Ga door naar hoofdinhoud
Motorola Edge (2022) Front Camera Replacement
Wat je nodig hebt
  1. Motorola Edge (2022) Front Camera Replacement, Heat the right edge: stap 1, afbeelding 1 van 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Front Camera Replacement, Separate the right adhesive: stap 2, afbeelding 1 van 3 Motorola Edge (2022) Front Camera Replacement, Separate the right adhesive: stap 2, afbeelding 2 van 3 Motorola Edge (2022) Front Camera Replacement, Separate the right adhesive: stap 2, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Front Camera Replacement, Slice the right adhesive: stap 3, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Slice the right adhesive: stap 3, afbeelding 2 van 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Front Camera Replacement, Heat the bottom edge: stap 4, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Front Camera Replacement, Slice the bottom right corner adhesive: stap 5, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Slice the bottom right corner adhesive: stap 5, afbeelding 2 van 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Front Camera Replacement: stap 6, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 6, afbeelding 2 van 2
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Front Camera Replacement: stap 7, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Front Camera Replacement: stap 8, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 8, afbeelding 2 van 2
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Front Camera Replacement: stap 9, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 9, afbeelding 2 van 2
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Front Camera Replacement: stap 10, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Front Camera Replacement: stap 11, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 11, afbeelding 2 van 2
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Front Camera Replacement: stap 12, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 12, afbeelding 2 van 2
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Front Camera Replacement, Remove the back cover: stap 13, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Remove the back cover: stap 13, afbeelding 2 van 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
  14. Motorola Edge (2022) Front Camera Replacement, Separate the camera bezel adhesive: stap 14, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Separate the camera bezel adhesive: stap 14, afbeelding 2 van 2
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
  15. Motorola Edge (2022) Front Camera Replacement: stap 15, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 15, afbeelding 2 van 2
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
  16. Motorola Edge (2022) Front Camera Replacement, Remove the camera bezel: stap 16, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Remove the camera bezel: stap 16, afbeelding 2 van 2
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
  17. Motorola Edge (2022) Front Camera Replacement, Detach the left wireless charging coil tape: stap 17, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Detach the left wireless charging coil tape: stap 17, afbeelding 2 van 2
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
  18. Motorola Edge (2022) Front Camera Replacement, Detach the right wireless charging coil tape: stap 18, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Detach the right wireless charging coil tape: stap 18, afbeelding 2 van 2
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
  19. Motorola Edge (2022) Front Camera Replacement: stap 19, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 19, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
  20. Motorola Edge (2022) Front Camera Replacement: stap 20, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement: stap 20, afbeelding 2 van 2
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
  21. Motorola Edge (2022) Front Camera Replacement: stap 21, afbeelding 1 van 3 Motorola Edge (2022) Front Camera Replacement: stap 21, afbeelding 2 van 3 Motorola Edge (2022) Front Camera Replacement: stap 21, afbeelding 3 van 3
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  22. Motorola Edge (2022) Front Camera Replacement, Remove the motherboard cover: stap 22, afbeelding 1 van 3 Motorola Edge (2022) Front Camera Replacement, Remove the motherboard cover: stap 22, afbeelding 2 van 3 Motorola Edge (2022) Front Camera Replacement, Remove the motherboard cover: stap 22, afbeelding 3 van 3
    • Slowly pull the motherboard cover up and away from the phone and remove it.
  23. Motorola Edge (2022) Front Camera Replacement, Move the graphite film: stap 23, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Move the graphite film: stap 23, afbeelding 2 van 2
    • Use your fingers to move the graphite film that covers the battery out of the way.
  24. Motorola Edge (2022) Front Camera Replacement, Disconnect the battery: stap 24, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Disconnect the battery: stap 24, afbeelding 2 van 2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  25. Motorola Edge (2022) Front Camera Replacement, Peel the camera tape: stap 25, afbeelding 1 van 2 Motorola Edge (2022) Front Camera Replacement, Peel the camera tape: stap 25, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to peel back the tape that connects the front camera to the motherboard.
  26. Motorola Edge (2022) Front Camera Replacement, Remove the front camera: stap 26, afbeelding 1 van 3 Motorola Edge (2022) Front Camera Replacement, Remove the front camera: stap 26, afbeelding 2 van 3 Motorola Edge (2022) Front Camera Replacement, Remove the front camera: stap 26, afbeelding 3 van 3
    • Use the pointed end of a spudger to pry up and disconnect the front camera's press connector.
    • Use your fingers or tweezers to remove the camera.
Conclusie
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
58.593 Reputatie
430 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.524 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 192
