Ga door naar hoofdinhoud
Lenovo ThinkPad T470 Bottom Cover Replacement
Kristen Gismondi
Kristen Gismondi en een andere bijdrager
Voor het laatst geüpdatet op May 23, 2024
10 minuten
Eenvoudig
Use this guide to replace the bottom cover of your Lenovo ThinkPad T470 laptop.
The bottom cover encases the internal components of the laptop and provides proper ventilation for the fan. You may need to replace the bottom cover if it is cracked or physically damaged to the point where it is exposing the laptop’s internals.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Wat je nodig hebt
Gereedschap
  1. Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: stap 1, afbeelding 1 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: stap 1, afbeelding 2 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement, External Battery: stap 1, afbeelding 3 van 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Bottom Cover Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement: stap 2, afbeelding 3 van 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T470 Bottom Cover Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Bottom Cover Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T470 Bottom Cover Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Bottom Cover Replacement: stap 5, afbeelding 1 van 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
Conclusie
Kristen Gismondi
92.167 Reputatie
241 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.470 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 84
Altijd: 3,708
