Ga door naar hoofdinhoud
iPad mini 5 Wi-Fi Magnetic Sensor Replacement
Wat je nodig hebt
  1. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply tape to a cracked screen: stap 1, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply tape to a cracked screen: stap 1, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply tape to a cracked screen: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Opening Procedure: stap 2, afbeelding 1 van 1
  3. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 3, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 3, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 3, afbeelding 3 van 3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  4. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 4, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 4, afbeelding 2 van 2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 5, afbeelding 1 van 1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 6, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 6, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 6, afbeelding 3 van 3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 7, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 7, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 7, afbeelding 3 van 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 8, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 8, afbeelding 2 van 2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 9, afbeelding 1 van 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 10, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 10, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 10, afbeelding 3 van 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 11, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 11, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 11, afbeelding 3 van 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 12, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 12, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 12, afbeelding 3 van 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 13, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 13, afbeelding 2 van 2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 14, afbeelding 1 van 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  15. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 15, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 15, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 15, afbeelding 3 van 3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 16, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 16, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 16, afbeelding 3 van 3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 17, afbeelding 1 van 1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 18, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 18, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 18, afbeelding 3 van 3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 19, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 19, afbeelding 2 van 2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 20, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 20, afbeelding 2 van 2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 21, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 21, afbeelding 2 van 2
    • Slide the pick around the lower left edge of the iPad.
  22. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 22, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 22, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 22, afbeelding 3 van 3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 23, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 23, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 23, afbeelding 3 van 3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Hold the screen perpendicular: stap 24, afbeelding 1 van 1
    • To avoid stressing any cables, hold the screen perpendicular to the frame.
  25. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the display cable bracket: stap 25, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Continue to hold the screen perpendicular during this step.
    • Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
  26. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Reposition the screen: stap 26, afbeelding 1 van 1
    • You'll need to reposition the screen to access the bottom side of the display cable bracket.
    • Lower the screen to about 30 degrees above the frame.
  27. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Disconnect the battery: stap 27, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Disconnect the battery: stap 27, afbeelding 2 van 2
    • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
    • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
  28. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Rotate the display cable bracket: stap 28, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Rotate the display cable bracket: stap 28, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Rotate the display cable bracket: stap 28, afbeelding 3 van 3
    • The display cable bracket is secured by a clip under the edge of the frame.
    • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
    • Rotate the display cable bracket toward the battery.
    • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
  29. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Disconnect the display press connectors: stap 29, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Disconnect the display press connectors: stap 29, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
  30. iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 30, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 30, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement: stap 30, afbeelding 3 van 3
    • Use the pointed end of a spudger to disconnect the second and third display press connectors.
  31. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the screen: stap 31, afbeelding 1 van 1
    • Lift and remove the screen.
  32. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Screen reassembly information: stap 32, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Screen reassembly information: stap 32, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Screen reassembly information: stap 32, afbeelding 3 van 3
    • During reassembly, remove any remaining adhesive and residue from the perimeters of the frame and the screen. Then, apply new adhesive to secure the screen to the frame.
    • Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
    • Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
  33. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the magnetic sensor sticker: stap 33, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the magnetic sensor sticker: stap 33, afbeelding 2 van 2
    • Use a pair of tweezers to remove the sticker covering the magnetic sensor solder pads.
  34. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Desolder information: stap 34, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Desolder information: stap 34, afbeelding 2 van 2
    • In the next steps, you'll desolder the six solder pads securing the magnetic sensor to the screen.
  35. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply polyimide tape: stap 35, afbeelding 1 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply polyimide tape: stap 35, afbeelding 2 van 3 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply polyimide tape: stap 35, afbeelding 3 van 3
    • Apply polyimide tape to the area around the magnetic sensor solder pads to protect the components from heat.
  36. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Apply heat: stap 36, afbeelding 1 van 1
    • Use a soldering iron or hot air gun to apply heat evenly to the six magnetic sensor solder pads.
  37. iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the magnetic sensor cable: stap 37, afbeelding 1 van 2 iPad mini 5 Wi-Fi Magnetic Sensor Replacement, Remove the magnetic sensor cable: stap 37, afbeelding 2 van 2
    • When the solder on the solder pads is melted, use a pair of tweezers to separate the magnetic sensor from the screen.
    • If the solder isn't melted, apply more heat and try again.
    • When the area is cool enough to touch, remove the polyimide tape.
    • Use a pair of tweezers to remove the magnetic sensor cable.
    • The magnetic sensor cable is secured to the screen with light adhesive. Remove the magenetic sensor cable slowly to avoid damaging the cable under it.
    • During reassembly, apply a piece of polyimide tape under the solder pads while soldering the magnetic sensor to avoid damaging the screen.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
Kyle Smith
40.929 Reputatie
123 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 85
Altijd: 1,872
