Inleiding
This guide will show you how to safely remove the USB ports in the laptop.
Wat je nodig hebt
Loosen the screws using Phillips #01 screwdriver with the extension attached.
Remove the six screws. Four are marked with a keyboard icons, two are located on the top corner.
Remove the three screws located in the battery port.
Flip the laptop over and locate the memory module panel and loosen the 3 screws holding down the panel.
Remove the panel to expose the 2 memory modules.
3 andere personen hebben deze handleiding voltooid.
