Ga door naar hoofdinhoud
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
Jackson Reynolds
Jackson Reynolds en 4 andere bijdragers
Voor het laatst geüpdatet op February 28, 2025
20 - 40 minuten
Gemiddeld
Actiemomenten
Behoeft meer afbeeldingen
Follow this guide to remove the SSD/Hard Drive from your Lenovo Thinkpad T560.
The hard drive stores data in your computer.
Some symptoms of a bad hard drive are your computer freezing and/or slowing down, a blue screen appearing, unusual sounds coming from the laptop, and the computer’s data being corrupted. Some more information about a faulty hard drive can be found at this website.
Before removing/replacing the hard drive, make sure to disable the internal battery, turn off your laptop and disconnect it from any external power sources.
Wat je nodig hebt
Gereedschap
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove SSD/Hard Drive case from the drive.
Conclusie
Jackson Reynolds
517 Reputatie
5 handleidingen geschreven
Clemson, Team 1-3, Hunter Spring 2022 Lid van Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 186
Altijd: 5,935
