Ga door naar hoofdinhoud
Hp Pavilion dv6-2155dx USB Port Replacement
Engels
Nederlands
Stap 3
Hp Pavilion dv6-2155dx USB Port Replacement: stap 0, afbeelding 1 van 3 Hp Pavilion dv6-2155dx USB Port Replacement: stap 0, afbeelding 2 van 3 Hp Pavilion dv6-2155dx USB Port Replacement: stap 0, afbeelding 3 van 3
  • Locate the WLAN module located in the hard drive panel and remove the screw holding the WLAN module.
  • Disconnect the two WLAN antenna cables (white and black) attached to the WLAN module by gently lifting and holding onto the gold base.
  • The wires are numbered as "1" and "2". When reconnecting, connect the designated location notated by "J1" and "J2" on the module.
Vertaling hier toevoegen
