Ga door naar hoofdinhoud
MacBook Pro 14" Late 2023 (M3) Battery Replacement
Wat je nodig hebt
  1. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 3 van 3
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the lower case: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Use a P5 pentalobe driver to remove the eight screws securing the lower case:
    • Four 9.2 mm-long screws along the back edge (near the screen hinge)
    • Four 5 mm-long screws along the front edge (near the trackpad)
  3. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the sliding clips: stap 3, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the sliding clips: stap 3, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the sliding clips: stap 3, afbeelding 3 van 3
    • Sliding clips along the back edge of the MacBook secure the lower case. In this step, you'll shift the lower case away from the hinges to free it from these clips.
    • Insert the flat end of a spudger between the lower case and the right screen hinge.
    • Lever your spudger against the hinge to push the lower case away from it.
    • Repeat for the left hinge.
  4. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Lower case information: stap 4, afbeelding 1 van 1
    • After you've released the sliding clips along the back edge, four remaining clips secure the lower case to the frame:
    • Two clips near the cutouts in the frame
    • Two clips near the middle of the lower case
    • As you release the lower case from the frame, you'll hear and feel a distinct "pop" as each of these four clips release.
  5. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the right clips: stap 5, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the right clips: stap 5, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Release the right clips: stap 5, afbeelding 3 van 3
    • Don't insert your tool deeper than 1 cm (a little less than half an inch) near the front of the speaker cutouts to avoid damaging the speakers.
    • Insert the flat end of your spudger into the front of the cutout in the right side of the frame.
    • Slide your spudger toward the back of the cutout and pry up to release the two right-side clips.
    • Repeat for the left-side speaker cutout to release the two left-side clips.
  6. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the lower case: stap 6, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the lower case: stap 6, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the lower case: stap 6, afbeelding 3 van 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the trackpad connector cover: stap 7, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the trackpad connector cover: stap 7, afbeelding 2 van 2
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm-long 3IP Torx Plus screws securing the trackpad connector cover.
  8. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the trackpad connector cover: stap 8, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the trackpad connector cover: stap 8, afbeelding 2 van 2
    • Remove the trackpad connector cover.
  9. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the trackpad: stap 9, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the trackpad: stap 9, afbeelding 2 van 2
    • Use the flat end of your spudger to pry up and disconnect the trackpad press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't force it, since a misaligned connector can bend the pins, and cause permanent damage.
  10. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Move the trackpad cable: stap 10, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Move the trackpad cable: stap 10, afbeelding 2 van 2
    • Light adhesive secures the trackpad cable to the battery board.
    • Peel the trackpad cable from the battery board and move it over the front edge of the MacBook.
    • Be careful not to crease or damage the cable.
  11. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Soften the battery data cable adhesive: stap 11, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Soften the battery data cable adhesive: stap 11, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Soften the battery data cable adhesive: stap 11, afbeelding 3 van 3
    • The battery data cable is adhered to the battery board and logic board. In the next few steps, you'll disconnect it, separate its adhesive, and remove it.
    • Heat an iOpener and place it on the battery data cable for 30 seconds to soften its adhesive.
    • If you don't have an iOpener, you can use a hair dryer to lightly heat the cable. Be careful not to overheat the battery, as doing so is a fire hazard.
  12. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Reveal the battery board ZIF connector: stap 12, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Reveal the battery board ZIF connector: stap 12, afbeelding 2 van 2
    Koop
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the battery board.
  13. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unlatch the ZIF connector: stap 13, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unlatch the ZIF connector: stap 13, afbeelding 2 van 2
    • Use the point of your spudger to flip up the small locking flap on the battery data cable ZIF connector on the battery board.
  14. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the battery board: stap 14, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the battery board: stap 14, afbeelding 2 van 2
    • Use your tweezers to slide the connector straight out of its socket to disconnect it from the battery board.
  15. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Reveal the logic board battery data ZIF connector: stap 15, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Reveal the logic board battery data ZIF connector: stap 15, afbeelding 2 van 2
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the logic board.
  16. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unlatch the ZIF connector: stap 16, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unlatch the ZIF connector: stap 16, afbeelding 2 van 2
    • Use the point of your spudger to flip up the small locking flap on the logic board battery data ZIF connector.
  17. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the logic board battery data cable: stap 17, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the logic board battery data cable: stap 17, afbeelding 2 van 2
    • Use your tweezers to grip the neck of the cable and slide it straight out of its socket to disconnect it from the logic board.
  18. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Separate the battery data cable adhesive: stap 18, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Separate the battery data cable adhesive: stap 18, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Separate the battery data cable adhesive: stap 18, afbeelding 3 van 3
    • The battery data cable is lightly adhered to the battery board and logic board.
    • Slide the tip of an opening pick between the upper section of the battery data cable and the logic board to separate the adhesive.
    • Slide your pick between the lower section of the cable and the silver wide-head screw to separate the remaining adhesive.
  19. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the battery data cable: stap 19, afbeelding 1 van 1
    • Remove the battery data cable.
  20. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the battery connector: stap 20, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the 3.9 mm-long 5IP Torx Plus wide-head screw securing the main battery connector.
  21. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the main power connector: stap 21, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the main power connector: stap 21, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Disconnect the main power connector: stap 21, afbeelding 3 van 3
    • Use the flat end of your spudger to lift the main battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent breaking it.
    • For added safety, place a non-conductive barrier, such as a piece of a playing card, between the connector and board.
  22. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the trackpad: stap 22, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the trackpad: stap 22, afbeelding 2 van 2
    • Use your T5 Torx driver to remove the ten 5.8 mm-long 5IP Torx Plus screws securing the trackpad.
    • During reassembly, you may need to open your MacBook to check for alignment as you tighten the screws. Adjust the trackpad so that the edges don't rub against the frame.
  23. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Lift the body of the MacBook: stap 23, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Lift the body of the MacBook: stap 23, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Lift the body of the MacBook: stap 23, afbeelding 3 van 3
    • Slowly lift the body of your MacBook away from the screen and guide the trackpad cable through its cutout.
    • The trackpad will remain on the screen.
    • During reassembly, make sure all the screw holes align with their holes in the frame as you lower it onto the trackpad.
  24. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the trackpad: stap 24, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the trackpad: stap 24, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the trackpad: stap 24, afbeelding 3 van 3
    • Remove the trackpad.
    • Make sure not to lose the six small metal washers from their screw posts on the trackpad. Without them, your trackpad won't sit flush in the frame.
  25. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the battery board: stap 25, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Unfasten the battery board: stap 25, afbeelding 2 van 2
    • Lower the body of your MacBook flat to the screen.
    • Use your T5 Torx driver to remove the 4.1 mm-long 5IP Torx Plus screw securing the battery board.
  26. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Flip over your MacBook: stap 26, afbeelding 1 van 1
    • Check that your battery connector isn't sticking out beyond the frame, as it could break when you flip your MacBook over and lay it down.
    • Place a soft cloth on your work surface.
    • Flip your MacBook over and lay it on the cloth.
    • Open the screen enough to access the trackpad recess.
  27. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Adhesive information: stap 27, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Adhesive information: stap 27, afbeelding 2 van 2
    • Your MacBook's battery is secured with 14 stretch release adhesive strips. The next five steps show how to remove them and free your battery.
    • Six strips are accessible from the trackpad recess.
    • The remaining eight strips are on the edges of the outer battery cells.
  28. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 28, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 28, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 28, afbeelding 3 van 3
    Koop
    • Use blunt nose tweezers to grip the black pull tab on one of the adhesive strips through its cutout in the frame.
    • Grip the entire length of the strip's pull tab and pull it slowly, evenly, and at a low angle out from underneath the battery cell. Twist your tool to wrap the strip around itself as you pull.
    • Give the strip plenty of time to stretch. Avoid dragging it over the frame as you pull.
    • If you're using your fingers to remove the strip, re-grip it often to avoid it stretching unevenly and tearing.
    • Repeat for the other five strips accessible from the trackpad recess.
    • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, don't worry! Move on to the next step to remove the other strips, then keep reading for an alternate method to remove the stuck battery cells.
  29. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Flip over your MacBook: stap 29, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Flip over your MacBook: stap 29, afbeelding 2 van 2
    • Be careful as you move your MacBook—the middle battery cells might be loose. They won't fall out, but don't let them strain any cables or components.
    • Close the screen and flip over your MacBook, so the battery faces up.
    • There are two pull tabs on the outer edge of each of the four outer battery cells.
  30. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Peel the pull tabs: stap 30, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Peel the pull tabs: stap 30, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Peel the pull tabs: stap 30, afbeelding 3 van 3
    • Don't use metal or sharp tools near the battery, and be careful not to dent or puncture it.
    • Use the tip of an opening pick to peel up an edge of one of the adhesive strip pull tabs.
    • Use blunt nose tweezers to grip the pull tab and separate it from the edge of the battery cell.
  31. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 31, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 31, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the stretch release adhesive: stap 31, afbeelding 3 van 3
    • Give the strip plenty of time to stretch. Avoid dragging it over the speakers as you pull.
    • Repeat the last two steps for the other seven strips.
    • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, read on to the next step for an alternate method to remove the battery.
  32. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Alternate method to remove the battery: stap 32, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Alternate method to remove the battery: stap 32, afbeelding 2 van 2
    • If you removed all 14 stretch release adhesive strips, you can now remove the battery. If not, follow the next three steps to separate the remaining adhesive with isopropyl alcohol and an opening pick.
    • Open your screen and place a paper towel or absorbent cloth between it and the trackpad recess to protect the screen from any residual isopropyl alcohol.
  33. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Apply isopropyl alcohol: stap 33, afbeelding 1 van 2 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Apply isopropyl alcohol: stap 33, afbeelding 2 van 2
    • Prop up the edge of your MacBook where the stuck adhesive strips are.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the outside edges of the stuck battery cells.
    • Wait one minute for the isopropyl alcohol to flow underneath the stuck battery cells and soften the adhesive.
  34. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Pry up the stuck cells: stap 34, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Pry up the stuck cells: stap 34, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Pry up the stuck cells: stap 34, afbeelding 3 van 3
    • Don't bend or crease your battery cells. If they feel stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Insert the flat end of an opening pick between the stuck battery cell and the speaker.
    • Slowly and steadily pry up the battery cell.
    • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
    • Repeat this process for any additional stuck cells.
  35. MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the battery: stap 35, afbeelding 1 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the battery: stap 35, afbeelding 2 van 3 MacBook Pro 14" Late 2023 (M3) Battery Replacement, Remove the battery: stap 35, afbeelding 3 van 3
    Tesa 61395 Tape
    $6.99
    Koop
    • Remove the battery.
    • To install a new battery:
    • Peel any residual adhesive strips from the frame.
    • Clean the frame with isopropyl alcohol and a lint-free or microfiber cloth.
    • If your battery comes with adhesive pre-installed, remove the liners and firmly press each cell into place.
    • If your battery doesn't come with adhesive pre-installed, apply a couple strips of thin, double-sided tape to each cell and firmly press it into place.
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
Één andere persoon heeft deze handleiding voltooid.
Clay Eickemeyer
68.032 Reputatie
453 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.524 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 231
Altijd: 1,335
