Ga door naar hoofdinhoud
Joy-Con 2 (Left) Battery Replacement
Wat je nodig hebt
  1. Joy-Con 2 (Left) Battery Replacement, Remove the right edge screws: stap 1, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Remove the right edge screws: stap 1, afbeelding 2 van 2
    • Use a tri‑point Y00 driver to remove the two 3.1 mm‑long black screws on the right edge of the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. Joy-Con 2 (Left) Battery Replacement, Insert an opening pick: stap 2, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Insert an opening pick: stap 2, afbeelding 2 van 2
    • Insert an opening pick into the gap underneath the bumper button on the left side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the left edge of the controller.
    Vraag FixBot
    Voeg opmerking toe
  3. Joy-Con 2 (Left) Battery Replacement, Separate the plastic strip: stap 3, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Separate the plastic strip: stap 3, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Separate the plastic strip: stap 3, afbeelding 3 van 3
    • Slide the opening pick around to the front of the controller.
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
    Vraag FixBot
    Voeg opmerking toe
  4. Joy-Con 2 (Left) Battery Replacement, Remove the plastic strip: stap 4, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Remove the plastic strip: stap 4, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Remove the plastic strip: stap 4, afbeelding 3 van 3
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
    Vraag FixBot
    Voeg opmerking toe
  5. Joy-Con 2 (Left) Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the plastic strip.
    Vraag FixBot
    Voeg opmerking toe
  6. Joy-Con 2 (Left) Battery Replacement, Remove the left edge screws: stap 6, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Remove the left edge screws: stap 6, afbeelding 2 van 2
    • Remove the two screws on the left edge of the controller:
    • One 3.1 mm‑long tri‑point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
    Vraag FixBot
    Voeg opmerking toe
  7. Joy-Con 2 (Left) Battery Replacement, Insert an opening pick: stap 7, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Insert an opening pick: stap 7, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Insert an opening pick: stap 7, afbeelding 3 van 3
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its left side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's left edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
    Vraag FixBot
    Voeg opmerking toe
  8. Joy-Con 2 (Left) Battery Replacement, Insert a second opening pick: stap 8, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Insert a second opening pick: stap 8, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Insert a second opening pick: stap 8, afbeelding 3 van 3
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button at the top of the controller.
    • Use the opening pick to press the release button through the gap.
    Vraag FixBot
    Voeg opmerking toe
  9. Joy-Con 2 (Left) Battery Replacement, Release the back cover: stap 9, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Release the back cover: stap 9, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Release the back cover: stap 9, afbeelding 3 van 3
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
    Vraag FixBot
    Voeg opmerking toe
  10. Joy-Con 2 (Left) Battery Replacement, Remove the back cover: stap 10, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Remove the back cover: stap 10, afbeelding 2 van 2
    • Firmly grasp the two wires (blue and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  11. Joy-Con 2 (Left) Battery Replacement, Disconnect the battery: stap 11, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Disconnect the battery: stap 11, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Disconnect the battery: stap 11, afbeelding 3 van 3
    • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
    Vraag FixBot
    Voeg opmerking toe
  12. Joy-Con 2 (Left) Battery Replacement, Remove the release button: stap 12, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Remove the release button: stap 12, afbeelding 2 van 2
    • Pick up the release button and remove it.
    Vraag FixBot
    Voeg opmerking toe
  13. Joy-Con 2 (Left) Battery Replacement, Remove the battery: stap 13, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Remove the battery: stap 13, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Remove the battery: stap 13, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iFixit Adhesive Remover
    $19.99
    • Insert a flat edge of an opening pick into the gap between the battery and the battery well.
    • Pry the battery up slowly with steady force to release the adhesive.
    • Don't bend or crease the battery—apply steady force and give the adhesive time to release.
    • If it feels stubborn, apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the battery side of the pick while it's inserted and allow it to run under the battery. Be careful not to spill it elsewhere in the controller.
    • If you're using adhesive remover, follow these preparation steps first.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  14. Joy-Con 2 (Left) Battery Replacement, Disassembly complete: stap 14, afbeelding 1 van 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Vraag FixBot
    Voeg opmerking toe
  15. Joy-Con 2 (Left) Battery Replacement, Clean the frame: stap 15, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Clean the frame: stap 15, afbeelding 2 van 2
    Cotton Swabs
    • Apply isopropyl alcohol to a cotton swab and wipe any adhesive residue from the frame.
    • The foam on the inside walls of the frame dissolves in isopropyl alcohol. Avoid damaging the foam.
    Vraag FixBot
    Voeg opmerking toe
  16. Joy-Con 2 (Left) Battery Replacement, Transfer the foam: stap 16, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Transfer the foam: stap 16, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Transfer the foam: stap 16, afbeelding 3 van 3
    • If your replacement battery includes new foam, skip this step.
    • Slide an opening pick or fingernail between the foam and the battery, making sure it's completely below the foam's adhesive.
    • Carefully peel the foam sticker, including its adhesive, off the old battery. Avoid stretching or tearing the foam.
    • If the foam does tear, apply the pieces to the replacement battery in their original shape.
    • Apply the foam sticker to the new battery so the edges of the foam are aligned with the edges of the battery.
    Vraag FixBot
    Voeg opmerking toe
  17. Joy-Con 2 (Left) Battery Replacement, Install the battery: stap 17, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Install the battery: stap 17, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Install the battery: stap 17, afbeelding 3 van 3
    Tesa 61395 Tape
    $2.95
    • If your replacement battery came with adhesive pre-installed, peel off any adhesive liners.
    • If your replacement battery doesn't include new adhesive, use thin, double-sided tape instead. If you're using our pre-cut card, cut one of the 5 mm strips so it's half as long, and apply the strips to the back of the battery.
    • Align the battery with its housing. Ensure the battery cable lines up with its channel.
    • Lower one side of the battery, then the other, into its housing.
    • Press and hold on the battery for 10 seconds to bond the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  18. Joy-Con 2 (Left) Battery Replacement, Install the release button: stap 18, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Install the release button: stap 18, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Install the release button: stap 18, afbeelding 3 van 3
    • Hold the release button so its smooth face is perpendicular to the controller.
    • Insert the release button into its bracket.
    • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
    Vraag FixBot
    Voeg opmerking toe
  19. Joy-Con 2 (Left) Battery Replacement, Connect the battery: stap 19, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Connect the battery: stap 19, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Connect the battery: stap 19, afbeelding 3 van 3
    • Align the battery connector over its socket on the board.
    • Press down on the connector until it's fully seated.
    Vraag FixBot
    Voeg opmerking toe
  20. Joy-Con 2 (Left) Battery Replacement, Connect the rumble motor: stap 20, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Connect the rumble motor: stap 20, afbeelding 2 van 2
    • Align the rumble motor connector to its socket on the bottom edge of the board and push down until it's fully seated to connect it.
    Vraag FixBot
    Voeg opmerking toe
  21. Joy-Con 2 (Left) Battery Replacement, Install the back cover: stap 21, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Install the back cover: stap 21, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Install the back cover: stap 21, afbeelding 3 van 3
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cutout for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (blue & white) are fully within the frame.
    Vraag FixBot
    Voeg opmerking toe
  22. Joy-Con 2 (Left) Battery Replacement: stap 22, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement: stap 22, afbeelding 2 van 2
    • Remove the opening pick.
    Vraag FixBot
    Voeg opmerking toe
  23. Joy-Con 2 (Left) Battery Replacement, Install the left edge screws: stap 23, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Install the left edge screws: stap 23, afbeelding 2 van 2
    • Install the two screws on the left edge of the controller:
    Vraag FixBot
    Voeg opmerking toe
  24. Joy-Con 2 (Left) Battery Replacement, Install the plastic strip: stap 24, afbeelding 1 van 3 Joy-Con 2 (Left) Battery Replacement, Install the plastic strip: stap 24, afbeelding 2 van 3 Joy-Con 2 (Left) Battery Replacement, Install the plastic strip: stap 24, afbeelding 3 van 3
    • Align the clips on the plastic strip with their cut-outs on the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
    Vraag FixBot
    Voeg opmerking toe
  25. Joy-Con 2 (Left) Battery Replacement, Install the right edge screws: stap 25, afbeelding 1 van 2 Joy-Con 2 (Left) Battery Replacement, Install the right edge screws: stap 25, afbeelding 2 van 2
    • Use a tri‑point Y00 driver to install the two 3.1 mm‑long black screws on the right edge of the controller.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
You finished fixing your Joy-Con 2!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
Nick Schultz
58.004 Reputatie
316 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 73
Afgelopen 30 dagen: 327
Altijd: 2,752
