MacBook Unibody Model A1342 Front Display Bezel Replacement
Inleiding
Ga naar stap 1Remove the front display bezel to access components in your display.
Wat je nodig hebt
Gereedschap
Insert the flat end of a spudger between the thin rubber strip surrounding the front display bezel and the rear display bezel.
Use the flat end of your spudger to carefully pry the front display bezel away from the adhesive securing it to the rear display bezel.
Continue prying until the front display bezel is free along the right side of the display and behind the right clutch hinge.
Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly.
When you get about half way across, pry up from the other side of the front display bezel's lower edge to ease the process.
Remove the front display bezel from the display assembly.
19 andere personen hebben deze handleiding voltooid.
