Ga door naar hoofdinhoud
Governor Adjustment
Governor Adjustment
Aaron Correya
Aaron Correya en 4 andere bijdragers
Voor het laatst geüpdatet op June 19, 2018
10 - 20 minuten
Eenvoudig
Adjusting the governor helps maintain a steady engine speed no matter the terrain and other conditions that could effect the engine workload. While the manufacturer highly recommends against this, it may be necessary to keep your engine running well.
Wat je nodig hebt
Gereedschap
  1. Governor Adjustment, Governor Adjustment: stap 1, afbeelding 1 van 3 Governor Adjustment, Governor Adjustment: stap 1, afbeelding 2 van 3 Governor Adjustment, Governor Adjustment: stap 1, afbeelding 3 van 3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: stap 2, afbeelding 1 van 1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: stap 3, afbeelding 1 van 1
    • Carefully re-hook the spring on the arm it was disconnected from.
Conclusie
Aaron Correya
239 Reputatie
2 handleidingen geschreven
Cal Poly, Team S25-G15, Maness Spring 2018 Lid van Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Leden
7 handleidingen geschreven
2 opmerkingen
Wow, I'm very grateful.
Bradley Earnest - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 20
Altijd: 2,646
