Ga door naar hoofdinhoud
iPhone 14 Pro Max Screen Replacement
Wat je nodig hebt
  1. iPhone 14 Pro Max Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 2 van 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 14 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 14 Pro Max Screen Replacement: stap 5, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement: stap 5, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 14 Pro Max Screen Replacement: stap 6, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement: stap 6, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement: stap 6, afbeelding 3 van 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 14 Pro Max Screen Replacement, Heat the bottom edge: stap 7, afbeelding 1 van 1
    • If you're using a suction handle, follow the next two steps to loosen the screen.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 14 Pro Max Screen Replacement, Insert an opening pick: stap 8, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Insert an opening pick: stap 8, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Insert an opening pick: stap 8, afbeelding 3 van 3
    • Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  9. iPhone 14 Pro Max Screen Replacement, Heat the right edge: stap 9, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Heat the right edge: stap 9, afbeelding 2 van 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: stap 10, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: stap 10, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Separate the right adhesive: stap 10, afbeelding 3 van 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 14 Pro Max Screen Replacement, Heat the top edge: stap 11, afbeelding 1 van 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: stap 12, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: stap 12, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Slice the top edge adhesive: stap 12, afbeelding 3 van 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and half way across the top edge stopping right before the earpiece speaker cut-out.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
  13. iPhone 14 Pro Max Screen Replacement, Heat the left edge: stap 13, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Heat the left edge: stap 13, afbeelding 2 van 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 14 Pro Max Screen Replacement, Screen information: stap 14, afbeelding 1 van 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 14 Pro Max Screen Replacement, Slice the left edge adhesive: stap 15, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Slice the left edge adhesive: stap 15, afbeelding 2 van 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 14 Pro Max Screen Replacement, Open the iPhone: stap 16, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Open the iPhone: stap 16, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Open the iPhone: stap 16, afbeelding 3 van 3
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
    • Lean the screen against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
    • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
  17. iPhone 14 Pro Max Screen Replacement, Unfasten the battery connector cover screws: stap 17, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Unfasten the battery connector cover screws: stap 17, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
    • Six 1.3 mm-long screws
    • One 1.6 mm-long screw
    • One 1.9 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: stap 18, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: stap 18, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Remove the battery connector cover: stap 18, afbeelding 3 van 3
    • Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
    • Remove the connector cover.
  19. iPhone 14 Pro Max Screen Replacement, Disconnect the battery: stap 19, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Disconnect the battery: stap 19, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 14 Pro Max Screen Replacement, Disconnect the display cables: stap 20, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Disconnect the display cables: stap 20, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 14 Pro Max Screen Replacement: stap 21, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement: stap 21, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the second display cable by prying the connector straight up from its socket.
  22. iPhone 14 Pro Max Screen Replacement, Remove the screen: stap 22, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Remove the screen: stap 22, afbeelding 2 van 2
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the screen adhesives.
  23. iPhone 14 Pro Max Screen Replacement, Unfasten the front sensor bracket: stap 23, afbeelding 1 van 1
    • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
    • Use a PH000 screwdriver to remove the two 1.4 mm-long screws securing the sensor assembly bracket.
  24. iPhone 14 Pro Max Screen Replacement, Remove the front sensor bracket: stap 24, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Remove the front sensor bracket: stap 24, afbeelding 2 van 2
    • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
  25. iPhone 14 Pro Max Screen Replacement, Heat the front sensor assembly: stap 25, afbeelding 1 van 1
    • Heat an iOpener and apply it to the top edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  26. iPhone 14 Pro Max Screen Replacement, Disconnect the proximity sensor: stap 26, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Disconnect the proximity sensor: stap 26, afbeelding 2 van 2
    • Insert an opening pick between the proximity sensor and its recess on the screen.
    • Pry up with the pick to separate the proximity sensor from the screen.
  27. iPhone 14 Pro Max Screen Replacement, Disconnect the ambient light sensor: stap 27, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement, Disconnect the ambient light sensor: stap 27, afbeelding 2 van 2
    • Insert an opening pick between the ambient light sensor and its recess on the screen.
    • Pry up with the pick to separate the ambient light sensor from the screen.
  28. iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: stap 28, afbeelding 1 van 3 iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: stap 28, afbeelding 2 van 3 iPhone 14 Pro Max Screen Replacement, Remove the front sensor assembly: stap 28, afbeelding 3 van 3
    • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
    • Insert an opening pick under the left side of the front sensor assembly.
    • Slide the pick under the assembly to separate it from the frame.
  29. iPhone 14 Pro Max Screen Replacement: stap 29, afbeelding 1 van 2 iPhone 14 Pro Max Screen Replacement: stap 29, afbeelding 2 van 2
    Tesa 61395 Tape
    $5.99
    • Remove the front sensor assembly.
    • When transferring the assembly to a new screen, follow these instructions:
    • Connect the sensors to their slots in the frame to help align the main section of the assembly.
    • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
28 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
228.969 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.412 handleidingen geschreven
16 opmerkingen
What should I do if in the center and where is the eye of the central chamber, under pressure, my fingers click?
Very annoying, on 2 iPhone such clicks, that is, then disappear... thanks
pro style - Antwoord
Thanks for this detailed guide on how to disassemble my phone screen. I was just checking some Celebrity Heights and all of a sudden my screen went black. I tried hard reset and all different things but it was the screen. I bought on eBay a new screen and used your guide to replace it and luckily everything went smoothly. Thanks again.
Briansmith1 - Antwoord
Why would I pay 399 for a stupid kit and do it myself and apple is $20 cheaper and they ll replace it with limited warranty. Wtf yall smoking.
Jimmy g - Antwoord
Then go through Apple
Alec -
Just replaced the iPhone 14 Pro MAX, How do I get rid of the screen error message that the screen is not an authentic device?
Blake2005 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 123
Afgelopen 7 dagen: 839
Afgelopen 30 dagen: 3,105
Altijd: 104,048
