Ga door naar hoofdinhoud
HP Envy x360 15m-cn0012dx Daughterboard Replacement
Grace Daleki
Grace Daleki en een andere bijdrager
Voor het laatst geüpdatet op June 16, 2020
50 minuten
Gemiddeld
If your HP Envy x360 m Convertible (Model 15m-cn0012dx) isn’t reading SD cards, use this guide to replace the SD card motherboard.
A faulty SD card reader will not even recognize that there is a card in the slot. It will not show up on the computer desktop screen.
Before starting, make sure all external connections are unplugged and the computer is turned off.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: stap 1, afbeelding 1 van 2 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: stap 1, afbeelding 2 van 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 3, afbeelding 3 van 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 4, afbeelding 3 van 3
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 1 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 2 van 3 HP Envy x360 15m-cn0012dx Daughterboard Replacement: stap 5, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Grace Daleki
487 Reputatie
3 handleidingen geschreven
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Lid van UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 33
Altijd: 821
