Ga door naar hoofdinhoud
DualSense Edge Back Buttons Replacement
Wat je nodig hebt
  1. DualSense Edge Back Buttons Replacement, Remove the front trim: stap 1, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the front trim: stap 1, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the front trim: stap 1, afbeelding 3 van 3
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
  2. DualSense Edge Back Buttons Replacement, Remove the joysticks: stap 2, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the joysticks: stap 2, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the joysticks: stap 2, afbeelding 3 van 3
    • Flip the controller over so the joysticks are facing up.
    • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
    • Slide the joystick out from its slot.
  3. DualSense Edge Back Buttons Replacement: stap 3, afbeelding 1 van 1
    • Repeat this process to remove the other joystick.
  4. DualSense Edge Back Buttons Replacement, Insert an opening pick: stap 4, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Insert an opening pick: stap 4, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Insert an opening pick: stap 4, afbeelding 3 van 3
    • The rear trim is held in place by fragile plastic clips. Work slowly and gently to avoid breaking the clips.
    • If you installed the back button paddles included with your controller, remove them before beginning this process.
    • Insert the flat edge of an opening pick between the black portion of the rear trim and the top cover, near the joystick lever.
    • Slide the opening pick towards the bottom of the grip to release the clips.
  5. DualSense Edge Back Buttons Replacement, Release the clips: stap 5, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Release the clips: stap 5, afbeelding 2 van 2
    • Slide the pick around to the rear of the controller and flip the controller over so the buttons are facing down.
    • Slide the opening pick around the edge of the rear trim to release the clips.
  6. DualSense Edge Back Buttons Replacement, Remove the rear trim: stap 6, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the rear trim: stap 6, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the rear trim: stap 6, afbeelding 3 van 3
    • Slide the opening along the edge of the trim on the other grip.
    • Once all clips are released, remove the trim.
    • If at any point the trim feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
  7. DualSense Edge Back Buttons Replacement, Remove the L1 and R1 buttons: stap 7, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the L1 and R1 buttons: stap 7, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the L1 and R1 buttons: stap 7, afbeelding 3 van 3
    • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
    • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
    • Use the spudger to pry out the L1 button.
    • The buttons tend to shoot out in this step. You can place your thumb over the button to prevent this.
    • Repeat this process to remove the R1 button.
  8. DualSense Edge Back Buttons Replacement, Remove the screws: stap 8, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Remove the screws: stap 8, afbeelding 2 van 2
    • Remove the two 6.4 mm screws behind the L1 and R1 buttons.
    • Use a JIS J0 driver or an official iFixit Phillips PH0 driver, which is designed to be cross-compatible with JIS screws. Using a screwdriver other than an official iFixit driver or a JIS driver may result in stripped screws.
  9. DualSense Edge Back Buttons Replacement, Lift the release bar spring: stap 9, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Lift the release bar spring: stap 9, afbeelding 2 van 2
    • Rotate the controller so the grips are pointing towards you.
    • Use a pair of angled tweezers to lift the right end of the release bar spring off of the white post.
    • The spring is located below the RB button.
  10. DualSense Edge Back Buttons Replacement, Remove the trim release bar: stap 10, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the trim release bar: stap 10, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the trim release bar: stap 10, afbeelding 3 van 3
    • Use a pair of tweezers or your fingers to slide the release bar to the left.
    • Slide the release bar away from the controller to remove it.
  11. DualSense Edge Back Buttons Replacement, Remove the rear case screws: stap 11, afbeelding 1 van 1
    • Remove the nine screws securing the rear case:
    • Seven 6.4 mm‑long screws
    • Two 10.5 mm‑long screws
  12. DualSense Edge Back Buttons Replacement, Insert an opening pick: stap 12, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Insert an opening pick: stap 12, afbeelding 2 van 2
    • Insert the point an opening pick in the gap along the outside edge of one of the controller grips, near the bottom.
  13. DualSense Edge Back Buttons Replacement, Separate the rear case: stap 13, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Separate the rear case: stap 13, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Separate the rear case: stap 13, afbeelding 3 van 3
    • Pry with the opening pick to separate the rear case from the front case by releasing the clips that hold them together.
    • Continue prying along the edge of the controller until one side is separated.
  14. DualSense Edge Back Buttons Replacement: stap 14, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement: stap 14, afbeelding 2 van 2
    • Repeat this process to separate the other side of the rear case.
  15. DualSense Edge Back Buttons Replacement, Remove the rear case: stap 15, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Remove the rear case: stap 15, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Remove the rear case: stap 15, afbeelding 3 van 3
    • If at any point the case feels stuck, stop and look for any clips that may have re-engaged and release them with the opening pick to avoid damaging them.
    • Hold the main body of the controller with one hand.
    • Lift the rear case with your other hand. It should lift at an angle.
    • Pushing slightly towards the L and R buttons, lift the rear case off of the controller and remove it.
    • During reassembly, make sure the plastic covers for the adaptive trigger assembly adjustment sliders are correctly installed over the sliders.
  16. DualSense Edge Back Buttons Replacement, Replace the slider covers: stap 16, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Replace the slider covers: stap 16, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Replace the slider covers: stap 16, afbeelding 3 van 3
    • The rear case holds two small plastic covers for the adaptive trigger assembly adjustment sliders. These may have come off during removal. Place them back in the rear cover now to avoid losing them.
    • Use a pair of tweezers or your fingers to lift the cover from the controller.
    • Slide the flat end of the cover under the plastic tab in the rear case.
    • Make sure it is placed so it can move freely in its groove. The edge with the notch should be towards the middle of the controller.
    • If a cover got bent during the rear case removal or reassembly process, apply a small amount of heat with a hair dryer to restore it to its original shape.
    • During reassembly, you can use a small piece of painter's tape on the outside of the rear case to hold the covers in place.
  17. DualSense Edge Back Buttons Replacement, Lift the battery: stap 17, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Lift the battery: stap 17, afbeelding 2 van 2
    • If your battery is swollen or deformed in any way, take appropriate precautions.
    • Lift the battery and move it to the right, so the connector underneath the battery is accessible.
  18. DualSense Edge Back Buttons Replacement, Disconnect the battery: stap 18, afbeelding 1 van 3 DualSense Edge Back Buttons Replacement, Disconnect the battery: stap 18, afbeelding 2 van 3 DualSense Edge Back Buttons Replacement, Disconnect the battery: stap 18, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up the low profile connector.
    • Only pry on the connector. Do not pry on the wires, as that may damage the wires.
    • Remove the battery.
  19. DualSense Edge Back Buttons Replacement, Remove the back button bracket: stap 19, afbeelding 1 van 1
    • These instructions are for the RB back button, which is to your left. The instructions are identical for the LB back button.
    • While holding the back button switch down, remove the two 6.4 mm‑long screws securing the back button bracket.
  20. DualSense Edge Back Buttons Replacement: stap 20, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement: stap 20, afbeelding 2 van 2
    • While holding the back button switch down, use a pair of tweezers or your fingers to lift and remove the back button bracket.
  21. DualSense Edge Back Buttons Replacement, Remove the back button switch: stap 21, afbeelding 1 van 2 DualSense Edge Back Buttons Replacement, Remove the back button switch: stap 21, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to lift and remove the back button switch, being careful not to lose the plastic covers on the sides of the switch.
    • During reassembly, make sure the white plastic covers are in place, seated fully, and oriented correctly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Spencer Pennington
17.094 Reputatie
113 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.537 handleidingen geschreven
18 opmerkingen
Hey! Great video! By the way, any luck finding a source to buy the black piece you pick up at 8:07 in the video? I was able to glue them back in place, but I know that will just be temporary.
Edwin Burgos - Antwoord
Same here,where can we buy that black piece
zeko_fitness -
I also need that black piece, if someone knows where to buy it please let me know!
Remberto Nunez -
extremrate is about to release this fixing piece
Shawn Xiao -
I also need this black piece :(
Mykhailo Marochkin - Antwoord
Me too, need this piece as well.
Elijah Joaquin Ramirez - Antwoord
the mechanical Rocker that sits on top of the Module with the two pins sticking out at 8:09... are you able to 3D print these and or make some out of carbon fiber... that way they are more durable for constant wear and tear...
Blakn0va - Antwoord
Need the black, two prong piece
Link Bass - Antwoord
I am looking for taht same piece
Alan Garcia Chavez - Antwoord
Is there no answer to the question of where to get the black piece?
Craig - Antwoord
Folks, I heard that extremrate is about to release this fixing piece. Can't wait to fix my back buttons.
Shawn Xiao -
Any idea where to get the back button circuit board? The thing that allows the button to pop back up deflated and I'm unable to get to reflate and keep it flated.
Dao Masta - Antwoord
What I did with the black piece to fix it is. Drill a hole and insert a screw, cut off the end of the screw so it's the same way as the other arm and file it down. That piece broke on me on the second day of having a controller. Be back button mechanics was pretty poorly made.
Can you fix playstation edge controller back buttons mine just stopped working and only had it since Christmas
Josh Sharp - Antwoord
I need the black piece too. Please let me know where to buy it!
taleseum46 - Antwoord
Hi, any Idea where to buy the PCB for the back paddles, my left won't click anymore and although functional I reckon it needs replacing.
Brayan Valle - Antwoord
hello there,
first of all thank you so much for take the time to teach how to open and change the back botton but might i ask where you buy the back botton intertnal panel ?
JuanJO - Antwoord
Is there a link for the replacement button?
nullbreached - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 110
Afgelopen 30 dagen: 533
Altijd: 4,650
