Ga door naar hoofdinhoud
How to Test the Hardware on Your Motorola Phone
  1. How to Test the Hardware on Your Motorola Phone, Open the apps menu: stap 1, afbeelding 1 van 1
    • From the home screen, swipe up from the bottom of the phone to open the applications menu.
  2. How to Test the Hardware on Your Motorola Phone, Open the device help app: stap 2, afbeelding 1 van 1
    • Select the "Device Help" application from the menu.
  3. How to Test the Hardware on Your Motorola Phone, Select device diagnosis: stap 3, afbeelding 1 van 1
    • Select "Device diagnosis" from the menu.
  4. How to Test the Hardware on Your Motorola Phone, Select hardware test: stap 4, afbeelding 1 van 1
    • Select "Hardware test" from the menu.
  5. How to Test the Hardware on Your Motorola Phone: stap 5, afbeelding 1 van 1
    • You can now select which hardware test you would like to run, or you can run a full hardware test.
Eindstreep
20 andere personen hebben deze handleiding voltooid.
Spencer Day
155.036 Reputatie
1.033 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.774 handleidingen geschreven
6Gids Commentaar
is built using the open source software libraries listed below. These libraries are distributed under associated licenses, acknowledgements and required copyright notices also listed below:
Michael Lassiter - Antwoord
Thank you for your help and approval
What if my Motorola phone doesn't have the device help in the app menu then how do I go about running diagnostics on it OH and Just so you know I don't have any mobile data connection so I can't use the phone codes.
Sean Jacob Higgins - Antwoord
Having problems with my phone
Lisa Jablon - Antwoord
I want to see how I could take apps off Motorola moto04
Antonio “Mono” Cabrera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 180
Afgelopen 30 dagen: 854
Altijd: 54,120
