Shark Clean Sense HP102PET Sensor Replacement
Inleiding
Ga naar stap 1Use this guide to replace the sensor in your Shark Clean Sense HP102PET. The sensor allows the device to register whenever you use the LED touch screen feature.
Wat je nodig hebt
Unscrew the one 1.2 cm screw holding the grate at the top with a TR10 Torx screwdriver.
Use a prying tool to carefully pry along the outer edges to disengage the inner retaining clips.
Remove the grate.
Gently pull housing outwards, to where you can easily access the portion circled in the third picture.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
