Inleiding
Prerequisite-only guide for detaching the display assembly for access to the iPhone 11 internals.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Gereedschap gebruikt in deze stap:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Pull the small nub on the suction cup to detach it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Prop the display up against something sturdy.
To access the screws in the following step, tilt the display by slightly lifting its lower edge.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
Use a spudger or a fingernail to disconnect the LCD panel cable connector.
Disconnect the digitizer connector next to it.
Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
