Ga door naar hoofdinhoud
Nintendo Switch 2 Battery Replacement
Wat je nodig hebt
  1. Nintendo Switch 2 Battery Replacement, Power off the console: stap 1, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Power off the console: stap 1, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Power off the console: stap 1, afbeelding 3 van 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo Switch 2 Battery Replacement, Remove the bottom screws: stap 2, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the bottom screws: stap 2, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo Switch 2 Battery Replacement, Remove the top screw: stap 3, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the top screw: stap 3, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo Switch 2 Battery Replacement, Heat the right side sticker: stap 4, afbeelding 1 van 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: stap 5, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: stap 5, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Pry up the right side sticker: stap 5, afbeelding 3 van 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo Switch 2 Battery Replacement: stap 6, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 6, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
    Vraag FixBot
    Voeg opmerking toe
  7. Nintendo Switch 2 Battery Replacement, Heat the right side sticker: stap 7, afbeelding 1 van 1
    • Reheat the bottom of the right side until it's hot to the touch.
    Vraag FixBot
    Voeg opmerking toe
  8. Nintendo Switch 2 Battery Replacement, Remove the right side sticker: stap 8, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Remove the right side sticker: stap 8, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Remove the right side sticker: stap 8, afbeelding 3 van 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
    Vraag FixBot
    Voeg opmerking toe
  9. Nintendo Switch 2 Battery Replacement, Remove the left side sticker: stap 9, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Remove the left side sticker: stap 9, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Remove the left side sticker: stap 9, afbeelding 3 van 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
    Vraag FixBot
    Voeg opmerking toe
  10. Nintendo Switch 2 Battery Replacement, Remove the side screws: stap 10, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the side screws: stap 10, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Vraag FixBot
    Voeg opmerking toe
  11. Nintendo Switch 2 Battery Replacement, Open the kickstand: stap 11, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Open the kickstand: stap 11, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Open the kickstand: stap 11, afbeelding 3 van 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
    Vraag FixBot
    Voeg opmerking toe
  12. Nintendo Switch 2 Battery Replacement, Remove the back-side screws: stap 12, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the back-side screws: stap 12, afbeelding 2 van 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
    Vraag FixBot
    Voeg opmerking toe
  13. Nintendo Switch 2 Battery Replacement, Insert an opening pick: stap 13, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Insert an opening pick: stap 13, afbeelding 2 van 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
    Vraag FixBot
    Voeg opmerking toe
  14. Nintendo Switch 2 Battery Replacement: stap 14, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 14, afbeelding 2 van 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
    Vraag FixBot
    Voeg opmerking toe
  15. Nintendo Switch 2 Battery Replacement, Insert a second opening pick: stap 15, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Insert a second opening pick: stap 15, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Insert a second opening pick: stap 15, afbeelding 3 van 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
    Vraag FixBot
    Voeg opmerking toe
  16. Nintendo Switch 2 Battery Replacement: stap 16, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 16, afbeelding 2 van 2
    • Slide the first opening pick back to where it was first inserted.
    Vraag FixBot
    Voeg opmerking toe
  17. Nintendo Switch 2 Battery Replacement, Remove the back cover: stap 17, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Remove the back cover: stap 17, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Remove the back cover: stap 17, afbeelding 3 van 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
    Vraag FixBot
    Voeg opmerking toe
  18. Nintendo Switch 2 Battery Replacement: stap 18, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 18, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 18, afbeelding 3 van 3
    • Lift the back cover up from the bottom edge and remove it.
    Vraag FixBot
    Voeg opmerking toe
  19. Nintendo Switch 2 Battery Replacement, Remove the lower antenna screws: stap 19, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the lower antenna screws: stap 19, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
    Vraag FixBot
    Voeg opmerking toe
  20. Nintendo Switch 2 Battery Replacement, Remove the lower antenna: stap 20, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the lower antenna: stap 20, afbeelding 2 van 2
    • Use tweezers or your fingers to remove the lower antenna.
    Vraag FixBot
    Voeg opmerking toe
  21. Nintendo Switch 2 Battery Replacement, Remove the upper antenna screws: stap 21, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the upper antenna screws: stap 21, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
    Vraag FixBot
    Voeg opmerking toe
  22. Nintendo Switch 2 Battery Replacement, Remove the upper antenna: stap 22, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the upper antenna: stap 22, afbeelding 2 van 2
    • Use tweezers or your fingers to remove the upper antenna.
    Vraag FixBot
    Voeg opmerking toe
  23. Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: stap 23, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: stap 23, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the lower antenna cable: stap 23, afbeelding 3 van 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
    Vraag FixBot
    Voeg opmerking toe
  24. Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: stap 24, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: stap 24, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the remaining antenna cables: stap 24, afbeelding 3 van 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
    Vraag FixBot
    Voeg opmerking toe
  25. Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: stap 25, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: stap 25, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Disconnect the MicroSD connector: stap 25, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
    Vraag FixBot
    Voeg opmerking toe
  26. Nintendo Switch 2 Battery Replacement, Remove the shield plate screws: stap 26, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the shield plate screws: stap 26, afbeelding 2 van 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
    Vraag FixBot
    Voeg opmerking toe
  27. Nintendo Switch 2 Battery Replacement, Lift the shield plate: stap 27, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Lift the shield plate: stap 27, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Lift the shield plate: stap 27, afbeelding 3 van 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
    Vraag FixBot
    Voeg opmerking toe
  28. Nintendo Switch 2 Battery Replacement: stap 28, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 28, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 28, afbeelding 3 van 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
    Vraag FixBot
    Voeg opmerking toe
  29. Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: stap 29, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: stap 29, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Unroute the gray antenna cable: stap 29, afbeelding 3 van 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
    Vraag FixBot
    Voeg opmerking toe
  30. Nintendo Switch 2 Battery Replacement: stap 30, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 30, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 30, afbeelding 3 van 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
    Vraag FixBot
    Voeg opmerking toe
  31. Nintendo Switch 2 Battery Replacement: stap 31, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 31, afbeelding 2 van 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
    Vraag FixBot
    Voeg opmerking toe
  32. Nintendo Switch 2 Battery Replacement, Remove the shield plate: stap 32, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Remove the shield plate: stap 32, afbeelding 2 van 2
    • Pick up and remove the shield plate.
    Vraag FixBot
    Voeg opmerking toe
  33. Nintendo Switch 2 Battery Replacement, Disconnect the battery: stap 33, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Disconnect the battery: stap 33, afbeelding 2 van 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
    Vraag FixBot
    Voeg opmerking toe
  34. Nintendo Switch 2 Battery Replacement, Weaken the adhesive: stap 34, afbeelding 1 van 1
    iFixit Adhesive Remover
    $19.99
    • Tilt the bottom edge of the console upward.
    • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol inside the battery well from its bottom cutout to weaken the adhesive.
    • Make sure not to puncture or scrape the bottom of the battery.
    • If you're using adhesive remover, follow these preparation steps first.
    • Hold the console upright for 1–2 minutes for the solvent to flow under the battery and weaken the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  35. Nintendo Switch 2 Battery Replacement, Lift the battery: stap 35, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Lift the battery: stap 35, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Lift the battery: stap 35, afbeelding 3 van 3
    • Don't bend the battery. If you see the battery bending, or if you're having difficulty prying, apply more solvent.
    • Insert the flat end of a spudger underneath the battery from the battery well cutout.
    • Slowly pry the battery up until its adhesive is fully separated from the frame. You can pry against the metal grille along the bottom edge of the console.
    Vraag FixBot
    Voeg opmerking toe
  36. Nintendo Switch 2 Battery Replacement, Remove the battery: stap 36, afbeelding 1 van 1
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  37. Nintendo Switch 2 Battery Replacement, Disassembly complete: stap 37, afbeelding 1 van 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Vraag FixBot
    Voeg opmerking toe
  38. Nintendo Switch 2 Battery Replacement, Clean the battery well: stap 38, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Clean the battery well: stap 38, afbeelding 2 van 2
    Cotton Swabs
    • Apply high-concentration (90% or higher) isopropyl alcohol to a cotton swab and wipe any adhesive residue from the battery well.
    • The foam on the inside walls of the well dissolves in isopropyl alcohol. Avoid touching the foam with your cotton swab so you don't damage it.
    Vraag FixBot
    Voeg opmerking toe
  39. Nintendo Switch 2 Battery Replacement, Transfer the foam: stap 39, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Transfer the foam: stap 39, afbeelding 2 van 2
    • If your new battery comes with foam pre-installed, skip the next two steps.
    • Use an opening pick or your fingernail to lift the foam strip off the top edge of the battery by its adhesive, not the foam itself.
    Vraag FixBot
    Voeg opmerking toe
  40. Nintendo Switch 2 Battery Replacement: stap 40, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 40, afbeelding 2 van 2
    • Peel the entire sticker, including the foam, from the front of the battery.
    Vraag FixBot
    Voeg opmerking toe
  41. Nintendo Switch 2 Battery Replacement: stap 41, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 41, afbeelding 2 van 2
    • Install the foam stickers in their original positions onto the new battery.
    Vraag FixBot
    Voeg opmerking toe
  42. Nintendo Switch 2 Battery Replacement, Prepare the adhesive: stap 42, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Prepare the adhesive: stap 42, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Prepare the adhesive: stap 42, afbeelding 3 van 3
    Tesa 61395 Tape
    $2.95
    • If your battery doesn't come with pre-installed adhesive, apply 5 mm‑wide strips of thin, double-sided tape to the flat area on the bottom of the battery. Don't install adhesive along the angled parts of the edges.
    • Remove all adhesive backings.
    Vraag FixBot
    Voeg opmerking toe
  43. Nintendo Switch 2 Battery Replacement, Install the new battery: stap 43, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the new battery: stap 43, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the new battery: stap 43, afbeelding 3 van 3
    • Align the battery with its well, ensuring the cable aligns with its cutout.
    • Carefully lower the battery into the frame.
    • Once the adhesive sticks on more than one side, don't try to lift and reposition the battery.
    • Gently press down on the battery for around 20 seconds to adhere it to the frame.
    Vraag FixBot
    Voeg opmerking toe
  44. Nintendo Switch 2 Battery Replacement, Connect the battery: stap 44, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Connect the battery: stap 44, afbeelding 2 van 2
    • Use your finger or the flat end of a spudger to press the flat-topped battery connector onto its socket until it's fully seated.
    Vraag FixBot
    Voeg opmerking toe
  45. Nintendo Switch 2 Battery Replacement, Clean the heat pipe: stap 45, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Clean the heat pipe: stap 45, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Clean the heat pipe: stap 45, afbeelding 3 van 3
    Arctic Silver ArctiClean
    $11.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
    Vraag FixBot
    Voeg opmerking toe
  46. Nintendo Switch 2 Battery Replacement, Apply thermal putty: stap 46, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Apply thermal putty: stap 46, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Apply thermal putty: stap 46, afbeelding 3 van 3
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
    Vraag FixBot
    Voeg opmerking toe
  47. Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: stap 47, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: stap 47, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Route the gray antenna cable: stap 47, afbeelding 3 van 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
    Vraag FixBot
    Voeg opmerking toe
  48. Nintendo Switch 2 Battery Replacement, Lower the shield plate: stap 48, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Lower the shield plate: stap 48, afbeelding 2 van 2
    • Lower the shield plate into place and align it with its screw holes.
    Vraag FixBot
    Voeg opmerking toe
  49. Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: stap 49, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: stap 49, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Finish routing the gray antenna cable: stap 49, afbeelding 3 van 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
    Vraag FixBot
    Voeg opmerking toe
  50. Nintendo Switch 2 Battery Replacement: stap 50, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 50, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 50, afbeelding 3 van 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
    Vraag FixBot
    Voeg opmerking toe
  51. Nintendo Switch 2 Battery Replacement, Install the shield plate screws: stap 51, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Install the shield plate screws: stap 51, afbeelding 2 van 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
    Vraag FixBot
    Voeg opmerking toe
  52. Nintendo Switch 2 Battery Replacement, Connect the MicroSD connector: stap 52, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Connect the MicroSD connector: stap 52, afbeelding 2 van 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Vraag FixBot
    Voeg opmerking toe
  53. Nintendo Switch 2 Battery Replacement, Connect the antenna cables: stap 53, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Connect the antenna cables: stap 53, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Connect the antenna cables: stap 53, afbeelding 3 van 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
    Vraag FixBot
    Voeg opmerking toe
  54. Nintendo Switch 2 Battery Replacement, Install the upper antenna: stap 54, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the upper antenna: stap 54, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the upper antenna: stap 54, afbeelding 3 van 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
    Vraag FixBot
    Voeg opmerking toe
  55. Nintendo Switch 2 Battery Replacement, Install the lower antenna: stap 55, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the lower antenna: stap 55, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the lower antenna: stap 55, afbeelding 3 van 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
    Vraag FixBot
    Voeg opmerking toe
  56. Nintendo Switch 2 Battery Replacement, Prepare the back cover: stap 56, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Prepare the back cover: stap 56, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Prepare the back cover: stap 56, afbeelding 3 van 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
    Vraag FixBot
    Voeg opmerking toe
  57. Nintendo Switch 2 Battery Replacement, Install the back cover: stap 57, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the back cover: stap 57, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the back cover: stap 57, afbeelding 3 van 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
    Vraag FixBot
    Voeg opmerking toe
  58. Nintendo Switch 2 Battery Replacement: stap 58, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement: stap 58, afbeelding 2 van 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
    Vraag FixBot
    Voeg opmerking toe
  59. Nintendo Switch 2 Battery Replacement, Install the back-side screws: stap 59, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the back-side screws: stap 59, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the back-side screws: stap 59, afbeelding 3 van 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
    Vraag FixBot
    Voeg opmerking toe
  60. Nintendo Switch 2 Battery Replacement, Install the side screws: stap 60, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Install the side screws: stap 60, afbeelding 2 van 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Vraag FixBot
    Voeg opmerking toe
  61. Nintendo Switch 2 Battery Replacement, Test the console: stap 61, afbeelding 1 van 2 Nintendo Switch 2 Battery Replacement, Test the console: stap 61, afbeelding 2 van 2
    • Power on the console and test functionality to ensure it's working as expected.
    Vraag FixBot
    Voeg opmerking toe
  62. Nintendo Switch 2 Battery Replacement, Install the stickers: stap 62, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement, Install the stickers: stap 62, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement, Install the stickers: stap 62, afbeelding 3 van 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
    Vraag FixBot
    Voeg opmerking toe
  63. Nintendo Switch 2 Battery Replacement: stap 63, afbeelding 1 van 3 Nintendo Switch 2 Battery Replacement: stap 63, afbeelding 2 van 3 Nintendo Switch 2 Battery Replacement: stap 63, afbeelding 3 van 3
    • Repeat this procedure to install the left side sticker.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
You finished fixing your Switch 2!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
3 andere personen hebben deze handleiding voltooid.
Nick Schultz
57.947 Reputatie
316 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 202
Afgelopen 7 dagen: 1,989
Afgelopen 30 dagen: 4,664
Altijd: 26,599
