Inleiding
Use this guide to remove or replace the screen on your Samsung Galaxy Note10.
Due to the Note10’s design, you will have to remove the back panel in order to disconnect the screen cable.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the back panel and the screen.
Wat je nodig hebt
Prepare an iOpener and apply it to the left edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the top edge of the phone for one minute.
Prepare an iOpener and apply it to the right edge of the phone for one minute.
Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen touch layer cable connector from the motherboard.
Prepare an iOpener and apply it to the left edge of the display for one minute.
Apply a suction cup to the heated edge of the display, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the display and the frame.
Prepare an iOpener and apply it to the bottom edge of the phone for one minute.
30 andere personen hebben deze handleiding voltooid.
8 opmerkingen
Does the same method apply to Note 10+ as well ?
The method is similar but not identical. We will have Note10+ guides up within this month!
Would the phone still be water resistant?
Depending on adhesive you use to put back glass
For anyone thinking about doing this -
The screen on my wife’s Note 10 cracked. She lived with it for a little while, but of course the cracks spread and got worse over time. We decided to take a stab at fixing it ourselves.
From what I can tell, the instructions here are spot on. I was eventually able to fix the phone myself - looks brand new. You definitely don’t have to be a rocket scientist to do this - just some patience while you go through the steps.
My one regret is that I tried using a heat gun to soften the adhesive. While her screen was cracked, the LED display was still working. After using the heat gun, the LED display was no longer working - so I had to order a new one (they’re not cheap). At the time, I did not know about the iOpener. I would be very curious to give it a try. As long as it provides enough heat, it would probably work a lot better due to the increased control in heat application. For the price, it’s probably worth giving it a shot if you’re planning on doing this.
