Ga door naar hoofdinhoud
iPad 7 Battery Replacement
Wat je nodig hebt
  1. iPad 7 Battery Replacement, Heat the left edge: stap 1, afbeelding 1 van 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 Battery Replacement, Screen removal information: stap 2, afbeelding 1 van 3 iPad 7 Battery Replacement, Screen removal information: stap 2, afbeelding 2 van 3 iPad 7 Battery Replacement, Screen removal information: stap 2, afbeelding 3 van 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 Battery Replacement, Anti-Clamp instructions: stap 3, afbeelding 1 van 3 iPad 7 Battery Replacement, Anti-Clamp instructions: stap 3, afbeelding 2 van 3 iPad 7 Battery Replacement, Anti-Clamp instructions: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 Battery Replacement: stap 4, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 4, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 4, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 Battery Replacement: stap 5, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 5, afbeelding 2 van 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 Battery Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPad 7 Battery Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPad 7 Battery Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 7 Battery Replacement, Separate the left adhesive: stap 7, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the left adhesive: stap 7, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the left adhesive: stap 7, afbeelding 3 van 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 Battery Replacement: stap 8, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 8, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 8, afbeelding 3 van 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 Battery Replacement: stap 9, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 9, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 9, afbeelding 3 van 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 Battery Replacement, Heat the top edge: stap 10, afbeelding 1 van 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 7 Battery Replacement, Separate the top left adhesive: stap 11, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the top left adhesive: stap 11, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the top left adhesive: stap 11, afbeelding 3 van 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 7 Battery Replacement, Separate the top adhesive: stap 12, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the top adhesive: stap 12, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the top adhesive: stap 12, afbeelding 3 van 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 Battery Replacement: stap 13, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 13, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 13, afbeelding 3 van 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 Battery Replacement: stap 14, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 14, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 14, afbeelding 3 van 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 Battery Replacement, Heat the right edge: stap 15, afbeelding 1 van 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 Battery Replacement, Separate the top right adhesive: stap 16, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the top right adhesive: stap 16, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the top right adhesive: stap 16, afbeelding 3 van 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 Battery Replacement, Separate the right adhesive: stap 17, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the right adhesive: stap 17, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the right adhesive: stap 17, afbeelding 3 van 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 7 Battery Replacement, Heat the bottom edge: stap 18, afbeelding 1 van 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 Battery Replacement, Separate the bottom left adhesive: stap 19, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the bottom left adhesive: stap 19, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the bottom left adhesive: stap 19, afbeelding 3 van 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 Battery Replacement, Separate the bottom adhesive: stap 20, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the bottom adhesive: stap 20, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the bottom adhesive: stap 20, afbeelding 3 van 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 Battery Replacement: stap 21, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 21, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 21, afbeelding 3 van 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 7 Battery Replacement: stap 22, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 22, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 22, afbeelding 3 van 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 Battery Replacement, Heat the right edge: stap 23, afbeelding 1 van 1
  24. iPad 7 Battery Replacement: stap 24, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 24, afbeelding 2 van 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 Battery Replacement: stap 25, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 25, afbeelding 2 van 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 Battery Replacement, Separate the right adhesive: stap 26, afbeelding 1 van 3 iPad 7 Battery Replacement, Separate the right adhesive: stap 26, afbeelding 2 van 3 iPad 7 Battery Replacement, Separate the right adhesive: stap 26, afbeelding 3 van 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 Battery Replacement: stap 27, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 27, afbeelding 2 van 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 7 Battery Replacement, Remove the LCD: stap 28, afbeelding 1 van 2 iPad 7 Battery Replacement, Remove the LCD: stap 28, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    Koop
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 Battery Replacement, Flip the LCD over: stap 29, afbeelding 1 van 3 iPad 7 Battery Replacement, Flip the LCD over: stap 29, afbeelding 2 van 3 iPad 7 Battery Replacement, Flip the LCD over: stap 29, afbeelding 3 van 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 7 Battery Replacement, Disconnect the battery: stap 30, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the single 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 Battery Replacement, Battery connector information: stap 31, afbeelding 1 van 3 iPad 7 Battery Replacement, Battery connector information: stap 31, afbeelding 2 van 3 iPad 7 Battery Replacement, Battery connector information: stap 31, afbeelding 3 van 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 Battery Replacement, Disconnect the battery: stap 32, afbeelding 1 van 3 iPad 7 Battery Replacement, Disconnect the battery: stap 32, afbeelding 2 van 3 iPad 7 Battery Replacement, Disconnect the battery: stap 32, afbeelding 3 van 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 Battery Replacement, Remove the display cable bracket: stap 33, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 Battery Replacement: stap 34, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 34, afbeelding 2 van 2
    • Remove the display cable bracket.
  35. iPad 7 Battery Replacement, Disconnect the LCD: stap 35, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the LCD: stap 35, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 Battery Replacement: stap 36, afbeelding 1 van 1
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  37. iPad 7 Battery Replacement, Disconnect the home button: stap 37, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the home button: stap 37, afbeelding 2 van 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  38. iPad 7 Battery Replacement: stap 38, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 38, afbeelding 2 van 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  39. iPad 7 Battery Replacement: stap 39, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 39, afbeelding 2 van 2
    • Use a pair of tweezers to carefully pull the home button ribbon cable straight out of the ZIF connector.
  40. iPad 7 Battery Replacement, Disconnect the display cables: stap 40, afbeelding 1 van 3 iPad 7 Battery Replacement, Disconnect the display cables: stap 40, afbeelding 2 van 3 iPad 7 Battery Replacement, Disconnect the display cables: stap 40, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the two digitizer cables by lifting straight up on the press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  41. iPad 7 Battery Replacement, Remove the vibration isolator: stap 41, afbeelding 1 van 3 iPad 7 Battery Replacement, Remove the vibration isolator: stap 41, afbeelding 2 van 3 iPad 7 Battery Replacement, Remove the vibration isolator: stap 41, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  42. iPad 7 Battery Replacement: stap 42, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 42, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 42, afbeelding 3 van 3
    • Use a pair of tweezers to peel the home button cable away from the rear case.
    • The cable is secured with some light adhesive.
  43. iPad 7 Battery Replacement, Remove the front panel assembly: stap 43, afbeelding 1 van 3 iPad 7 Battery Replacement, Remove the front panel assembly: stap 43, afbeelding 2 van 3 iPad 7 Battery Replacement, Remove the front panel assembly: stap 43, afbeelding 3 van 3
    Polyimide Tape
    $9.99
    Koop
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  44. iPad 7 Battery Replacement, Eject the SIM card tray: stap 44, afbeelding 1 van 2 iPad 7 Battery Replacement, Eject the SIM card tray: stap 44, afbeelding 2 van 2
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press firmly to eject the SIM card tray.
  45. iPad 7 Battery Replacement: stap 45, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 45, afbeelding 2 van 2
    • Remove the SIM card tray from the iPad.
  46. iPad 7 Battery Replacement, Remove the upper component bracket: stap 46, afbeelding 1 van 2 iPad 7 Battery Replacement, Remove the upper component bracket: stap 46, afbeelding 2 van 2
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
  47. iPad 7 Battery Replacement: stap 47, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket.
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  48. iPad 7 Battery Replacement: stap 48, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 48, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 48, afbeelding 3 van 3
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
  49. iPad 7 Battery Replacement, Disconnect the front camera: stap 49, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the front camera: stap 49, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the front camera cable by lifting straight up on the press connector.
  50. iPad 7 Battery Replacement, Remove the front camera: stap 50, afbeelding 1 van 3 iPad 7 Battery Replacement, Remove the front camera: stap 50, afbeelding 2 van 3 iPad 7 Battery Replacement, Remove the front camera: stap 50, afbeelding 3 van 3
    • Use a spudger to lift the front camera out of its recess until you can grip it with your fingers.
    • Use the spudger to pull the adhesive foam pad away from the front camera.
  51. iPad 7 Battery Replacement: stap 51, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 51, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 51, afbeelding 3 van 3
    • Use a pair of tweezers to grip the front camera and rotate it to thread the cable through its slot in the rear case.
    • Remove the front camera.
  52. iPad 7 Battery Replacement, Disconnect the headphone jack: stap 52, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the headphone jack: stap 52, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the headphone jack by lifting straight up on the press connector.
  53. iPad 7 Battery Replacement: stap 53, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 53, afbeelding 2 van 2
    • Use a pair of tweezers to peel the headphone jack up from the logic board and fold the cable out of the way.
  54. iPad 7 Battery Replacement, Remove the right cellular antenna screws: stap 54, afbeelding 1 van 2 iPad 7 Battery Replacement, Remove the right cellular antenna screws: stap 54, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the cellular antennas to the rear case.
  55. iPad 7 Battery Replacement, Disconnect the cellular antennas: stap 55, afbeelding 1 van 3 iPad 7 Battery Replacement, Disconnect the cellular antennas: stap 55, afbeelding 2 van 3 iPad 7 Battery Replacement, Disconnect the cellular antennas: stap 55, afbeelding 3 van 3
    • Use the pointed end of a spudger to disconnect the right cellular antenna coaxial cable by prying up as close to the connector as possible.
    • Disconnect the left antenna cable.
  56. iPad 7 Battery Replacement: stap 56, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 56, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 56, afbeelding 3 van 3
    • Peel the left cellular antenna coaxial cable away from the rear case.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  57. iPad 7 Battery Replacement: stap 57, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 57, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 57, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect both cellular antennas by lifting straight up on their press connectors.
  58. iPad 7 Battery Replacement, Disconnect the rear camera: stap 58, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the rear camera: stap 58, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the rear camera by lifting straight up on the press connector.
  59. iPad 7 Battery Replacement, Disconnect the microphone assembly: stap 59, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the microphone assembly: stap 59, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the microphone assembly by lifting straight up on the press connector.
  60. iPad 7 Battery Replacement, Disconnect the button control cable: stap 60, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the button control cable: stap 60, afbeelding 2 van 2
  61. iPad 7 Battery Replacement: stap 61, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 61, afbeelding 2 van 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  62. iPad 7 Battery Replacement: stap 62, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 62, afbeelding 2 van 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
  63. iPad 7 Battery Replacement, Disconnect the Smart Cover sensor: stap 63, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the Smart Cover sensor: stap 63, afbeelding 2 van 2
    • Peel off any tape covering the Smart Cover sensor cable ZIF connector.
  64. iPad 7 Battery Replacement: stap 64, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 64, afbeelding 2 van 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Smart Cover sensor cable ZIF connector.
  65. iPad 7 Battery Replacement: stap 65, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 65, afbeelding 2 van 2
    • Use a pair of tweezers to carefully pull the Smart Cover sensor cable straight out of the ZIF connector.
  66. iPad 7 Battery Replacement, Disconnect the SIM card reader: stap 66, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the SIM card reader: stap 66, afbeelding 2 van 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the SIM card reader cable ZIF connector.
  67. iPad 7 Battery Replacement: stap 67, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 67, afbeelding 2 van 2
    • Use a pair of tweezers to carefully pull the SIM card reader cable straight out of the ZIF connector.
  68. iPad 7 Battery Replacement, Disconnect the antennas: stap 68, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the antennas: stap 68, afbeelding 2 van 2
    • Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
  69. iPad 7 Battery Replacement: stap 69, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 69, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 69, afbeelding 3 van 3
    • Peel up the right antenna cable.
  70. iPad 7 Battery Replacement, Disconnect the left antenna: stap 70, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the left antenna: stap 70, afbeelding 2 van 2
    • Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
  71. iPad 7 Battery Replacement: stap 71, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 71, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 71, afbeelding 3 van 3
    • Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
  72. iPad 7 Battery Replacement, Remove the vibration isolator: stap 72, afbeelding 1 van 3 iPad 7 Battery Replacement, Remove the vibration isolator: stap 72, afbeelding 2 van 3 iPad 7 Battery Replacement, Remove the vibration isolator: stap 72, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up the vibration isolator at the bottom left corner of the iPad.
    • Use a pair of tweezers to remove the vibration isolator.
  73. iPad 7 Battery Replacement, Disconnect the speakers: stap 73, afbeelding 1 van 3 iPad 7 Battery Replacement, Disconnect the speakers: stap 73, afbeelding 2 van 3 iPad 7 Battery Replacement, Disconnect the speakers: stap 73, afbeelding 3 van 3
    • Use a pair of tweezers, or your fingers, to peel up the tape covering the speaker connectors.
  74. iPad 7 Battery Replacement: stap 74, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 74, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 74, afbeelding 3 van 3
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on both the left and right speaker cable ZIF connectors.
  75. iPad 7 Battery Replacement: stap 75, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 75, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 75, afbeelding 3 van 3
    • Use a pair of tweezers to carefully pull the left and right speaker cables straight out of their respective ZIF connectors.
  76. iPad 7 Battery Replacement, Disconnect the Smart Connector: stap 76, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the Smart Connector: stap 76, afbeelding 2 van 2
    • Use the pointed end of a spudger to disconnect the Smart Connector coaxial cable by prying up as close to the connector as possible.
  77. iPad 7 Battery Replacement: stap 77, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 77, afbeelding 2 van 2
    • Use a pair of tweezers to disconnect the Smart Connector cable connector by lifting straight up.
  78. iPad 7 Battery Replacement: stap 78, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 78, afbeelding 2 van 2
    • Use a pair of tweezers to peel back the tape securing the Smart Connector cables to the rear case.
  79. iPad 7 Battery Replacement: stap 79, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 79, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 79, afbeelding 3 van 3
    • Peel the Smart Connector cables away from the rear case.
  80. iPad 7 Battery Replacement, Loosen the SIM card reader's adhesive: stap 80, afbeelding 1 van 1
    • Heat an iOpener and apply it to the bottom left corner of the rear case to soften the SIM card reader's adhesive for thirty seconds.
  81. iPad 7 Battery Replacement, Remove the SIM card reader: stap 81, afbeelding 1 van 2 iPad 7 Battery Replacement, Remove the SIM card reader: stap 81, afbeelding 2 van 2
    • Use an opening tool to pry up on the bottom edge of the SIM card reader with a slow and steady force.
    • If the SIM card reader feels extra stuck, apply more heat and try again.
  82. iPad 7 Battery Replacement: stap 82, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 82, afbeelding 2 van 2
    • Remove the SIM card reader.
  83. iPad 7 Battery Replacement, Disconnect the charging port: stap 83, afbeelding 1 van 2 iPad 7 Battery Replacement, Disconnect the charging port: stap 83, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 2.2 mm-long screws securing the charging port to the rear case.
    • Two 2.2 mm-long screws
    • Two 3.2 mm-long screws
  84. iPad 7 Battery Replacement, Loosen the adhesive: stap 84, afbeelding 1 van 3 iPad 7 Battery Replacement, Loosen the adhesive: stap 84, afbeelding 2 van 3 iPad 7 Battery Replacement, Loosen the adhesive: stap 84, afbeelding 3 van 3
    • Heat an iOpener and apply it to the bottom, top, and logic board side of the iPad for thirty seconds in each location.
  85. iPad 7 Battery Replacement, Separate the charging port cable's adhesive: stap 85, afbeelding 1 van 2 iPad 7 Battery Replacement, Separate the charging port cable's adhesive: stap 85, afbeelding 2 van 2
    • Insert an opening pick under the charging port cable near the logic board and slide it toward the charging port to slice the adhesive.
  86. iPad 7 Battery Replacement: stap 86, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 86, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 86, afbeelding 3 van 3
    • Insert an opening pick under the charging port cable near the charging port and slide it towards the logic board to cut the adhesive.
  87. iPad 7 Battery Replacement: stap 87, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 87, afbeelding 2 van 2
    • Pull the charging port out of its slot in the rear case.
  88. iPad 7 Battery Replacement, Remove the logic board: stap 88, afbeelding 1 van 3 iPad 7 Battery Replacement, Remove the logic board: stap 88, afbeelding 2 van 3 iPad 7 Battery Replacement, Remove the logic board: stap 88, afbeelding 3 van 3
    • Insert an opening pick under the upper arm of the logic board and slide it toward the logic board to cut the adhesive securing it to the rear case.
    • Leave the opening pick inserted to keep the adhesive from re-adhering.
  89. iPad 7 Battery Replacement: stap 89, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 89, afbeelding 2 van 2
    • Remove the battery blocker.
  90. iPad 7 Battery Replacement: stap 90, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 90, afbeelding 2 van 2
    • Insert an opening tool near the bottom of the logic board and pry up with a slow and steady force to peel it away from the rear case.
    • Bending or warping the logic board could lead to permanent damage. If the adhesive feels extra stubborn, apply more heat and try again.
    • Slide an opening pick underneath the bottom edge of the logic board to slice some of the adhesive if your logic board won't budge.
  91. iPad 7 Battery Replacement: stap 91, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 91, afbeelding 2 van 2
    • Insert an opening tool near the middle of the logic board and pry up with a slow and steady force to peel it away from the rear case.
  92. iPad 7 Battery Replacement: stap 92, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 92, afbeelding 2 van 2
    • Insert an opening tool near the top of the logic board and pry up with a slow and steady force to peel it away from the rear case.
  93. iPad 7 Battery Replacement: stap 93, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 93, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 93, afbeelding 3 van 3
    • Insert an opening tool near the middle of the logic board and pry up until you can grip it with your fingers.
  94. iPad 7 Battery Replacement: stap 94, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 94, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 94, afbeelding 3 van 3
    • Use a halberd spudger or an opening pick to slice any remaining adhesive securing the logic board to the rear case.
  95. iPad 7 Battery Replacement: stap 95, afbeelding 1 van 1
    Tesa 61395 Tape
    $5.99
    Koop
    • Remove the logic board.
    • During reassembly, ensure that there are no ribbon cables stuck under the logic board before gluing it down.
    • During reassembly, apply strips of Tesa tape if the original adhesive is too mangled to be reused.
  96. iPad 7 Battery Replacement, Protect the other components: stap 96, afbeelding 1 van 3 iPad 7 Battery Replacement, Protect the other components: stap 96, afbeelding 2 van 3 iPad 7 Battery Replacement, Protect the other components: stap 96, afbeelding 3 van 3
    • Before removing the battery, it's important to protect the other components in the rear case by covering them with tape.
    • Cut a strip of painter's tape or scotch tape to the width of the iPad.
    • Press the bottom edge of the tape strip onto the rear case above the speakers and bottom antennas.
    • Run your finger along the bottom edge of tape strip to ensure a good seal.
    • Press the top edge of the tape strip over the bottom components to keep any cables from intruding on the battery removal.
  97. iPad 7 Battery Replacement: stap 97, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 97, afbeelding 2 van 2
    • Cover the upper components with a strip of tape.
  98. iPad 7 Battery Replacement, Protect your eyes and skin: stap 98, afbeelding 1 van 2 iPad 7 Battery Replacement, Protect your eyes and skin: stap 98, afbeelding 2 van 2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover.
    • Do not wear contact lenses without eye protection.
    • Protective gloves are included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  99. iPad 7 Battery Replacement, Open the adhesive remover: stap 99, afbeelding 1 van 3 iPad 7 Battery Replacement, Open the adhesive remover: stap 99, afbeelding 2 van 3 iPad 7 Battery Replacement, Open the adhesive remover: stap 99, afbeelding 3 van 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  100. iPad 7 Battery Replacement, Adhesive location: stap 100, afbeelding 1 van 1
    • The red boxes show the locations of the adhesive strips that secure the battery to the rear case.
  101. iPad 7 Battery Replacement, Apply adhesive remover: stap 101, afbeelding 1 van 3 iPad 7 Battery Replacement, Apply adhesive remover: stap 101, afbeelding 2 van 3 iPad 7 Battery Replacement, Apply adhesive remover: stap 101, afbeelding 3 van 3
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the left edge of the battery.
  102. iPad 7 Battery Replacement: stap 102, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 102, afbeelding 2 van 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the bottom edge of the battery.
  103. iPad 7 Battery Replacement: stap 103, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 103, afbeelding 2 van 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol between the two battery cells.
  104. iPad 7 Battery Replacement: stap 104, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 104, afbeelding 2 van 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the right edge of the battery.
  105. iPad 7 Battery Replacement: stap 105, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 105, afbeelding 2 van 2
    • Apply a few drops of adhesive remover or high-concentration isopropyl alcohol along the upper edge of the battery.
  106. iPad 7 Battery Replacement, Cut the adhesive on the right edge: stap 106, afbeelding 1 van 2 iPad 7 Battery Replacement, Cut the adhesive on the right edge: stap 106, afbeelding 2 van 2
    Plastic Cards
    $2.99
    Koop
    • Insert a plastic card at the bottom right corner of the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • If at any point in this process the adhesive becomes very difficult to cut through, apply an iOpener to that area.
  107. iPad 7 Battery Replacement: stap 107, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 107, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 107, afbeelding 3 van 3
    • Slide the plastic card underneath the right edge to reach the center.
    • Insert the plastic card as far as you can under the battery to cut the adhesive.
    • Remove the plastic card.
  108. iPad 7 Battery Replacement: stap 108, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 108, afbeelding 2 van 2
    • Insert the plastic card below the battery connector as far as you can.
    • Leave the plastic card inserted.
  109. iPad 7 Battery Replacement: stap 109, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 109, afbeelding 2 van 2
    • Insert another plastic card above the battery connector as far as you can.
  110. iPad 7 Battery Replacement, Cut the adhesive on the bottom edge: stap 110, afbeelding 1 van 2 iPad 7 Battery Replacement, Cut the adhesive on the bottom edge: stap 110, afbeelding 2 van 2
    • Remove the plastic card below the battery connector and insert it under the bottom edge of the battery.
  111. iPad 7 Battery Replacement: stap 111, afbeelding 1 van 3 iPad 7 Battery Replacement: stap 111, afbeelding 2 van 3 iPad 7 Battery Replacement: stap 111, afbeelding 3 van 3
    • Slide the plastic card along the bottom edge of the battery to cut the adhesive strip.
    • When you reach the left corner of the bottom edge, insert the plastic card as far as you can.
  112. iPad 7 Battery Replacement, Cut the adhesive on the upper edge: stap 112, afbeelding 1 van 2 iPad 7 Battery Replacement, Cut the adhesive on the upper edge: stap 112, afbeelding 2 van 2
    • Remove the plastic card above the battery connector and insert it under the upper edge of the battery.
    • Slide the plastic card along the top edge of the battery to cut the adhesive strip.
    • If you're having trouble loosening the battery, apply some more adhesive remover, or apply a heated iOpener to the back case.
  113. iPad 7 Battery Replacement: stap 113, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 113, afbeelding 2 van 2
    • When you reach the left corner of the upper edge, insert the plastic card as far as you can.
  114. iPad 7 Battery Replacement, Cut the adhesive on the left edge: stap 114, afbeelding 1 van 3 iPad 7 Battery Replacement, Cut the adhesive on the left edge: stap 114, afbeelding 2 van 3 iPad 7 Battery Replacement, Cut the adhesive on the left edge: stap 114, afbeelding 3 van 3
    • Insert the plastic card under the upper left corner of the battery.
    • Slide the plastic card down towards the bottom of the iPad.
    • When you reach the center edge of the battery, insert the plastic card as far as you can to cut the central adhesive strip.
  115. iPad 7 Battery Replacement: stap 115, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 115, afbeelding 2 van 2
    • Insert the plastic card under the bottom left corner of the battery.
    • Slide the plastic card up towards the top of the iPad.
  116. iPad 7 Battery Replacement: stap 116, afbeelding 1 van 2 iPad 7 Battery Replacement: stap 116, afbeelding 2 van 2
    • When you reach the center edge, insert the plastic card as far as you can to cut the central adhesive strip.
  117. iPad 7 Battery Replacement, Remove the battery: stap 117, afbeelding 1 van 1
    Tesa 61395 Tape
    $10.99
    Koop
    • Remove the battery.
    • If you are still not able to remove the battery, repeat the process of cutting through the battery adhesive.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove the old battery adhesive from the rear case using tweezers and high concentration isopropyl alcohol with a lint-free cloth where needed.
    • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
    • Before installing the new battery, test it by first reinserting the logic board, connecting the button control cable ZIF connector, and the LCD press connector. Then remove the battery blocker and reinstall the battery connector screw. Power on the device to ensure it still works. Go backwards through this step and then glue down the battery.
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Robert Boyd
26.559 Reputatie
94 handleidingen geschreven
2 opmerkingen
I'm not 100% sure you guys know how to replace the battery.
There are more chances of damage by pulling that board with the soldered DC. And by the way you kind forgot to mention the silicone glue underneath the left side of the LCD screen, pull that lcd without breaking that silicone tape and you will be needing to add an new LCD screen to that battery replacement.
Miguel - Antwoord
Hi Miguel,
I'm not sure about the silicone glue holding the LCD that you're speaking of—we haven't encountered any in the multiple iPad 7s that we've disassembled.
We've considered multiple methods on how to take out the battery. Because of how the battery and logic board are glued down, each method has its pros and cons. The procedure we decided is much more involved (and prone to errors), but reduces the chance of flex damage to the logic board (which would be difficult to diagnose and repair).
Arthur Shi -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 175
Afgelopen 30 dagen: 754
Altijd: 15,416
