Ga door naar hoofdinhoud
HP EliteBook x360 1030 G3 Battery Replacement
Pablo Arriola
Pablo Arriola en 5 andere bijdragers
Voor het laatst geüpdatet op December 9, 2023
20 minuten
Gemiddeld
Uitgelichte studenten-handleiding
If you are having power issues with this device, replacing the battery may be the solution. This guide will show you how to do so.
However, you should check through the troubleshooting page before proceeding, in case a simpler fix resolves the problem.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: stap 4, afbeelding 1 van 2 HP EliteBook x360 1030 G3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the battery out of its place.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Pablo Arriola
528 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G9, Maness Spring 2019 Lid van Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Leden
16 handleidingen geschreven
5 opmerkingen
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - Antwoord
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - Antwoord
Thank you. very useful.
mustapha ELABED - Antwoord
Very simple and precise with good warnings too
Roland Appiah - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 179
Altijd: 13,336
