Inleiding
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
This guide shows how to remove and replace the loudspeaker module for a Google Pixel 3 XL.
The loudspeaker is sealed against the frame with an adhesive gasket. If you remove the loudspeaker, the Pixel will no longer be retain its water resistance.
Wat je nodig hebt
Heat an iOpener and apply it to the right edge of the back cover for a minute.
While you wait, note the following areas on the back cover:
Strong adhesive—there are large patches of adhesive near the bottom of the phone.
Fingerprint sensor cable—be careful not to slice through the cable as you pry
Apply a suction cup to the heated edge of the back cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap.
Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
Insert the point of an opening pick into the gap.
Slide the opening pick along the right edge to slice through the adhesive.
The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
Apply a heated iOpener to the bottom of the back cover for a minute.
Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
Leave a pick in the edge to prevent the adhesive from re-sealing.
Continue heating and slicing the remaining edges of the phone.
Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
Gently pry up the right edge of the back cover.
Use an opening pick to slice through any remaining adhesive along the edges.
Swing the right edge of the back cover upwards and rest the flipped panel along the left side of the phone.
User tweezers to carefully peel up the yellow tape over the fingerprint sensor connector.
Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
Remove the following four T3 screws securing the metal cover bracket:
Three 4 mm long screws
One 3 mm long screw
Insert the flat end of a spudger underneath the top right edge of the metal bracket and pry up to loosen it.
Remove the metal cover bracket.
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Bend the battery cable such that the connector will not accidentally touch the socket.
Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket, near the bottom right edge of the phone.
Remove the following four T3 screws securing the loudspeaker:
One 3.9 mm long screw
Insert the point of an opening pick under the bottom right corner of the loudspeaker.
Slide the pick in to loosen the right side of the loudspeaker.
Lift the loudspeaker out slowly and pull it away from any remaining adhesive.
Remove the loudspeaker.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
