Ga door naar hoofdinhoud
MSI GS65 Stealth Thin 8RE RAM Replacement
Engels
Nederlands
Stap 3
MSI GS65 Stealth Thin 8RE RAM Replacement: stap 0, afbeelding 1 van 3 MSI GS65 Stealth Thin 8RE RAM Replacement: stap 0, afbeelding 2 van 3 MSI GS65 Stealth Thin 8RE RAM Replacement: stap 0, afbeelding 3 van 3
  • Gently unclasp and unplug the four connectors by first lifting the black locking bars of the ZIF connectors.
  • The black locking tables can be lifted by using something small such as a fingernail.
  • There may be black tape covering the ribbon cables that need to be removed.
  • Be gentle while dealing with ribbon connectors since if damaged will cause malfunction.
  • When reassembling, make sure that each ribbon connector is completely inserted before lowering the black tab.
Vertaling hier toevoegen
