Inleiding
Use this guide to replace the loudspeaker on your Xiaomi Poco F3.
You'll need replacement adhesive in order to complete this repair.
Wat je nodig hebt
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the eleven screws securing the motherboard cover:
Ten 3.4 mm-long screws
One 1.5 mm-long screw
Insert the tip of an opening pick under the bottom left edge of the motherboard cover.
Use the opening pick to lift up the motherboard cover and release the plastic clips that hold the cover in its place.
Use your fingers to lift up the motherboard cover to access the connector on the motherboard.
Use a spudger to disconnect the motherboard cover by prying the connector straight up from its socket at the motherboard.
Remove the motherboard cover.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left bottom edge of the Poco F3.
Press firmly to eject the tray.
Remove the SIM card tray from the phone.
Use a Phillips screwdriver to remove the seven 3.5 mm-long screws securing the loudspeaker.
Use a spudger to pry up and disconnect the black antenna cable from the motherboard.
Insert an opening pick between the frame and the top left of the loudspeaker.
Use the opening pick to pry up the loudspeaker by tilting it downwards.
Use a pair of tweezers or your fingers to remove the loudspeaker.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
