Ga door naar hoofdinhoud
Motorola Edge Midframe Replacement
Wat je nodig hebt
  1. Motorola Edge Midframe Replacement, Find the SIM tray: stap 1, afbeelding 1 van 1
    • Find the SIM tray located at the top of the phone.
  2. Motorola Edge Midframe Replacement, Eject the SIM tray: stap 2, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Eject the SIM tray: stap 2, afbeelding 2 van 2
    • Insert a SIM eject tool or SIM eject bit into the small hole in the SIM card tray.
    • If the tool you're using doesn't fit, don't force it. Forcing a tool may cause it to get stuck or break inside the ejection port.
    • Press to eject the tray.
  3. Motorola Edge Midframe Replacement, Remove the SIM card tray assembly: stap 3, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the SIM card tray assembly: stap 3, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the SIM card tray assembly: stap 3, afbeelding 3 van 3
    • Remove the SIM card tray from the phone.
  4. Motorola Edge Midframe Replacement, Heat the bottom edge: stap 4, afbeelding 1 van 1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  5. Motorola Edge Midframe Replacement, Separate the bottom adhesive: stap 5, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Separate the bottom adhesive: stap 5, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Separate the bottom adhesive: stap 5, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  6. Motorola Edge Midframe Replacement, Slice the bottom adhesive: stap 6, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Slice the bottom adhesive: stap 6, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Slice the bottom adhesive: stap 6, afbeelding 3 van 3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  7. Motorola Edge Midframe Replacement, Heat the right edge: stap 7, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge Midframe Replacement, Separate the corner adhesive: stap 8, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Separate the corner adhesive: stap 8, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Separate the corner adhesive: stap 8, afbeelding 3 van 3
    • Rotate the opening pick around the bottom-right corner of the phone.
  9. Motorola Edge Midframe Replacement, Separate the right adhesive: stap 9, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Separate the right adhesive: stap 9, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Separate the right adhesive: stap 9, afbeelding 3 van 3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  10. Motorola Edge Midframe Replacement, Remove the back cover: stap 10, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the back cover: stap 10, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the back cover: stap 10, afbeelding 3 van 3
    • Remove the back cover, taking care not to damage the components inside the phone.
  11. Motorola Edge Midframe Replacement, Remove the motherboard's screws: stap 11, afbeelding 1 van 1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  12. Motorola Edge Midframe Replacement, Remove the motherboard cover: stap 12, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the motherboard cover: stap 12, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the motherboard cover: stap 12, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  13. Motorola Edge Midframe Replacement, Disconnect the battery cable's press connector: stap 13, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the battery cable's press connector: stap 13, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Motorola Edge Midframe Replacement, Remove the daughterboard's t5 screws: stap 14, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Remove the daughterboard's t5 screws: stap 14, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  15. Motorola Edge Midframe Replacement, Remove the daughterboard cover: stap 15, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the daughterboard cover: stap 15, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the daughterboard cover: stap 15, afbeelding 3 van 3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
  16. Motorola Edge Midframe Replacement, Disconnect the interconnect cable from the motherboard: stap 16, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the interconnect cable from the motherboard: stap 16, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  17. Motorola Edge Midframe Replacement, Disconnect the interconnect cable from the daughterboard: stap 17, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the interconnect cable from the daughterboard: stap 17, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  18. Motorola Edge Midframe Replacement, Remove the interconnect cable: stap 18, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Remove the interconnect cable: stap 18, afbeelding 2 van 2
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
  19. Motorola Edge Midframe Replacement, Remove the copper tape: stap 19, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the copper tape: stap 19, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the copper tape: stap 19, afbeelding 3 van 3
    Koop
    • Use a pair of blunt tweezers to peel up and remove the copper tape covering the front camera ribbon cable.
  20. Motorola Edge Midframe Replacement, Remove the front camera cable's press connector: stap 20, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the front camera cable's press connector: stap 20, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the front camera cable's press connector: stap 20, afbeelding 3 van 3
    • Use a spudger to pry up the front camera cable's press connector and disconnect it from the motherboard.
    • Remove the front camera.
  21. Motorola Edge Midframe Replacement, Remove the wide angle camera's press connector: stap 21, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the wide angle camera's press connector: stap 21, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the wide angle camera's press connector: stap 21, afbeelding 3 van 3
    • Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
    • Remove the wide angle camera.
  22. Motorola Edge Midframe Replacement, Remove the main camera cable's press connector: stap 22, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the main camera cable's press connector: stap 22, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the main camera cable's press connector: stap 22, afbeelding 3 van 3
    • Use a spudger to pry up the main camera cable's press connector and disconnect it from the motherboard.
    • Remove the main camera.
  23. Motorola Edge Midframe Replacement, Remove the telephoto camera's press connector: stap 23, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the telephoto camera's press connector: stap 23, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the telephoto camera's press connector: stap 23, afbeelding 3 van 3
    • Use a spudger to pry up and disconnect the telephoto camera cable's press connector from the motherboard.
    • Remove the telephoto camera.
  24. Motorola Edge Midframe Replacement, Disconnect the screen ribbon cable's press connector: stap 24, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the screen ribbon cable's press connector: stap 24, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the screen ribbon cable's press connector from the motherboard.
  25. Motorola Edge Midframe Replacement, Disconnect the black coaxial cable: stap 25, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the black coaxial cable: stap 25, afbeelding 2 van 2
    • Use a spudger to pry up the black coaxial cable and detach it from the motherboard.
  26. Motorola Edge Midframe Replacement, Disconnect the white coaxial cable: stap 26, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the white coaxial cable: stap 26, afbeelding 2 van 2
    • Use a spudger to pry up the white coaxial cable and detach it from the motherboard.
  27. Motorola Edge Midframe Replacement, Remove the motherboard: stap 27, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the motherboard: stap 27, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the motherboard: stap 27, afbeelding 3 van 3
    • Use a spudger to pry up and remove the motherboard.
    • Make sure no cables get trapped under the motherboard during reassembly.
  28. Motorola Edge Midframe Replacement, Weaken the earpiece speaker's adhesive: stap 28, afbeelding 1 van 1
    • Apply a drop or two of isopropyl alcohol to weaken the adhesive securing the earpiece speaker.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive.
    • The adhesive is located both under the ribbon cable and under the earpiece speaker.
  29. Motorola Edge Midframe Replacement, Disconnect the earpiece speaker cable: stap 29, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Disconnect the earpiece speaker cable: stap 29, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Disconnect the earpiece speaker cable: stap 29, afbeelding 3 van 3
    • Use an opening pick to disconnect the earpiece speaker cable from the midframe.
  30. Motorola Edge Midframe Replacement, Remove the earpiece speaker: stap 30, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the earpiece speaker: stap 30, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the earpiece speaker: stap 30, afbeelding 3 van 3
    • Pry at the edge of the earpiece speaker with a spudger to detach it from the frame.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing the earpiece speaker.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the earpiece speaker.
  31. Motorola Edge Midframe Replacement, Disconnect the fingerprint sensor cable's press connector: stap 31, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the fingerprint sensor cable's press connector: stap 31, afbeelding 2 van 2
    • Use a spudger to pry up the fingerprint sensor cable's press connector and disconnect it from the daughterboard.
  32. Motorola Edge Midframe Replacement, Remove the daughterboard screw: stap 32, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Remove the daughterboard screw: stap 32, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the single 3.2 mm screw securing the daughterboard.
  33. Motorola Edge Midframe Replacement, Disconnect the black coaxial cable: stap 33, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the black coaxial cable: stap 33, afbeelding 2 van 2
    • Use a spudger to pry up the black coaxial cable and detach it from the daughterboard.
  34. Motorola Edge Midframe Replacement, Disconnect the white coaxial cable: stap 34, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Disconnect the white coaxial cable: stap 34, afbeelding 2 van 2
    • Use a spudger to pry up the white coaxial cable and disconnect it from the daughterboard.
  35. Motorola Edge Midframe Replacement, Remove the daughterboard: stap 35, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the daughterboard: stap 35, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the daughterboard: stap 35, afbeelding 3 van 3
    • Use a spudger to pry up and separate the daughterboard from the rest of the phone.
    • When removing and replacing the daughterboard, be careful not to damage any of the cables that attach to it.
  36. Motorola Edge Midframe Replacement, Weaken the vibrator's adhesive: stap 36, afbeelding 1 van 1
    • Use a drop or two of isopropyl alcohol to weaken the adhesive attaching the vibrator to the phone's frame.
    • Wait thirty seconds for the isopropyl alcohol to weaken the adhesive under the vibrator.
  37. Motorola Edge Midframe Replacement, Detach the vibrator's ribbon cable: stap 37, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Detach the vibrator's ribbon cable: stap 37, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Detach the vibrator's ribbon cable: stap 37, afbeelding 3 van 3
    • Use an opening pick to carefully separate the vibrator's ribbon cable from the frame of the phone.
  38. Motorola Edge Midframe Replacement, Remove the vibrator: stap 38, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the vibrator: stap 38, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the vibrator: stap 38, afbeelding 3 van 3
    • Use a spudger to carefully separate and remove the vibrator.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing the vibrator.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the vibrator.
  39. Motorola Edge Midframe Replacement, Weaken the battery's adhesive: stap 39, afbeelding 1 van 1
    • Heat an iOpener and place it on the screen for two minutes in order to loosen the adhesive on the battery.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  40. Motorola Edge Midframe Replacement, Create a gap between the battery and the frame: stap 40, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Create a gap between the battery and the frame: stap 40, afbeelding 2 van 2
    • Wedge the pointed end of an opening pick between the right side of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Be careful not to damage the screen's ribbon cable, which is located underneath the battery.
  41. Motorola Edge Midframe Replacement, Switch to a plastic card: stap 41, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Switch to a plastic card: stap 41, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Switch to a plastic card: stap 41, afbeelding 3 van 3
    Plastic Cards
    $2.99
    Koop
    • After making a gap between the battery and the frame, replace the opening pick with a plastic card.
    • A plastic card will help ensure that the battery is not bent or damaged while being removed.
  42. Motorola Edge Midframe Replacement, Cut through the battery's adhesive: stap 42, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Cut through the battery's adhesive: stap 42, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Cut through the battery's adhesive: stap 42, afbeelding 3 van 3
    • Carefully slide a plastic card underneath the battery to cut through the adhesive.
  43. Motorola Edge Midframe Replacement, Remove the battery: stap 43, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the battery: stap 43, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the battery: stap 43, afbeelding 3 van 3
    • Slide a plastic card under the battery, then carefully lift the battery up until the adhesive is loose enough to remove the battery.
  44. Motorola Edge Midframe Replacement: stap 44, afbeelding 1 van 3 Motorola Edge Midframe Replacement: stap 44, afbeelding 2 van 3 Motorola Edge Midframe Replacement: stap 44, afbeelding 3 van 3
    • Separate and remove the battery from the midframe.
    • If the battery is deformed, dented, or damaged in any way, don't reinstall it. Reinstalling a damaged battery is a potential safety hazard. Replace it with a new one.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to reinstall the battery.
  45. Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 45, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 45, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 45, afbeelding 3 van 3
    • Insert the pointed end of a spudger behind the red microphone gasket at the top of the midframe.
    • There is a small hole in the microphone gasket. You can gently place the spudger in the hole to help remove the gasket from the midframe.
  46. Motorola Edge Midframe Replacement, Remove the microphone gasket: stap 46, afbeelding 1 van 1
    • Use a spudger to dislodge and remove the red microphone gasket from the top of the midframe.
  47. Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 47, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 47, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Wedge a spudger behind the microphone gasket: stap 47, afbeelding 3 van 3
    • Insert the pointed end of a spudger behind the red microphone gasket at the bottom of the midframe.
  48. Motorola Edge Midframe Replacement, Remove the microphone gasket: stap 48, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the microphone gasket: stap 48, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the microphone gasket: stap 48, afbeelding 3 van 3
    • Insert the pointed end of a spudger behind the microphone gasket at the bottom of the midframe.
  49. Motorola Edge Midframe Replacement, Remove the midframe: stap 49, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Remove the midframe: stap 49, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Remove the midframe: stap 49, afbeelding 3 van 3
    • Turn the phone over and remove the midframe while gently threading the screen ribbon cable through the opening in the midframe.
  50. Motorola Edge Midframe Replacement, Weaken the fingerprint sensor's adhesive: stap 50, afbeelding 1 van 1
    • Use a drop or two of isopropyl alcohol to weaken the fingerprint sensor's adhesive.
  51. Motorola Edge Midframe Replacement, Disconnect the fingerprint sensor cable: stap 51, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Disconnect the fingerprint sensor cable: stap 51, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Disconnect the fingerprint sensor cable: stap 51, afbeelding 3 van 3
    • Use an opening pick to carefully separate the fingerprint sensor cable from the midframe.
  52. Motorola Edge Midframe Replacement, Thread the fingerprint sensor cable: stap 52, afbeelding 1 van 3 Motorola Edge Midframe Replacement, Thread the fingerprint sensor cable: stap 52, afbeelding 2 van 3 Motorola Edge Midframe Replacement, Thread the fingerprint sensor cable: stap 52, afbeelding 3 van 3
    • Turn the phone over, then carefully thread the the fingerprint sensor cable through the opening in the midframe.
  53. Motorola Edge Midframe Replacement: stap 53, afbeelding 1 van 3 Motorola Edge Midframe Replacement: stap 53, afbeelding 2 van 3 Motorola Edge Midframe Replacement: stap 53, afbeelding 3 van 3
    • Carefully finish separating the fingerprint sensor from the midframe.
    • Remove the fingerprint sensor.
  54. Motorola Edge Midframe Replacement, Separate the midframe: stap 54, afbeelding 1 van 2 Motorola Edge Midframe Replacement, Separate the midframe: stap 54, afbeelding 2 van 2
    • Once the fingerprint sensor has been removed, the midframe is ready to be replaced.
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Jennifer Berg
2.655 Reputatie
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 248
