Ga door naar hoofdinhoud
iPad Air 3 Power Button Cable Replacement
Wat je nodig hebt
  1. iPad Air 3 Power Button Cable Replacement, Prepare an iOpener: stap 1, afbeelding 1 van 1
    • Strong adhesive holds the screen in place. In order to separate it, you'll first need to heat and soften the adhesive using an iOpener, hair dryer, or heat gun.
    • You may need to reapply heat repeatedly throughout this process to prevent the adhesive from cooling and hardening.
    • Prepare an iOpener and place it on the bottom edge of the iPad's screen for about two minutes.
    Vraag FixBot
    Voeg opmerking toe
  2. iPad Air 3 Power Button Cable Replacement, Create an opening gap: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • If your iPad's screen is badly cracked, wear skin and eye protection. Cover the screen with a smooth layer of clear packing tape to contain glass shards and help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    • Place a suction cup next to the iPad's home button and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • If you want to use the Anti-Clamp, a tool we designed to make the opening procedure easier, follow this guide.
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Don't pull too hard, or you may shatter the glass. If necessary, apply more heat to further soften the adhesive.
    • Once you've opened a sufficient gap, insert an opening pick into the gap.
    Vraag FixBot
    Voeg opmerking toe
  3. iPad Air 3 Power Button Cable Replacement, Slice through the bottom adhesive: stap 3, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement, Slice through the bottom adhesive: stap 3, afbeelding 2 van 2
    • Slice through the adhesive under the screen by sliding the pick along the edge of the display, towards the bottom left corner.
    • Leave the pick in place temporarily to prevent the adhesive from re-sealing.
    Vraag FixBot
    Voeg opmerking toe
  4. iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: stap 4, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: stap 4, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement, Slice through the left adhesive: stap 4, afbeelding 3 van 3
    • Apply heat to the left edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • If necessary, re-heat your iOpener for a few seconds or until it's a bit too hot to touch. Be careful not to overheat the iOpener, or it may burst.
    • Insert a second opening pick at the bottom left corner of the iPad.
    • Slide the second opening pick along the left side of the display to separate the adhesive underneath.
    • Leave the opening pick inserted near the top left corner of the iPad to prevent the adhesive from re-sealing.
    Vraag FixBot
    Voeg opmerking toe
  5. iPad Air 3 Power Button Cable Replacement: stap 5, afbeelding 1 van 1
    • Apply heat to the top edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    Vraag FixBot
    Voeg opmerking toe
  6. iPad Air 3 Power Button Cable Replacement: stap 6, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 6, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 6, afbeelding 3 van 3
    • Insert a third opening pick at the top left corner of the iPad.
    • Use the opening pick to cut the adhesive under the top edge of the iPad by sliding it to the top right corner.
    • The front-facing camera is located right in the center of the iPad's top edge and can be damaged if the pick is inserted too far. Only insert the tip of the opening pick when cutting near the camera.
    Vraag FixBot
    Voeg opmerking toe
  7. iPad Air 3 Power Button Cable Replacement: stap 7, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 7, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 7, afbeelding 3 van 3
    • Apply heat to the final, right edge of the iPad for about two minutes, or until it's slightly too hot to touch comfortably.
    • Insert a fourth opening pick at the top right corner of the iPad.
    • Slide the opening pick down to the bottom right corner to cut the adhesive.
    • Slide the opening pick around the bottom right corner—pausing to apply more heat if needed—and cut the remaining adhesive on the bottom edge, but stop before you reach the home button.
    Vraag FixBot
    Voeg opmerking toe
  8. iPad Air 3 Power Button Cable Replacement: stap 8, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement: stap 8, afbeelding 2 van 2
    • Insert a fifth opening pick at the top of the iPad near (but not directly on) the front-facing camera.
    • Gently twist the pick to separate the display assembly from the iPad.
    • Don't try to remove the display all the way yet! It is still connected to the iPad's motherboard.
    • If needed, apply more heat and/or cut any remaining adhesive that prevents the display from separating.
    Vraag FixBot
    Voeg opmerking toe
  9. iPad Air 3 Power Button Cable Replacement: stap 9, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 9, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 9, afbeelding 3 van 3
    • Lift the display assembly from its top edge and carefully slide it up (towards the front-facing camera and headphone jack), until the screw that secures the battery power connector is revealed at the bottom.
    • Don't lift the display more than 70° or you may damage the attached ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  10. iPad Air 3 Power Button Cable Replacement: stap 10, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement: stap 10, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    • Remove the 1.9 mm Phillips screw that secures the battery power connector.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Vraag FixBot
    Voeg opmerking toe
  11. iPad Air 3 Power Button Cable Replacement, Battery connector information: stap 11, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement, Battery connector information: stap 11, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement, Battery connector information: stap 11, afbeelding 3 van 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Vraag FixBot
    Voeg opmerking toe
  12. iPad Air 3 Power Button Cable Replacement, Disconnect the battery: stap 12, afbeelding 1 van 1
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • To disconnect the battery, slide one prong of a battery blocker or the tip of an opening pick under the battery power connector to ensure the power circuit is interrupted.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages.
    • Leave the battery blocker in place as you work.
    Vraag FixBot
    Voeg opmerking toe
  13. iPad Air 3 Power Button Cable Replacement: stap 13, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 13, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 13, afbeelding 3 van 3
    • Slowly lift the display from its top edge, being careful not to strain the attached ribbon cables.
    • Remove the two 1.3 mm Phillips screws securing the display connector cover bracket.
    • You may need to angle the driver slightly in order to avoid straining the ribbon cables.
    • Remove the display connector cover bracket.
    Vraag FixBot
    Voeg opmerking toe
  14. iPad Air 3 Power Button Cable Replacement: stap 14, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 14, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 14, afbeelding 3 van 3
    • Use a spudger to disconnect the two visible display flex connectors by gently prying them straight up from their sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  15. iPad Air 3 Power Button Cable Replacement: stap 15, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 15, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 15, afbeelding 3 van 3
    • Underneath, you'll find two additional display cable connectors.
    • Use your spudger to gently pry them up and disconnect them.
    Vraag FixBot
    Voeg opmerking toe
  16. iPad Air 3 Power Button Cable Replacement: stap 16, afbeelding 1 van 1
    • Remove the display assembly.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • If you plan to reinstall your existing display, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
    Vraag FixBot
    Voeg opmerking toe
  17. iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket screws: stap 17, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 2.4 mm-long screws
    Vraag FixBot
    Voeg opmerking toe
  18. iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: stap 18, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: stap 18, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement, Free the upper component bracket: stap 18, afbeelding 3 van 3
    • Use a spudger to push the upper component bracket towards the upper edge and off of the clips located near the rear camera.
    Vraag FixBot
    Voeg opmerking toe
  19. iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket: stap 19, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement, Remove the upper component bracket: stap 19, afbeelding 2 van 2
    • Remove the upper component bracket.
    • During reassembly, make sure that the upper component bracket slides under the clips near the rear camera.
    Vraag FixBot
    Voeg opmerking toe
  20. iPad Air 3 Power Button Cable Replacement, Disconnect the power button assembly: stap 20, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement, Disconnect the power button assembly: stap 20, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the front camera cable by lifting straight up on the press connector.
    Vraag FixBot
    Voeg opmerking toe
  21. iPad Air 3 Power Button Cable Replacement, Remove the power button bracket screws: stap 21, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 4.3 mm-long screws securing the power button bracket to the rear case.
    Vraag FixBot
    Voeg opmerking toe
  22. iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: stap 22, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: stap 22, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement, Remove the power button assembly: stap 22, afbeelding 3 van 3
    • Use a pair of tweezers to peel the power button assembly away from the rear case.
    • The power button is loose and may fall out of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  23. iPad Air 3 Power Button Cable Replacement, Loosen the adhesive: stap 23, afbeelding 1 van 2 iPad Air 3 Power Button Cable Replacement, Loosen the adhesive: stap 23, afbeelding 2 van 2
    • Apply a heated iOpener to the power button assembly for thirty seconds.
    Vraag FixBot
    Voeg opmerking toe
  24. iPad Air 3 Power Button Cable Replacement, Remove the power button cable: stap 24, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement, Remove the power button cable: stap 24, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement, Remove the power button cable: stap 24, afbeelding 3 van 3
    • Grip the power button bracket with a pair of tweezers.
    • Use an opening pick or halberd spudger to peel the power button cable away from the bracket.
    Vraag FixBot
    Voeg opmerking toe
  25. iPad Air 3 Power Button Cable Replacement: stap 25, afbeelding 1 van 3 iPad Air 3 Power Button Cable Replacement: stap 25, afbeelding 2 van 3 iPad Air 3 Power Button Cable Replacement: stap 25, afbeelding 3 van 3
    • Use an opening pick or a halberd spudger to peel the power button cable away from the bracket.
    • Remove the power button cable.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
    • During reassembly, transfer the ambient light sensor gasket over to the new power button cable.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to attach the new cable to the power button bracket.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air 3 Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Robert Boyd
33.336 Reputatie
94 handleidingen geschreven
1Gids Commentaar
Will replacing this power button cable assembly also resolve the problem of the iPad Air 3rd gen not responding to a smart cover? If not, what part would need to be replaced? Thanks!
Ben - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 89
Altijd: 4,277
