Ga door naar hoofdinhoud
Motorola Edge (2022) Vibration Motor Replacement
Wat je nodig hebt
  1. Motorola Edge (2022) Vibration Motor Replacement, Remove the SIM card tray: stap 1, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement, Remove the SIM card tray: stap 1, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement, Remove the SIM card tray: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the sim card tray hole to eject the SIM card tray.
    • Use your fingers or tweezers to remove the SIM card tray.
  2. Motorola Edge (2022) Vibration Motor Replacement, Heat the right edge: stap 2, afbeelding 1 van 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Edge (2022) Vibration Motor Replacement, Separate the right adhesive: stap 3, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement, Separate the right adhesive: stap 3, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement, Separate the right adhesive: stap 3, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  4. Motorola Edge (2022) Vibration Motor Replacement, Slice the right adhesive: stap 4, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Slice the right adhesive: stap 4, afbeelding 2 van 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  5. Motorola Edge (2022) Vibration Motor Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  6. Motorola Edge (2022) Vibration Motor Replacement, Slice the bottom right corner adhesive: stap 6, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Slice the bottom right corner adhesive: stap 6, afbeelding 2 van 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  7. Motorola Edge (2022) Vibration Motor Replacement: stap 7, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 7, afbeelding 2 van 2
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  8. Motorola Edge (2022) Vibration Motor Replacement: stap 8, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  9. Motorola Edge (2022) Vibration Motor Replacement: stap 9, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 9, afbeelding 2 van 2
    • Rotate the pick around the bottom left corner to slice the adhesive.
  10. Motorola Edge (2022) Vibration Motor Replacement: stap 10, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 10, afbeelding 2 van 2
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  11. Motorola Edge (2022) Vibration Motor Replacement: stap 11, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  12. Motorola Edge (2022) Vibration Motor Replacement: stap 12, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 12, afbeelding 2 van 2
    • Rotate the pick around the top left corner to slice the adhesive.
  13. Motorola Edge (2022) Vibration Motor Replacement: stap 13, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 13, afbeelding 2 van 2
    • Slide the pick along the top edge to slice the adhesive.
  14. Motorola Edge (2022) Vibration Motor Replacement, Remove the back cover: stap 14, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Remove the back cover: stap 14, afbeelding 2 van 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
  15. Motorola Edge (2022) Vibration Motor Replacement, Separate the camera bezel adhesive: stap 15, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Separate the camera bezel adhesive: stap 15, afbeelding 2 van 2
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
  16. Motorola Edge (2022) Vibration Motor Replacement: stap 16, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 16, afbeelding 2 van 2
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
  17. Motorola Edge (2022) Vibration Motor Replacement, Remove the camera bezel: stap 17, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Remove the camera bezel: stap 17, afbeelding 2 van 2
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
  18. Motorola Edge (2022) Vibration Motor Replacement, Detach the left wireless charging coil tape: stap 18, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Detach the left wireless charging coil tape: stap 18, afbeelding 2 van 2
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
  19. Motorola Edge (2022) Vibration Motor Replacement, Detach the right wireless charging coil tape: stap 19, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Detach the right wireless charging coil tape: stap 19, afbeelding 2 van 2
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
  20. Motorola Edge (2022) Vibration Motor Replacement: stap 20, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 20, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 10 4 mm screws securing the motherboard cover.
  21. Motorola Edge (2022) Vibration Motor Replacement: stap 21, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 21, afbeelding 2 van 2
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
  22. Motorola Edge (2022) Vibration Motor Replacement: stap 22, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 22, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 22, afbeelding 3 van 3
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  23. Motorola Edge (2022) Vibration Motor Replacement, Remove the motherboard cover: stap 23, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement, Remove the motherboard cover: stap 23, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement, Remove the motherboard cover: stap 23, afbeelding 3 van 3
    • Slowly pull the motherboard cover up and away from the phone and remove it.
  24. Motorola Edge (2022) Vibration Motor Replacement, Move the graphite film: stap 24, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Move the graphite film: stap 24, afbeelding 2 van 2
    • Use your fingers to move the graphite film that covers the battery out of the way.
  25. Motorola Edge (2022) Vibration Motor Replacement, Disconnect the battery: stap 25, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Disconnect the battery: stap 25, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  26. Motorola Edge (2022) Vibration Motor Replacement, Unfasten the daughterboard cover: stap 26, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Unfasten the daughterboard cover: stap 26, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the five screws securing the daughterboard cover:
    • Four 4.1 mm screws
    • One 3 mm screw
  27. Motorola Edge (2022) Vibration Motor Replacement, Release the daughterboard cover clips: stap 27, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Release the daughterboard cover clips: stap 27, afbeelding 2 van 2
    • Insert a spudger under the daughterboard cover on the bottom right corner of the phone.
    • Pry up with the spudger to release the clips securing the cover.
  28. Motorola Edge (2022) Vibration Motor Replacement, Remove the daughterboard cover: stap 28, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Remove the daughterboard cover: stap 28, afbeelding 2 van 2
    Koop
    • Use your fingers or tweezers to remove daughterboard cover.
  29. Motorola Edge (2022) Vibration Motor Replacement, Disconnect the interconnect cable: stap 29, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Disconnect the interconnect cable: stap 29, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  30. Motorola Edge (2022) Vibration Motor Replacement: stap 30, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 30, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 30, afbeelding 3 van 3
    • Use your fingers or tweezers to peel back and remove the tape on the fingerprint sensor cover.
    • Set the tape aside for reassembly.
  31. Motorola Edge (2022) Vibration Motor Replacement, Unfasten the daughterboard: stap 31, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Unfasten the daughterboard: stap 31, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 3 mm screws:
    • One screw securing the fingerprint sensor cover.
    • One screw securing the daughterboard.
  32. Motorola Edge (2022) Vibration Motor Replacement: stap 32, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 32, afbeelding 2 van 2
    • Use your fingers or tweezers to remove the fingerprint sensor cover.
  33. Motorola Edge (2022) Vibration Motor Replacement: stap 33, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 33, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
  34. Motorola Edge (2022) Vibration Motor Replacement: stap 34, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 34, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 34, afbeelding 3 van 3
    • Use the pointed end of a spudger to pry up and disconnect the black antenna's coaxial connector.
    • Pry under the rounded edge of the coaxial connector, not the straight edge. If you pry under the straight edge, you may rip the socket off the daughterboard.
    • Use the spudger to push the antenna up and away from the phone until the cable is freed from the clip securing it to the daughterboard.
    • During reassembly, make sure the cable's metal band connects to the grounding clip in the daughterboard.
    • To re-attach coaxial connectors like this one, hold the connectors in place and gently press them straight down with your finger or the pointed end of a spudger.
  35. Motorola Edge (2022) Vibration Motor Replacement: stap 35, afbeelding 1 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 35, afbeelding 2 van 3 Motorola Edge (2022) Vibration Motor Replacement: stap 35, afbeelding 3 van 3
    • Repeat the previous step for the white antenna cable.
    • During reassembly, make sure to put the cable back in its clip on the daughterboard.
  36. Motorola Edge (2022) Vibration Motor Replacement: stap 36, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement: stap 36, afbeelding 2 van 2
    • Before you perform this step, be sure you’ve ejected the SIM tray.
    • Insert the pointed end of a spudger in the gap between the daughterboard and frame near the right edge of the phone.
    • Gently pry up to release the clips securing the daughterboard.
  37. Motorola Edge (2022) Vibration Motor Replacement, Remove the daughterboard: stap 37, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Remove the daughterboard: stap 37, afbeelding 2 van 2
    • Use your fingers or tweezers to lift the daughterboard out of its recess and remove it.
    • During reassembly, make sure all cables that connect to the daughterboard (interconnect, fingerprint sensor, and antennas) are out of they way so they don't get stuck under the daughterboard when it's reinserted.
  38. Motorola Edge (2022) Vibration Motor Replacement, Apply isopropyl alcohol: stap 38, afbeelding 1 van 1
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the vibration motor and its contact pad to loosen the adhesive securing them.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
  39. Motorola Edge (2022) Vibration Motor Replacement, Pry the vibration motor: stap 39, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Pry the vibration motor: stap 39, afbeelding 2 van 2
    • Insert the pointed end of a spudger in the gap between the vibration motor and frame.
    • Pry up with the spudger to separate the vibration motor from the frame.
  40. Motorola Edge (2022) Vibration Motor Replacement, Remove the vibration motor: stap 40, afbeelding 1 van 2 Motorola Edge (2022) Vibration Motor Replacement, Remove the vibration motor: stap 40, afbeelding 2 van 2
    Koop
    • Use your fingers or tweezers to remove the vibration motor.
    • The vibration motor's flex cable is very fragile. Work slowly to prevent tearing the cable.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it up or allow the alcohol to dry off before installing a new vibration motor.
    • Apply new adhesive to your vibration motor before installing it in the frame.
Conclusie
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
55.176 Reputatie
408 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.420 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 259
