Ga door naar hoofdinhoud
iPhone 14 Screen Replacement
Wat je nodig hebt
  1. iPhone 14 Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 2 iPhone 14 Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 2 van 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    PLEASE remove back first and disconnect battery before taking cables off!! as per Apple instructions
    PC Technology Group - Antwoord
  2. iPhone 14 Screen Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 14 Screen Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 14 Screen Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Antwoord
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Antwoord
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Antwoord
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Antwoord
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Antwoord
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Antwoord
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Antwoord
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Antwoord
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Antwoord
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Antwoord
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Antwoord
  3. iPhone 14 Screen Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 14 Screen Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 14 Screen Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Had to do the superglue. Also that glass was so shattered that it came off in pieces, took my almost an hour to get the whole screen of. Tape didn't really help there, it would just pull the tape off instead of the screen. Do note that the whole screen assembly is quite thick, I think I initially put my pick in a layer inbetween.
    1st step you have forgotten remove the back to disconnect battery golden rule battery first
  4. iPhone 14 Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 14 Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 14 Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Follow this guide to secure your rear glass with the included tape.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Screen Replacement: stap 5, afbeelding 1 van 3 iPhone 14 Screen Replacement: stap 5, afbeelding 2 van 3 iPhone 14 Screen Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Screen Replacement: stap 6, afbeelding 1 van 3 iPhone 14 Screen Replacement: stap 6, afbeelding 2 van 3 iPhone 14 Screen Replacement: stap 6, afbeelding 3 van 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Screen Replacement, Heat the bottom edge: stap 7, afbeelding 1 van 1
    • If you're using a suction handle, follow the next two steps to loosen the screen.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Screen Replacement, Insert an opening pick: stap 8, afbeelding 1 van 3 iPhone 14 Screen Replacement, Insert an opening pick: stap 8, afbeelding 2 van 3 iPhone 14 Screen Replacement, Insert an opening pick: stap 8, afbeelding 3 van 3
    • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The adhesive holding the screen is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Screen Replacement, Heat the right edge: stap 9, afbeelding 1 van 2 iPhone 14 Screen Replacement, Heat the right edge: stap 9, afbeelding 2 van 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 14 Screen Replacement, Separate the right adhesive: stap 10, afbeelding 1 van 3 iPhone 14 Screen Replacement, Separate the right adhesive: stap 10, afbeelding 2 van 3 iPhone 14 Screen Replacement, Separate the right adhesive: stap 10, afbeelding 3 van 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 14 Screen Replacement, Heat the top edge: stap 11, afbeelding 1 van 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 14 Screen Replacement, Separate the top adhesive: stap 12, afbeelding 1 van 3 iPhone 14 Screen Replacement, Separate the top adhesive: stap 12, afbeelding 2 van 3 iPhone 14 Screen Replacement, Separate the top adhesive: stap 12, afbeelding 3 van 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 14 Screen Replacement, Heat the left edge: stap 13, afbeelding 1 van 2 iPhone 14 Screen Replacement, Heat the left edge: stap 13, afbeelding 2 van 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 14 Screen Replacement, Screen information: stap 14, afbeelding 1 van 1
    • There are two delicate cable along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 14 Screen Replacement, Separate the left adhesive: stap 15, afbeelding 1 van 2 iPhone 14 Screen Replacement, Separate the left adhesive: stap 15, afbeelding 2 van 2
    • The cables along the left edge are very easy to damage with a pick. Follow this alternate procedure to separate the left adhesive.
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
    My glass was so shattered that twisting picks never was going to create enough force for the centre to come loose. I just pulled up the corners with my hands.
  16. iPhone 14 Screen Replacement, Open the iPhone: stap 16, afbeelding 1 van 3 iPhone 14 Screen Replacement, Open the iPhone: stap 16, afbeelding 2 van 3 iPhone 14 Screen Replacement, Open the iPhone: stap 16, afbeelding 3 van 3
    • Remove your suction handle from the screen.
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
    • Lean the screen against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
    • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
  17. iPhone 14 Screen Replacement, Unfasten the display connector bracket screw: stap 17, afbeelding 1 van 2 iPhone 14 Screen Replacement, Unfasten the display connector bracket screw: stap 17, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the 0.9 mm-long screw securing the display connector bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 14 Screen Replacement, Remove the display connector bracket: stap 18, afbeelding 1 van 3 iPhone 14 Screen Replacement, Remove the display connector bracket: stap 18, afbeelding 2 van 3 iPhone 14 Screen Replacement, Remove the display connector bracket: stap 18, afbeelding 3 van 3
    • Grasp the screw hole end of the connector bracket with a pair of tweezers.
    • Lift the bracket slightly to loosen the latch on the other edge.
    • Remove the display connector bracket.
    • During reassembly, make sure the bracket latches properly.
  19. iPhone 14 Screen Replacement, Disconnect the display connector: stap 19, afbeelding 1 van 2 iPhone 14 Screen Replacement, Disconnect the display connector: stap 19, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the display cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    It is necessary to disconnect the battery flex cable prior to disconnecting the screen to prevent any electrical damage to the device. This guide is inaccurate. You have to remove the rear glass panel first to disconnect the battery.
    Alec - Antwoord
    @robialecm It's not necessary, although it is a bit risky to do it without disconnecting the battery by just turning it off. Anyway, I wanted to check if the new screen was working before fully reassembling, otherwise the warranty on my replacement screen would be void. I have to admit I accidentally turned on the phone a few times, it's hard to not press the power button every once in a while. I managed to turn off the phone more or less by pressing volume up then volume down then hold power button then wait until reboot, keep holding power button until screen goes dark, then quickly release. But I was lucky that the new screen didn't sustain any damage because I'm pretty sure the phone was on while I was messing with the display connector.
    I was very careful reconnecting the cables, and therefore it took my a very long time. Every time I pushed one side, the other side would come out. In the end the trick was to keep one side pressed down while gently - not too gently - pressing the other side.
  20. iPhone 14 Screen Replacement, Unfasten the front sensor connector bracket: stap 20, afbeelding 1 van 2 iPhone 14 Screen Replacement, Unfasten the front sensor connector bracket: stap 20, afbeelding 2 van 2
    • Use a Y000 screwdriver to remove the 0.9 mm-long screw securing the front sensor connector bracket.
  21. iPhone 14 Screen Replacement, Remove the front sensor connector bracket: stap 21, afbeelding 1 van 3 iPhone 14 Screen Replacement, Remove the front sensor connector bracket: stap 21, afbeelding 2 van 3 iPhone 14 Screen Replacement, Remove the front sensor connector bracket: stap 21, afbeelding 3 van 3
    • Remove the front sensor connector bracket.
  22. iPhone 14 Screen Replacement, Disconnect the front sensor cable: stap 22, afbeelding 1 van 2 iPhone 14 Screen Replacement, Disconnect the front sensor cable: stap 22, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the front sensor cable by prying the connector straight up from its socket.
  23. iPhone 14 Screen Replacement, Remove the screen: stap 23, afbeelding 1 van 2 iPhone 14 Screen Replacement, Remove the screen: stap 23, afbeelding 2 van 2
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the screen adhesives.
  24. iPhone 14 Screen Replacement, Unfasten the front sensor bracket: stap 24, afbeelding 1 van 1
    • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
    • Use a Y000 screwdriver to remove the two 1.4 mm-long screws securing the sensor assembly bracket.
  25. iPhone 14 Screen Replacement, Remove the front sensor bracket: stap 25, afbeelding 1 van 2 iPhone 14 Screen Replacement, Remove the front sensor bracket: stap 25, afbeelding 2 van 2
    • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
  26. iPhone 14 Screen Replacement, Heat the front sensor assembly: stap 26, afbeelding 1 van 1
    • Heat an iOpener and apply it to the top edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  27. iPhone 14 Screen Replacement, Disconnect the ambient light sensor: stap 27, afbeelding 1 van 2 iPhone 14 Screen Replacement, Disconnect the ambient light sensor: stap 27, afbeelding 2 van 2
    • Insert an opening pick between the ambient light sensor and its recess in the screen.
    • Pry up with the pick to separate the ambient light sensor from the screen.
  28. iPhone 14 Screen Replacement, Disconnect the proximity sensor: stap 28, afbeelding 1 van 2 iPhone 14 Screen Replacement, Disconnect the proximity sensor: stap 28, afbeelding 2 van 2
    • Insert an opening pick between the proximity sensor and its recess on the screen.
    • Pry up with the pick to separate the proximity sensor from the screen.
  29. iPhone 14 Screen Replacement, Reposition the proximity sensor: stap 29, afbeelding 1 van 2 iPhone 14 Screen Replacement, Reposition the proximity sensor: stap 29, afbeelding 2 van 2
    • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
  30. iPhone 14 Screen Replacement, Disconnect the microphone: stap 30, afbeelding 1 van 3 iPhone 14 Screen Replacement, Disconnect the microphone: stap 30, afbeelding 2 van 3 iPhone 14 Screen Replacement, Disconnect the microphone: stap 30, afbeelding 3 van 3
    • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
    • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
  31. iPhone 14 Screen Replacement, Remove the front sensor assembly: stap 31, afbeelding 1 van 3 iPhone 14 Screen Replacement, Remove the front sensor assembly: stap 31, afbeelding 2 van 3 iPhone 14 Screen Replacement, Remove the front sensor assembly: stap 31, afbeelding 3 van 3
    • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
    • Insert an opening pick under the left side of the front sensor assembly.
    • Slide the pick under the assembly to separate it from the frame.
  32. iPhone 14 Screen Replacement: stap 32, afbeelding 1 van 2 iPhone 14 Screen Replacement: stap 32, afbeelding 2 van 2
    Tesa 61395 Tape
    $5.99
    • Remove the front sensor assembly.
    • When transferring the assembly to a new screen, follow these instructions:
    • Connect the sensors to their slots in the frame to help align the main section of the assembly.
    • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
25 andere personen hebben deze handleiding voltooid.
Tobias Isakeit
123.755 Reputatie
189 handleidingen geschreven
Tobias Isakeit - Repairability Engineer Lid van Tobias Isakeit - Repairability Engineer
Business
1 Lid
1.131 handleidingen geschreven
8 opmerkingen
Is there still a software lock that disables face id / auto brightness?
Yung Bruh - Antwoord
What about the battery isnt it a risk to connect it like this. Feels like half of the repair job,
atlas Tanko - Antwoord
Hi atlas Tanko, you're right, normally we recommend disconnecting the battery before replacing the screen. Due to the design of the iPhone 14 and 14 Plus (separate entry methods for screen and battery replacements), we consider it safe in this case. For the iPhone 14 Pro and Pro Max, we still include steps for disconnecting the battery during screen replacements.
Manuel Haeussermann -
Hi
iPhone 14 not showing display after replacement.
Connected old one, still no display.
I have previously discharged battery down, managed to access torch and also let screen on up to 10m at time - even though screen was quite damaged.
I am a 'careful repairer', but of course one can easily short pins of screen connector while trying to fit it, even though I use magnified glasses to see I do it as best as possible.
Any idea, do not know the 14 at all.
Thanks
JoeBlog - Antwoord
Hi JoeBlog,
Sorry to hear that you're facing some issues with your repair. How long did you let your phone charge after the repair? Did the device show signs of turning on, like vibration while booting / doing a hard reboot? Does it get recognized when being plugged into a computer? Please also check our troubleshooting resources for the iPhone 14.
you don't disconnect the battery ?
neo mobiles - Antwoord
Always disconnect the Battery!
Oliver -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 109
Afgelopen 7 dagen: 611
Afgelopen 30 dagen: 2,413
Altijd: 68,919
