Ga door naar hoofdinhoud
Google Pixel Fold Outer Screen Replacement
Wat je nodig hebt
    1. Google Pixel Fold Outer Screen Replacement, Safety Precautions: stap 1, afbeelding 1 van 1
      • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
      • Fully power off your phone and unplug any cables.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel Fold Outer Screen Replacement, Heat the bottom edge: stap 2, afbeelding 1 van 1
      • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel Fold Outer Screen Replacement, Adhesive information: stap 3, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Adhesive information: stap 3, afbeelding 2 van 2
      • While you're waiting for the adhesive to soften, note the following:
      • The adhesive is under the dark black border surrounding the screen.
      • During the screen removal procedure, you only need to insert your opening pick as deep as the border.
      • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 4, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 4, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 4, afbeelding 3 van 3
      • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
      • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
      • Insert an opening pick into the gap.
      • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel Fold Outer Screen Replacement, Separate the bottom adhesive: stap 5, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Separate the bottom adhesive: stap 5, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Separate the bottom adhesive: stap 5, afbeelding 3 van 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the opening pick in the bottom right corner before continuing.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel Fold Outer Screen Replacement, Heat the right edge: stap 6, afbeelding 1 van 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel Fold Outer Screen Replacement, Separate the bottom right adhesive: stap 7, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the bottom right adhesive: stap 7, afbeelding 2 van 2
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel Fold Outer Screen Replacement, Separate the right adhesive: stap 8, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Separate the right adhesive: stap 8, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Separate the right adhesive: stap 8, afbeelding 3 van 3
      • Insert a new opening pick in the bottom right corner.
      • Slide the opening pick toward the top right corner to separate the adhesive.
      • Leave the opening pick in the top right corner before continuing.
      Vraag FixBot
      Voeg opmerking toe
    8. Google Pixel Fold Outer Screen Replacement, Heat the top edge: stap 9, afbeelding 1 van 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Vraag FixBot
      Voeg opmerking toe
    9. Google Pixel Fold Outer Screen Replacement, Separate the top right adhesive: stap 10, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the top right adhesive: stap 10, afbeelding 2 van 2
      • Rotate the opening pick around the top right corner to separate its adhesive.
      Vraag FixBot
      Voeg opmerking toe
    10. Google Pixel Fold Outer Screen Replacement, Separate the top adhesive: stap 11, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the top adhesive: stap 11, afbeelding 2 van 2
      • Insert a new opening pick in the top right corner.
      • Slide the opening pick toward the top left corner to separate its adhesive.
      Vraag FixBot
      Voeg opmerking toe
    11. Google Pixel Fold Outer Screen Replacement, Heat the left edge: stap 12, afbeelding 1 van 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Vraag FixBot
      Voeg opmerking toe
    12. Google Pixel Fold Outer Screen Replacement, Separate the top left adhesive: stap 13, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the top left adhesive: stap 13, afbeelding 2 van 2
      • The sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
      • Angle your pick so it's as flat as possible to the screen.
      • Rotate the opening pick around the top left corner to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    13. Google Pixel Fold Outer Screen Replacement, Separate the left adhesive: stap 14, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Separate the left adhesive: stap 14, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Separate the left adhesive: stap 14, afbeelding 3 van 3
      • Insert a new opening pick in the top left corner.
      • Slide the opening pick toward the bottom left corner to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    14. Google Pixel Fold Outer Screen Replacement, Separate the bottom left adhesive: stap 15, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the bottom left adhesive: stap 15, afbeelding 2 van 2
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    15. Google Pixel Fold Outer Screen Replacement, Adhesive information: stap 16, afbeelding 1 van 1
      • There's a small adhesive strip that secures the screen near the top right corner of the phone.
      • The next three steps will show you how to separate this adhesive.
      Vraag FixBot
      Voeg opmerking toe
    16. Google Pixel Fold Outer Screen Replacement, Heat the top right corner: stap 17, afbeelding 1 van 1
      • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
      Vraag FixBot
      Voeg opmerking toe
    17. Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 18, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 18, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Insert an opening pick: stap 18, afbeelding 3 van 3
      • Insert an opening pick under the right edge of the screen, near the top right corner.
      • Push the opening pick under the screen as far you can go without losing your grip.
      Vraag FixBot
      Voeg opmerking toe
    18. Google Pixel Fold Outer Screen Replacement, Separate the adhesive: stap 19, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Separate the adhesive: stap 19, afbeelding 2 van 2
      • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
      • Twist the opening pick back and forth to separate the adhesive.
      • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
      Vraag FixBot
      Voeg opmerking toe
    19. Google Pixel Fold Outer Screen Replacement, Reposition the screen: stap 20, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Reposition the screen: stap 20, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Reposition the screen: stap 20, afbeelding 3 van 3
      • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
      • Don't remove the screen yet, as it's still connected to the phone by a cable.
      • Swing the left edge of the screen up and over the right edge of the phone.
      • Let the screen rest next to the phone before continuing.
      Vraag FixBot
      Voeg opmerking toe
    20. Google Pixel Fold Outer Screen Replacement, Unfasten the bottom bracket: stap 21, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      FixMat
      $36.95
      • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 Torx or T4 bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
      • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
      Vraag FixBot
      Voeg opmerking toe
    21. Google Pixel Fold Outer Screen Replacement, Remove the bottom bracket: stap 22, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Remove the bottom bracket: stap 22, afbeelding 2 van 2
      • Use tweezers, or your fingers, to remove the bottom bracket.
      • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
      Vraag FixBot
      Voeg opmerking toe
    22. Google Pixel Fold Outer Screen Replacement, Disconnect the flip battery: stap 23, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Disconnect the flip battery: stap 23, afbeelding 2 van 2
      • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
      • Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    23. Google Pixel Fold Outer Screen Replacement, Disconnect the screen: stap 24, afbeelding 1 van 2 Google Pixel Fold Outer Screen Replacement, Disconnect the screen: stap 24, afbeelding 2 van 2
      • Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
      • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
      • Pry up to disconnect the screen press connector.
      Vraag FixBot
      Voeg opmerking toe
    24. Google Pixel Fold Outer Screen Replacement, Remove the screen: stap 25, afbeelding 1 van 1
      • Remove the screen.
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Vraag FixBot
      Voeg opmerking toe
    25. Google Pixel Fold Outer Screen Replacement, Reassembly information: stap 26, afbeelding 1 van 3 Google Pixel Fold Outer Screen Replacement, Reassembly information: stap 26, afbeelding 2 van 3 Google Pixel Fold Outer Screen Replacement, Reassembly information: stap 26, afbeelding 3 van 3
      Tesa 61395 Tape
      $8.95
      • During reassembly, perform the following:
      • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
      • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
      • If your top right adhesive is still intact and sticky, you can reuse it.
      • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
      • Follow this guide to replace your screen adhesive.
      • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
7 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
246.393 Reputatie
1.203 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
43.834 handleidingen geschreven
3Gids Commentaar
palecho cell
Albert Wilbert - Antwoord Deel
Thank you! It was delicate but no too hard. I would have appreciated some more tutorial on all the sticky parts in removing films when installing a new screen.
Chad W - Antwoord Deel
Please note that if you use a new screen, it may already have adhesive applied to it. If so, you can potentially skip the step of perfectly aligning the adhesive that the kit comes with... Until you realize you forgot to replace the bottom bracket and have to open your phone up again. 😅
mar_c_b - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 255
Altijd: 5,837
