Ga door naar hoofdinhoud
iPhone 12 Pro Max Screen Replacement
Wat je nodig hebt
  1. iPhone 12 Pro Max Screen Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 12 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Antwoord
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Antwoord
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Antwoord
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Antwoord
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Antwoord
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Antwoord
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Antwoord
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Antwoord
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Antwoord
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Antwoord
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Antwoord
  3. iPhone 12 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 12 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 12 Pro Max Screen Replacement: stap 5, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement: stap 5, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 12 Pro Max Screen Replacement: stap 6, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement: stap 6, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement: stap 6, afbeelding 3 van 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 12 Pro Max Screen Replacement, Heat the bottom edge: stap 7, afbeelding 1 van 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    wenn man die Frontkamera nicht tauscht sondern nur anhebt und reinigt, funktioniert Face ID dann noch?
    dominic327i - Antwoord
    Wenn du beim Aus- und Einbau alles richtig machst, dürfte dabei nichts passieren.
    Fabian Neidhardt -
  8. iPhone 12 Pro Max Screen Replacement, Apply a suction cup: stap 8, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Apply a suction cup: stap 8, afbeelding 2 van 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  9. iPhone 12 Pro Max Screen Replacement, Lift the screen slightly: stap 9, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Lift the screen slightly: stap 9, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Lift the screen slightly: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Be very careful on this step to insert the pick as vertically as possible!!! I ended up separating the glass from the outer frame on this step and destroying the screen. Not a cheap mistake to make!
    L E - Antwoord
    I just destroyed the screen as well. I try to read these comments for each step but missed this comment section due to skipping down a few steps for not having the opening tool. Really frustrated.
    Anthony -
    The glue as of the 12 series is incredibly strong. I'm definitely not new to the game and working only with a suction cup, I damaged the screen too, because I couldn't lift it far enough. Therefore, I too had to buy a new screen. 130€ poorer, I would opt for borrowing the display removal kit Apple sells at selfservicerepairs.com. It's around 50 or 60 Euros and worth it.
    Manuel - Antwoord
    It must be emphasized that there's a sandwich here with the phone body, plastic bezel, and screen. The plastic bezel isn't visible as it's hidden by the phone's frame until you raise it with the suction cup -- and if the screen lifts off the bezel when you do this you won't see the bezel and you'll insert the pick between the screen and the bezel, destroying the screen. The instructions need to be much more detailed in this area as the consequences are not only expensive but result in long downtime for the phone (my current situation!). iFixit needs to do a much better job of anticipating what could go wrong and providing ways to avoid it!
    nat2 - Antwoord
  10. iPhone 12 Pro Max Screen Replacement, Heat the right edge: stap 10, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Heat the right edge: stap 10, afbeelding 2 van 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 12 Pro Max Screen Replacement: stap 11, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement: stap 11, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement: stap 11, afbeelding 3 van 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  12. iPhone 12 Pro Max Screen Replacement, Heat the top edge: stap 12, afbeelding 1 van 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 Pro Max Screen Replacement, Separate the top adhesive: stap 13, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Separate the top adhesive: stap 13, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Separate the top adhesive: stap 13, afbeelding 3 van 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  14. iPhone 12 Pro Max Screen Replacement, Heat the left edge: stap 14, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Heat the left edge: stap 14, afbeelding 2 van 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 Pro Max Screen Replacement, Screen information: stap 15, afbeelding 1 van 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Maybe show this vital information earlier??
    Nivek Selarom (NIV3K) - Antwoord
  16. iPhone 12 Pro Max Screen Replacement, Separate the left adhesive: stap 16, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Separate the left adhesive: stap 16, afbeelding 2 van 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 12 Pro Max Screen Replacement, Open the iPhone: stap 17, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Open the iPhone: stap 17, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Open the iPhone: stap 17, afbeelding 3 van 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  18. iPhone 12 Pro Max Screen Replacement, Unscrew the battery and display connector cover: stap 18, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Remove four 1.1 mm-long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 12 Pro Max Screen Replacement, Remove the battery and display connector cover: stap 19, afbeelding 1 van 1
    • Remove the battery and display connector cover.
  20. iPhone 12 Pro Max Screen Replacement, Disconnect the battery: stap 20, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Disconnect the battery: stap 20, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 12 Pro Max Screen Replacement, Disconnect the display cable: stap 21, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Disconnect the display cable: stap 21, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. iPhone 12 Pro Max Screen Replacement, Unscrew the front sensor connector cover: stap 22, afbeelding 1 van 1
    • Use a Y000 driver to remove the four 1.1 mm-long screws securing the front sensor connector cover.
  23. iPhone 12 Pro Max Screen Replacement, Remove the front sensor connector cover: stap 23, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Remove the front sensor connector cover: stap 23, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Remove the front sensor connector cover: stap 23, afbeelding 3 van 3
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  24. iPhone 12 Pro Max Screen Replacement, Disconnect the front sensors: stap 24, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Disconnect the front sensors: stap 24, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
    when lifting up the front sensor assembly cable connector, you should use the flat end of the spudger. Using the pointed end as shown in the picture runs the risk of damaging components on the board and/or the cable connector itself.
    Carter Taylor - Antwoord
  25. iPhone 12 Pro Max Screen Replacement, Remove the display assembly: stap 25, afbeelding 1 van 1
  26. iPhone 12 Pro Max Screen Replacement, Unscrew the speaker/sensor assembly: stap 26, afbeelding 1 van 1
    • Remove the four screws securing the speaker/sensor assembly to the back of the display.
    • Two 1.3 mm Phillips screws
    • One 1.8 mm shouldered Y000 screw
    • One 1.1 mm Y000 screw
  27. iPhone 12 Pro Max Screen Replacement, Flip the speaker assembly over: stap 27, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Flip the speaker assembly over: stap 27, afbeelding 2 van 2
    • The earpiece speaker is lightly adhered in place.
    • Use tweezers or the point of a spudger to gently pry up the top edge of the speaker.
    • Flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin ribbon cable. Be careful not to strain or damage the cable.
  28. iPhone 12 Pro Max Screen Replacement, Heat the top edge of the display: stap 28, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the display.
  29. iPhone 12 Pro Max Screen Replacement, Separate the ambient light sensor: stap 29, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Separate the ambient light sensor: stap 29, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Separate the ambient light sensor: stap 29, afbeelding 3 van 3
    • Use the point of a spudger to lift and separate the ambient light sensor from its notch in the front panel.
    • Take care not to damage the light sensor ribbon cables while prying.
    • Continue sliding the spudger underneath the ambient light sensor and its cable to separate the adhesive securing the cable.
  30. iPhone 12 Pro Max Screen Replacement, Pry up the microphone: stap 30, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Pry up the microphone: stap 30, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Pry up the microphone: stap 30, afbeelding 3 van 3
    • Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
  31. iPhone 12 Pro Max Screen Replacement, Pry up the proximity sensor and flood illuminator module: stap 31, afbeelding 1 van 2 iPhone 12 Pro Max Screen Replacement, Pry up the proximity sensor and flood illuminator module: stap 31, afbeelding 2 van 2
    • Use the point of a spudger to lift the proximity sensor and flood illuminator module out of its notch in the front panel.
  32. iPhone 12 Pro Max Screen Replacement, Remove the speaker and front sensor assembly: stap 32, afbeelding 1 van 3 iPhone 12 Pro Max Screen Replacement, Remove the speaker and front sensor assembly: stap 32, afbeelding 2 van 3 iPhone 12 Pro Max Screen Replacement, Remove the speaker and front sensor assembly: stap 32, afbeelding 3 van 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
Conclusie
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 12 Pro Max Answers community for troubleshooting help.
59 andere personen hebben deze handleiding voltooid.
Adam O'Camb
208.985 Reputatie
416 handleidingen geschreven
7 opmerkingen
Thank you so much. how can I order fixit kit. Please I would like to replace my screen as soon as I could.
dawadolma09 - Antwoord
We don’t have a fix kit available for this yet, but at the top of this guide you’ll find lists of the necessary parts and tools. Good luck with the screen replacement!
Adam O'Camb -
that's an excellent explanation thank you!
حيدر عباس مدب - Antwoord
If I accidentally cut the upper ribbon while removing the screen, which piece do in have to order as a replacement?
Danloebel - Antwoord
Really nice explanation! Easy to follow for Newbies and Pro's!
Andre Viermann - Antwoord
replaced screen and also transferred the screen serial number to the new screen but still lost touch sensitivity and other functions. Is this a common problem?
Christopher Martinez - Antwoord
Greetings, I have an iPhone 12 pro max that I need to change the screen because it is broken but my question is why do the replacements come with hooks in each corner if the original does not have them and it is very difficult for me to put in the new screen, what do I do?
Anna Robles - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 104
Afgelopen 7 dagen: 646
Afgelopen 30 dagen: 2,627
Altijd: 143,713
