Ga door naar hoofdinhoud
Hp Pavilion dv6-2155dx USB Port Replacement
Engels
Nederlands
Stap 13
Hp Pavilion dv6-2155dx USB Port Replacement: stap 0, afbeelding 1 van 2 Hp Pavilion dv6-2155dx USB Port Replacement: stap 0, afbeelding 2 van 2
  • Starting in the front of the laptop, use a flat plastic spudger to gently pry the silver/chrome plastic bar off of the front of the laptop.
  • Once the silver/chrome bar is removed, the laptop cover should be loosened enough to remove.
  • You may need to pry along the sides of the laptop with the spudger if the laptop cover isn't loosened completely.
Vertaling hier toevoegen
