LG Optimus Dynamic II L39C Camera Replacement
Inleiding
Ga naar stap 1For changing a broken camera.
Wat je nodig hebt
Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
Use the PH #000 screwdriver to remove the six screws from the midframe
Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
Use the plastic opening tool to disconnect the small orange tab from the motherboard.
Next disconnect the silver tab slightly above where the orange tab was.
Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
Using the spudger, push the black tabs on the sides of the motherboard off carefully.
Turn the phone over and pull up the orange tab connected to the camera.
You should be able to remove the camera easily with your fingers.
Één andere persoon heeft deze handleiding voltooid.
