Ga door naar hoofdinhoud
Nintendo Switch Lite Motherboard Replacement
Wat je nodig hebt
  1. Nintendo Switch Lite Motherboard Replacement, Remove the back panel screws: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
    All my screws got stripped any ideas on how to remove?
    Almost A Mammal - Antwoord
    A Y0 screwdriver seemed to work better for me.
    Tommy Morrill - Antwoord
    What type of screw driver do I use to un screw the screws and which way
    Luca Capito - Antwoord
    Y 0.6 was all I had but it seemed to fit perfectly
    Trevor - Antwoord
    Like really snug? I've gotten away with using Drivers either bigger or smaller but I hate doing it. But if 0.6 is the exact size I need, then I'll get that. I don't wanna strip my client's Switch Lite's screws.
    Vincent Valodze -
  2. Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: stap 2, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Remove the top and bottom back panel screws: stap 2, afbeelding 2 van 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
    I accidentally stripped the back screw and now I can't open it. I removed all the other screws. What should I do?
    tiggytiger555 - Antwoord
  3. Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: stap 3, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Release the clips securing the back panel: stap 3, afbeelding 2 van 2
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  4. Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: stap 4, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Continue releasing the clips around the device: stap 4, afbeelding 2 van 2
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  5. Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: stap 5, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Twist to release the clips: stap 5, afbeelding 2 van 2
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  6. Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: stap 6, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Slide and pry around the corners: stap 6, afbeelding 2 van 2
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  7. Nintendo Switch Lite Motherboard Replacement: stap 7, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement, Remove the back panel: stap 8, afbeelding 3 van 3
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Nintendo Switch Lite Motherboard Replacement, Remove the shield plate: stap 9, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
    There are four screws instead of three mentioned
    Khurram Chaudry - Antwoord
    it doesnt mention 3 anywhere, and it labels all four
    Ezi - Antwoord
    With how easy it seems to be to do serious damage with the next few steps, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    Nate - Antwoord
    i stripped a &&^&^$^ screw
    SpongebobFan254 - Antwoord
    Well I actually removed the screw right next to the 4.5 screw. I did not realize it till my son showed me why the plate wouldn't release. Ha ha, it's funny now but yeah not a big deal. I could have bent it badly assuming I took all screws out though. For anyone reading this before going in. 👍
    Toastninja - Antwoord
  10. Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
    You may need to replace the thermal paste on the heat sink.
    ahoz28 - Antwoord
    What type of Thermal Paste would you guys recommend? I clicked on the picture but nothing.
    Vincent Valodze - Antwoord
    Personnaly i use some Mx-6 from Artic, really good quality/price, never have to complain.
    Nothing -
  11. Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: stap 11, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the battery: stap 11, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    The clip broke off when trying to remove this cable. Audio only works through headphones and the display now won’t turn on after the clip broke. Does anyone know where I could get a clip or how I could fix it without it?
    Alexz Zepeda - Antwoord
    Mi è successa la stessa cosa è non so come ripararla! Chissà se c’è un modo!
    Paolo De Falco -
  12. Nintendo Switch Lite Motherboard Replacement: stap 12, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Do Not Use Metal Tweezers! Some fixers state that metallic tweezers can short circuit the ribbon cable/connector. It might be safer to just use nylon-tipped or ceramic-tipped tweezers.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    I turned the unit off beforehand, I used tweezers just like the instructions said (ifixit branded) , my device sparked and now it won’t turn back on
    User Service - Antwoord
    The flap came off is it important or is there a way t fix it?
    Jose Cruz R Rangel Cordero - Antwoord
    We're you able to get it working without the white flap? My screen is not working after putting it back together and i noticed this white flap was falling off
    Jimmy “Ghost” Trost -
    Did you get it working without the white flap? Everything on the switch works fine except for audio going through headphones and the display not turning on.
    Alexz Zepeda -
    do not use metal sharp pointed tweezers! you will rip your ribbon cable. Use the inside of a Bic type pen or something else dull and plastic to pull the cable away by putting the pen part where the first bend is.
    Christopher Bales (C.J.) - Antwoord
    Anyone figure out how to fix this? my device shorted in this step.
    Acord - Antwoord
    Maybe tape the Tweezers or smear some hot glue on them to insulate them to save you time and money.
    Maybe put all the Warnings at the start of the guide as well. We fix it geeks tend to get excited when fixing things 😁
  13. Nintendo Switch Lite Motherboard Replacement: stap 13, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    Caution the connector may not be properly soldered onto the motherboard. For me it snapped off the pins and now have to find a place to get that fixed if even possible. may have bricked it.
    Craig Osman - Antwoord
    Yup, broke the connector right off the motherboard. Thanks, ifixit -_-
    Justin Kerr - Antwoord
    I backed out when I reached this point. I couldn't risk damaging it. Do u just need to pull it up? Did you mean that it might have been soldered shut below?
    Jannalyzer - Antwoord
    You should just need to pull straight up, but make sure you’re pulling on the wires or the gray plug—do not pull on the black socket or it can snap off of the motherboard.
    Adam O'Camb -
    I pulled straight up from the south side on under 2 or three wires and held down the device as I pulled and the gray connector disconnected from the black connector on the Switch. Just be careful at this part.
    Jon - Antwoord
    With how easy it seems to be to do serious damage at this point, I figured I'd say that realistically you can skip steps 9-13 when doing this repair. While they provide a bit of extra security by disconnecting the battery, the left stick is completely accessible and replaceable without touching the heat shield or anything underneath (And steps 17 and 18 disconnect power from the daughter board regardless).
    Nate - Antwoord
    just broke my connector... ifixit PLEASE put a warning on how fragile the solder on this connector is.
    Nate Mascis - Antwoord
    Note for this step, you do not need to apply a lot of force. I used two tools here: small screwdriver to hold down the black base, and one side of fine-tipped tweezers to get under all 3 wires. Gently, push down on the tweezers to push the wires upwards, which should force the gray connector up and off the base. It did not take a lot of force. Take your time and it will be fine. Again, like others have said, do NOT pull or pry up the black base.
    Christopher Gillett - Antwoord
  14. Nintendo Switch Lite Motherboard Replacement, Remove the heat sink: stap 14, afbeelding 1 van 1
    • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    When reassembling, the foam may fold down between the fan and heatsink, blocking airflow. Gently lift the foam back up on top of the fan. The adhesive film should hold the foam together.
    Kean Stump - Antwoord
    Is removing the heat sink absolutely necessary?
    Clark Aulden - Antwoord
    It’s not necessary, but it makes it much easier to remove and replace the game card reader, since the heat sink partially covers the connector.
    Craig Lloyd -
    Not really…….. I never remove it. It slides out quite easily once disconnected.
    Alan Sears - Antwoord
    What do you do if these screws are stripped? They strip easily
    Whatever - Antwoord
  15. Nintendo Switch Lite Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    Non le tre ventole ma le tre viti
    Cristiano Minchillo - Antwoord
    Grazie per avercelo segnalato! Ho apportato la modifica. iFixit è una wiki, quindi ogni utente può modificare le pagine: se trovi altri errori in futuro, sentiti libero di fare la modifica tu stesso!
    Sara Balestra -
  16. Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
    16.5 remove cartridge / headphones jack……….
    Calvin Martin - Antwoord
    I've read that there are different ways to apply thermal paste, which should I use?
    Kai B - Antwoord
    My kit did not come with thermal paste..
    Bryan Donovan - Antwoord
  17. Nintendo Switch Lite Motherboard Replacement, Remove the right trigger button assembly: stap 17, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
    I think a whole step to remove the game card reader and speaker jack was skipped here…
    ConfusedAzn Random - Antwoord
    yes, just found that sadly these comments do not show unless we click on the , which is unhelpful
    Micheal speed -
    also, you need to remove the left trigger button
    Micheal speed - Antwoord
  18. Nintendo Switch Lite Motherboard Replacement: stap 18, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Remove the right trigger button assembly.
  19. Nintendo Switch Lite Motherboard Replacement: stap 19, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
  20. Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement, Disconnect the antenna cables: stap 20, afbeelding 3 van 3
    • Use the point of a spudger to pry the black antenna cable straight up out of its socket on the motherboard.
    • Repeat the same process for the white antenna cable.
  21. Nintendo Switch Lite Motherboard Replacement, Disconnect the fan cable: stap 21, afbeelding 1 van 1
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
  22. Nintendo Switch Lite Motherboard Replacement: stap 22, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
    There’s a step missing after this to remove the screws that hold the orange game cartridge slot. Those 7 screws have to be undone and the ribbon unclipped first before moving on to the next step.
    Heather Thrasher - Antwoord
    Good Looking out!
    Joshua Hinchey -
  23. Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: stap 23, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the screen cable: stap 23, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
    skipped a step or two about removing the golden piece in the photo above, and the other little board
    Eddy Whitaker - Antwoord
    If I broke the clasp on the ZIF connector can I elec tape it down?
    kevin miller - Antwoord
    What did you do to fix it if the ZIF connector broke?? Mine did too and I worry that is why the screen won’t turn on now
    Amber Smith -
    Missing the card reader + audio jack board removal. Just remove the 4 screws around the audio jack + 3 screws around the card reader and disconnect the ZIF connector from the motherboard.
    Guillaume Turchini - Antwoord
  24. Nintendo Switch Lite Motherboard Replacement: stap 24, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
  25. Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: stap 25, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the digitizer cable: stap 25, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
    Can I electrical tape this down if I broke the clasp?
  26. Nintendo Switch Lite Motherboard Replacement: stap 26, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 26, afbeelding 2 van 2
    • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
  27. Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: stap 27, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Disconnect the right joystick cable: stap 27, afbeelding 2 van 2
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
  28. Nintendo Switch Lite Motherboard Replacement: stap 28, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 28, afbeelding 2 van 2
    • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
  29. Nintendo Switch Lite Motherboard Replacement, Remove the motherboard assembly: stap 29, afbeelding 1 van 1
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following six screws securing the motherboard:
    • Three 4.5 mm screws
    how to get the c port off
    Dustin Cronk - Antwoord
    When re-assembling, be sure the fan cable (step 25) is completely pulled through prior to tightening the screw that’s right next to it.
    John Glaeser - Antwoord
  30. Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 1 van 3 Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 2 van 3 Nintendo Switch Lite Motherboard Replacement: stap 30, afbeelding 3 van 3
    • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
    • Remove the motherboard assembly.
  31. Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: stap 31, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement, Remove the right speaker module: stap 31, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
    What is the little white piece called that the speak cable goes into
    Kieron Torrens - Antwoord
  32. Nintendo Switch Lite Motherboard Replacement: stap 32, afbeelding 1 van 2 Nintendo Switch Lite Motherboard Replacement: stap 32, afbeelding 2 van 2
    • Remove the right speaker module from the motherboard.
  33. Nintendo Switch Lite Motherboard Replacement: stap 33, afbeelding 1 van 1
    • Only the motherboard remains.
    Where do you buy the motherboard if you can buy it
    addser973 - Antwoord
    Yea where can i get a motherboard from?
    JoyBoy - Antwoord
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
22 andere personen hebben deze handleiding voltooid.
Craig Lloyd
38.614 Reputatie
82 handleidingen geschreven
7 opmerkingen
Great guide, helped me fix charge port replacement, did notice between 16-17 the card reader magically disappeared, but help me tear down and repair and rebuild with a little bit of head scratching.
Sean Topp - Antwoord
La guida è molto chiara.. ma dove si può acquistare una scheda madre di ricambio ?
Walter - Antwoord
It stops at motherboard removal, is there a section for replacing the USB charging port on the switch lite?
Christian Knight - Antwoord
Where can i get the motherboard from, i cant replace the charging port, cause it is soldered to the motherboard. So if you could please let me know onto where i can get the mother board from. 😊
JoyBoy - Antwoord
I have a working motherboard but it is missing one of the resistors (see the green square). How do I find out the value of this resistor? The resistor is situated to the left of the main chip, just below the microSD card slot, if the USB-C port is facing downward.
Christian Odom - Antwoord
Steps 17-19 from LCD replacement (removing game card reader) are missing from this guide.
Yan - Antwoord
"To reassemble your device, follow these instructions in reverse order." Got it all back together and never reinstalled the card reader because that part isn't in the instructions.
RJ K - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 36
Afgelopen 7 dagen: 228
Afgelopen 30 dagen: 1,108
Altijd: 53,321
