Ga door naar hoofdinhoud
Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement
Chayton Ritter
Chayton Ritter en 3 andere bijdragers
Voor het laatst geüpdatet op February 15, 2023
30 - 45 minuten
Gemiddeld
Use this guide to upgrade or replace the left side M.2 solid-state drive (SSD) in a Lenovo Legion 5 Pro 16ACH6H gaming laptop. This laptop is only compatible with NVME SSDs, and is therefore not compatible with SATA SSDs.
Before you perform this repair, back up your existing SSD if possible. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Finally, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Wat je nodig hebt
Reparatiesets
Deze sets bevatten alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Toon meer…
  1. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: stap 1, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Back cover removal: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.7 mm PH00 screws
    • Four 4.2 mm PH00 screws
  2. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the front clips: stap 2, afbeelding 3 van 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 3, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 3, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 3, afbeelding 3 van 3
    • Angle the pick to about 45˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: stap 4, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: stap 4, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right clips: stap 4, afbeelding 3 van 3
    • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
  5. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: stap 5, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: stap 5, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left clips: stap 5, afbeelding 3 van 3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the right vent clips: stap 6, afbeelding 3 van 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 7, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 7, afbeelding 2 van 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Release the left vent clips: stap 8, afbeelding 3 van 3
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 9, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 9, afbeelding 2 van 2
  10. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the back cover: stap 10, afbeelding 3 van 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Disconnect the battery: stap 11, afbeelding 3 van 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 12, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: stap 13, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Left SSD removal: stap 13, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
    • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
  14. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the SSD shield: stap 14, afbeelding 3 van 3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 15, afbeelding 1 van 2 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement: stap 15, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 2.6 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 1 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 2 van 3 Lenovo Legion 5 Pro 16ACH6H Left SSD Replacement, Remove the left SSD: stap 16, afbeelding 3 van 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
3 andere personen hebben deze handleiding voltooid.
Chayton Ritter
22.528 Reputatie
105 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
9 Leden
11.426 handleidingen geschreven
Één opmerking
@chaytonr What's the maximum supported SSD capacity for Lenovo Legion 5 Pro 16ACH6H? I already have a 1TB SSD on the right slot but can i intall a 2TB SSD on the left slot for a total of 3TB storage?
Ayush Patel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 146
Altijd: 7,329
