display connector nor remove the display screen.
    I second this finding. I too did not remove the screws nor the bracket. The cables look a bit stretched, but certainly not strained.
    -Gamma
    Gamma Pailvan -
    This step of separating the two parts of the phone deserves careful consideration. In my case, I had propped up the display assembly with a box and rubber bands. However, only 2 of the battery adhesive strips came off easily. The effort to remove the battery with the display assembly attached was not a good move on my part. I jarred the ear speaker cable and after reassembly I had no camera or working ear speaker. Taking off these 5 screws and removing the three cables is not difficult. My suggestion: is you have ANY trouble removing the 3 battery adhesive strips, STOP, separate the two components, and then continue with the battery removal. Don’t struggle removing the battery with the display assembly attached. (I replaced the ear speaker cable, and all is working now)
    Richard Perl - Antwoord
    Thanks for this tip! I am having a really hard time removing this plate because one of the screw heads are stripped. So I’ll try removing the battery adhesive strips first to see if I can get the battery out without removing the screen.
    nathanfunk -
    Use dixie cups and label them for each part you take out. You can stack the dixie cups to keep them in order.
    Bradley Nolen - Antwoord
    I skipped this for the battery removal, but when I went to replace the seal, I had to remove it anyway.
    dgol69 - Antwoord
    I lost the bottom left screw of the five in this step - anyone know if it’sgoing to cause a problem? ‘m going to go ahead and put thephone back together anyway - wil report back withresult
    OMG…. SO excited! It works! Seems that missing screw wasn’t an issue. The reason I’m so excited is, I’m a senior and have bever attempted anything like this before and was worried I’d mess it up, or it just wouuldn’t work for whatever reason. I know I never would have tried if it weren’t for finding this site, the great service, parts to do it and the videos/guides. Thank you so much ifixit. :-)
    I changed the battery, without removing the screen, when I closed the phone the front camera and speaker no longer work.
    Mr T - Antwoord
  19. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 19, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 19, afbeelding 2 van 2
    • Verwijder het plaatje bovenop de schermkabel.
    Be careful on this step: with my iPhone, one of the connectors (the home button/fingerprint sensor) was stuck to the underside of the bracket and I almost strained its cable.
    kevin - Antwoord
  20. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 20, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 20, afbeelding 2 van 2
    • Zorg ervoor dat je enkel de aansluiting zelf en niet het contact op het logic board omhoog duwt.
    • Gebruik een plasticen openingstool om de naar voren gerichte camera en de sensorkabelaansluiting los te koppelen.
    FYI, in the video she uses the spudger for this but I think either one will work.
    I found prying from the right to be better
    Is there any need for this step if only the Battery is replaced
    mrrreid - Antwoord
    I don’t recommend using the spudger for this as you can do more damage that way. I scratched the black square thing underneath.
    Laura Houghton - Antwoord
    I managed to remove the battery without disconnecting and removing the display first. This avoids possible difficulties in these steps (see below).
    One has to be careful that, while fighting with the battery strips, the display remains in its 90º position
    alfasw33 - Antwoord
  21. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 21, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 21, afbeelding 2 van 2
    • Gebruik een plasticen openingstool om de digitizerkabel los te koppelen door ook deze in een rechte beweging uit het contact op het logic board omhoog te duwen.
    • Druk, bij het weer aansluiten van de digitizerkabel, niet op het middel van de aansluiting. Druk de aansluiting aan een kant aan en druk dan de andere kant aan. Als je de aansluiting in het midden vastdrukt, loop je het risico een pin in de aansluiting te buigen en de digitizer permanent te beschadigen.
    Thanks you i fix it
    God Hand - Antwoord
    “When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage. “
    The following note above was so helpful. I was speeding through the process of getting things back together, since it seemed easy to connect the digitizer cable, but I kept pushing it in the middle and I wouldn’t connect. Until I read through this step and realized it was easier if I would’ve connected one side and then the opposite side right after.
    Don’t be too shy when pushing the ends of the digitizer connector back to place. If it does not connect properly, you might face the “half backlight” problem, even if you did not kill any LCD filter. Also check carefully, that you don’t clamp parts of the sticky sealing material placed around the connector inside the connection area.
    Norbert Andreas Richartz - Antwoord
    This part was a very frustrating experience for me.  I thought that my replacement screen was just poor quality, as it worked when it wanted to work.  Pressing home/power repeatedly sometimes brought it back, charging to 100% also brought it back.    The actual problem was that it is very easy to get some of the gasket material caught in the connector, which I couldn’t see until I used my jeweler's loupe.  I used 91% alcohol to carefully clean all of this off until all pins were shiny, and it took about 6 tries to get it right.  However, the screen’s been running well for 2 days now.  I already bought another screen replacement which I have for a spare as it was 100% not the problem.
    chumblyf - Antwoord
    I followed all the steps, so the sound is missed. What could be happened? thanks a lot. Fabio Balbino
    Fabio Balbino - Antwoord
  22. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 22, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 22, afbeelding 2 van 2
    • Zorg dat de batterij is losgekoppeld voordat je de kabel in deze stap loskoppelt of weer aansluit.
    • Koppel de thuisknop/vingerafdruksensorkabel los door deze in een rechte beweging uit het contact op het logic board omhoog te duwen.
    How much is this to replace?
    Alistair knight - Antwoord
    And where could I buy from?
    After finishing the assembly I got the message “Touch ID cannot be enabled on this phone”. I found this connector was loose. Plugged it back in and that fixed it.
    Bryan Province - Antwoord
    Thanks for the tip. Same thing happened to me, some leftover adhesive was in the way!
    Sean - Lua Tech -
    Always make sure to disconnect the battery before you do any work on the phone replacing any parts the digitizer or anything. And before you start make sure the phone is turned off you don’t want any power surges. If you also have a static electricity bracelet that also is a plus to use but isn’t a necessity just a nice piece of mind. Some cases you do need to use one so you don’t discharge static electricity to an electrical component and mess it up.
    Brent - Antwoord
    Be very careful in this step. I noticed it’s very easy to tear the flex when trying to lift it out of its socket from the right side.
    shoeib - Antwoord
    What is the cable and how is it connected/fixed to the motherboard between the bottom socket and the screw hole.
    Mine came loose somehow?
    Jason Engelsman - Antwoord
    I figured out my own question its the Wi-Fi diversity antenna cable. But how is it connected/secured to the motherboard?
    i pressed on the center of the digitizer connection. and the bottom half of my screen didnt work. i then took that same front panel assembly and tried to install it on another old iphone 6s+ and i had the same issue.
    can i still fix it?
    what exactly is broken now?
    alejandro rueda - Antwoord
    @mynameisoli Honestly this just sounds like a defective screen to me, but it’s hard to say for sure. Look closely at the connector at the end of the ribbon cable and check it for damage. If it’s slightly bent/curved, all the pins won’t make good contact in the socket. You can try bending it back so it lays flat, but you have to be very careful not to damage the connector or contaminate the pins with skin oils, so it’s tricky—and it may be harder to return as “defective” if you mess up the connector. So try this at your own risk. Apart from that, I would just return it and try a different display. Good luck!
    Jeff Suovanen -
    The 6s plus screen repair kit i bought has the wrong size cable here on the replacement part. SOL.
    Alex Richardson - Antwoord
    Once I accidentally disconnected the display assembly cables before disconnecting the battery. Now the home button and fingerprint sensor doesn’t work. Any solution to this?? I have tried a different home button, even that doesn’t work.
    a3roar - Antwoord
    I changed the battery on my iPhone and put all together again and charged it. When I pressed the home button the lock screen with my picture appeared and when I pressed it again the screen with the digits from 0 to 9 appeared. I was asked to enter my passcode, but when I did that nothing happened, the phone did not open.
    What could be wrong? Is the home screen cable not fully connected or what could be the reason for this?
    THORDUR JOHANNESSON - Antwoord
  23. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 23, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 23, afbeelding 2 van 2
    For instructions on home button swap out to the new screen you just installed, go here
    iPhone 6s Plus Vervanging van de thuisknopmodule
    Superior Office Systems - Antwoord
    Do you know whether the adhesive contributes to waterproofing, or just for stability/adhesion?
    Christa - Antwoord
    @kitabel The iPhone 6s case isn’t waterproof, so I don’t think adhesive around the display is contributing anything other than stability. The 6s series does have some water resistance, but it’s mostly internal and not something Apple advertises.
    Jeff Suovanen -
    If you have a replacement adhesive for the display, you may need to install it before reconnecting cables to the components. If the adhesive wraps all the way around the display, it will be impossible to install it once the display is reconnected.
    Matthew Olwell - Antwoord
    These instructions worked great for me. Thank you!
    Chris Enloe - Antwoord
  24. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Thuisknopmodule: stap 24, afbeelding 1 van 1
    • Verwijder de twee 1.9 mm lange Phillips schroeven die het plaatje over de thuisknop bevestigen.
    Maybe this should be totally obvious, but it took me a minute or two to realize that this step is performed on the DISPLAY ASSEMBLY that was just removed, rather than the main body of the phone, which is the part on which all the previous steps were performed.
    Tom - Antwoord
    The new display came with a 1.9mm screw installed (the top left one above). This must be removed before putting back the home button bracket. It took me way too long to realize why I couldn’t thread the old screw back into the hole.
    Brandon Mathew - Antwoord
    If you bought a screen assembly with a home button but have not ever set up touch ID can you set up touch ID on the new screen’s home button?
    Andrew Shircel - Antwoord
    The home button and logic board are usually married. So if it’s a new home button paired with the original logic board, the Touch ID won’t work.
    Brittni Gange -
    do not over tight the screw or the lcd will get damaged
    764349 - Antwoord
  25. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 25, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 25, afbeelding 2 van 2
    • Verwijder het plaatje over de thuisknop.
    My home is wiggley I do not like it
    can you put home button adhesive
    Riley - Antwoord
  26. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 26, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 26, afbeelding 2 van 2
    • Gebruik de punt van je spudger om de thuisknopkabel los te koppelen van de aansluiting op de schermmodule.
    Gently: this piece is attached to the plastic cabling, not the surface of the phone
    Christa - Antwoord
    Buongiorno,ho cambiato display però adesso non mi funziona touch sul tasto home…cosa potrebbe essere???grazie
    eduartkurani - Antwoord
    ciao, hai risolto? ho sto valutando se cambiare lo schermo appunto per questo motivo, ho letto online che gli schermi non originali danno questo problema
    serena184 -
  27. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 27, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 27, afbeelding 2 van 2
    iOpener
    $19.99
    Koop
    • De rubberen pakking om de thuisknop heen is erg dun en scheurt daarom gemakkelijk.
    • Dien wat warmte toe (met een iOpener, warmtepistool of een föhn) om de lijm die de pakking van de thuisknop bevestigt, te verzachten.
    • Druk, met behulp van je vingertopje, voorzichtig op de thuisknop vanaf de voorkant van de schermmodule. Gebruik een stevige, constante druk om de rubberen pakking van de thuisknop los te duwen van het voorste paneel en zo de thuisknop los te maken.
    “The gasket is very thin and will tear easily. Apply steady pressure and give it time to separate. “
    The note above was very helpful. It really is thin and for one second I thought I punctured a whole through it, so be careful.
    I did this on 2 separate phones. The first time, I did it according to directions, and it worked well. However, the adhesive pulled off in the process. On the 2nd phone I used a handwarmer to slightly warm the home button area. (I think an iOpener would work best, but I didn’t have one on hand). With the constant pressure after being heated, the home button assembly came off easily, and the adhesive stayed in place. I’ll definitely use slight heat in the future for this step as it seems to lessen the possibility of damaging the assembly.
    Jami - Antwoord
    I would have liked to see the heating instructions on this page. I only saw it once I re-watched the video as I was having trouble getting the button out. iFixit would have made another sale had it been obvious that the heating pad would come in handy. I ended up using a microwave heating pad instead. Worked fine.
    Scott - Antwoord
    If anyone else is totally caught off guard by the need for heat at this point, the previous mention of a heating pad gave me the idea of heating a wet paper towel in the microwave and sticking it in a plastic bag. Obviously make sure no moisture escapes into the device. Worked fine, and is absolutely necessary: that gasket is VERY delicate.
    Joshua Rodgers - Antwoord
  28. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 28, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 28, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 28, afbeelding 3 van 3
    • Gebruik de punt van een spudger om de licht vastgemaakte flexkabel van de thuisknop van de schermmodule los te wrikken.
  29. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 29, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 29, afbeelding 2 van 2
    • Verwijder de thuisknopmodule.
    Make sure you remove any broken glass from around the button edges. Took me a few times to realize it had some glass on it.
    johnarchitzel - Antwoord
    I could not believe how EASY this was to repair my phone! Granted, it took me awhile (2 hrs) to replace a camera and a screen, but I was probably overly meticulous about each step, especially making sure the old adhesive was fully removed and the frame was clean. I can imagine, with tolerances being as tight as they are — I could barely see some of the screws! — the slightest lump of glue might have made a smooth placement difficult. But, in the end, it was worth it! Screen looks and works awesome, and so does my camera!
    Huge props to you for this detailed guide! Very easy to follow and flawless result! Thank you!
    Patrick Lynch - Antwoord
    does the home button work after you put it on the new repaired phone?
    Victoria Vojvodich - Antwoord
    what about the camera? i don’t see the step moving the old camera over to the new screen
    Brian - Antwoord
    Gasket guys!! How do you properly replace the gasket?? Not shown!!
    Jim Hickman - Antwoord
    Friends, take a very, very close look at how the connector on the replacement screen is situated. It rests BEHIND a small L shaped ledge that holds it in place. Once connected to the home button ribbon, you will need to seat it behind the little ledge. Otherwise it will be sitting on top of the ledge, and the metal cover won't fit properly before it is screwed back in place.
  30. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, Oorstukspeaker: stap 30, afbeelding 1 van 1
    • Verwijder de volgende drie Phillips schroeven:
    • Twee 2.7 mm lange schroeven
    • Eén 1.4 mm lange schroef
  31. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 31, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 31, afbeelding 2 van 2
    • Verwijder het plaatje op de oorstukspeaker.
  32. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 32, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 32, afbeelding 2 van 2
    • Gebruik het platte einde van een spudger om de FaceTime-camera uit de behuizing te tillen.
  33. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 33, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 33, afbeelding 2 van 2
    • Trek de FaceTime-camera naar achteren en verwijder de oorstukspeaker.
  34. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, FaceTime-camera en sensormodule: stap 34, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, FaceTime-camera en sensormodule: stap 34, afbeelding 2 van 2
    • Gebruik de punt van een spudger om de omgevingslichtsensor uit haar behuizing in het voorste paneel te tillen.
    Getting this assembly back in place was the most frustrating part of the entire reassembly. The preformed cables kept moving the sensors out of their sockets and making reassembly impossible. A little patient work using the spudger to hold things in place with one hand while placing the speaker and camera lens with the other got things reinstalled.
    junk4stumac - Antwoord
  35. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 35, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 35, afbeelding 2 van 2
    • Steek de punt van je spudger tussen de flexkabel van de microfoon en het voorste paneel om de lijm die zich daar bevindt door te snijden.
    I’m pretty sure I made a mistake at this point by applying a heat gun to soften the tacky adhesive. I suspect that the molded plastic lens on the camera became hot and the antireflective coating on it cracked all over. Under a microscope it looks messed up. The result is that the camera is now blurry. So be careful with applying heat.
    tcnewell - Antwoord
  36. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 36, afbeelding 1 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 36, afbeelding 2 van 3 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 36, afbeelding 3 van 3
    • Gebruik het platte einde van een spudger om de microfoon en de pakking van het oorstuk omhoog te tillen.
  37. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 37, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 37, afbeelding 2 van 2
    • Verwijder de FaceTime-camera en de sensormodule.
    Attention, au remontage trier les deux nappes horizontales pour que la nappe la plus large soit dessous.
    Brancher d’abord la nappe verticale latérale puis la nappe horizontale haute et enfin la nappe horizontale basse.
    Dominique Verdejo - Antwoord
    The replacement sensor comes with one of the sensor connectors covered with another plug. So if the connector doesn't want to fit, you can remove the outer connector adapter and then connect using the inner connector. Also, I installed this along with a new battery to fix the proximity sensor not working when making a call. Well, this didn't fix it either. So I suspect it's an OS issue, but I'm not about to upgrade a 7-year old phone. It is what it is!
    Brian K - Antwoord
    After removing the camera and sensor assembly, note the white colored dot in the recess for the ambient light sensor. It is actually a filter which must be transferred to the new unit. It is held in with mild adhesive and does not require any heat to remove it. Simply use the pointed end of a spudger or pointed tweezers to gently remove it.
    Larry Lynch - Antwoord
  38. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, EMI-scherm: stap 38, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, EMI-scherm: stap 38, afbeelding 2 van 2
    • Verwijder de zeven 1.5 mm lange Phillips schroeven die het EMI-scherm bevestigen.
    • De schroef aan de rechterkant in de eerste foto zit ongeveer 1.8 cm van de zijkant van het scherm vandaan.
    On the iphone 6s (not plus)the recessed screw is different to the other 6. The screw head is smaller.
    Stephen Harman - Antwoord
  39. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 39, afbeelding 1 van 2 iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer: stap 39, afbeelding 2 van 2
    • Verwijder het EMI-scherm uit het voorste paneel.
    So, this guide is garbage right here. There is no mentioning the home button connector, wich holds the bottom of the EMI shield in place. You can not remove the shield if this is not loosened. You also need to heat it or the cable will break. I now have to buy a new heat shield since my cable broke thanks to this guide
    Albert - Antwoord
  40. iPhone 6s Plus Vervanging van het LCD-scherm en de digitizer, LCD en digitizer: stap 40, afbeelding 1 van 1
    • Enkel het LCD-scherm en de digitizer blijven over.
    • De Touch ID-functie zal ALLEEN werken met de originele thuisknopmodule van je telefoon. Deze zul je dus mee over moeten zetten naar je nieuwe schermmodule om de Touch ID-functie te behouden.
    • Maak, na het weer in elkaar zetten van je telefoon en voordat je deze weer inschakelt, het oppervlakte van de touchscreen schoon met wat alcohol. De alcohol helpt bij het weghalen van mogelijk aanwezige statische electriciteit, welke problemen van het touchscreen kan veroorzaken.
    • Sluit je iPhone, na het weer in elkaar zetten van je telefoon, aan in een stopcontact voordat je je iPhone weer voor de eerste keer inschakelt. Als de iPhone eenmaal succesvol is opgestart, kun je je telefoon weer uit het stopcontact halen.
    Step 39 shows front panel display with connector for Touch-ID female receiver for Home-button attached to the metal plate. How do you remove and transfer that component to new donor screen?
    Robert Rutty - Antwoord
    @rrutty06 You don’t—that flex cable is integrated into the display assembly. If you try to access it, you run a high risk of destroying the display completely. If your new display doesn’t have that part already, it’s likely not a 6s Plus display.
    Jeff Suovanen -
Conclusie
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
158 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en nl
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Evan Noronha
223.594 Reputatie
168 handleidingen geschreven
11 opmerkingen
with the new update, how do I avoid bricking my phone. i read an article that said if a non authorized apple person attempts to fix my phone the phone will be bricked. iphone 6 plus firmware 4.52.00 update 9.2.1.
Josuee Lara - Antwoord
I believe you are referring to the Error 53 bug which has since been fixed. Initially, it was caused by people attempting to update their iPhones with a Home Button other than the original factory-installed unit—the update would pause halfway through and the iPhone would be bricked.
This guide involves transferring your original Home Button to the new display, so that's not an issue in this situation, but if you were to use a new Home Button, you would still be safe since Apple's issued a fix for Error 53.
Evan Noronha -
Whats the reasoning behind letting the AC charger turn the phone on and not the power button?
Rob Blank - Antwoord
My iphone 6s plus was water damaged and I've been told that I only need to replace the screen as the parts are still in good condition. My question is in this case do I have to replace only the front panel or the full display assembly?
Mariam - Antwoord
Did you ever get a answer ? Same problem I have
johnsonshatara -
They come fused at one unit, removing one removes the other.
Tugging -
You left out the part about loosening the home button connection wich are attached to the large heat shield. If it is not carefully heated and removed it will break and you will not have a home button to use. Should be step 37
Albert - Antwoord
I've performed this without using the ‘iOpener’ by carefully peeling with a spudger (step 26) as directed. It worked fine.
In response to comment Sept 17 from Albert, I did not have an issue during steps 36-37. Not sure what that comment is about. Unless it was confused with steps 26-27 having to do with the removal of the touch ID/home button. Again, I did not use heat to loosen the adheshive. I did have a warm rice bag (poor man’s iOpener, just a cloth bag with dry rice in it, warmed in the microwave at half power…) on hand in case it felt like not releasing easily. From what I found disassembling an iPhone6S Plus that’s over a year old is all the cable adhesives (top and bottom of phone) were ready to release with very little effort.
Side/screen adhesive lifting from the case proved to be the most challenging. This is due to the original damage, left side bracket that connects to EMI shields was broken on the phone. Be careful when separating if damage is extensive!
Sean Finney - Antwoord
Thank you for another thorough repair guide! With each repair, I am gaining confidence and competency that makes each repair that much faster. I just finished a bare display replacement in just over an hour on an i-Phone 6S Plus!
Peter Bovey - Antwoord
Hi Evan and thanks for your guide!
I’ve broken only the glass but if I’ve understood correctly, the glass is not separable from the retina screen right? So I’ve to buy a new glass/screen and follow this guide to replace every pieces except the retina screen cause is already installed in the glass (like this).
Many thanks
Giuseppe
ballone.giuseppe - Antwoord
One of the best explained step by step instructions I have read. My iphone 6 plus screen is cracked and before ordering the part I wanted to make sure I could do it myself. Definitely bookmarking this and using it when I do the replacement. I do have one question though. I also need to replace the back facing camera. At what point in the process should I do this? Thank you,
Rene Russell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 286
Altijd: 108,490
