Samsung Galaxy S6 Edge Rear Glass Replacement
Inleiding
Ga naar stap 1Use this guide to replace a damaged rear glass panel on your Samsung Galaxy S6 Edge, or remove it to access other components.
Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
This guide was performed on a Samsung Galaxy S6 (non Edge) but the procedure is exactly identical. Be sure that you buy S6 Edge adhesive, and that it matches the adhesive you pulled off of the rear glass, as it may differ from the adhesive shown in this guide.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
14 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Thanks for taking the time to make this guide
Hey Guys! I have found that if you squirt just a touch of 100% isopropyl alcohol at the bottom corner of iPhone, Samsung, etc. and can work enough of it in, that adhesive will instantly dissolve and allow you to get an opening to slide a pick under to slice the adhesive all the way around. The key is not use too much that it goes onto the screen causing delamination if you are removing a screen you plan to reuse. On the Ultra 21, that back glass is INCREDIBLY fragile especially at the edges plus the very extreme contouring of that glass, thus using alcohol all the way around to dissolve and loosen adhesive is the way to go, and preventing a shattered back glass. (Learned the hard way on my 1st one....doh.)
