Ga door naar hoofdinhoud
Disassembling Logitech MBJ58 Mouse Scroll wheel from mount
Maximilian Betkowski
Maximilian Betkowski en 11 andere bijdragers
Voor het laatst geüpdatet op December 5, 2022
3 - 5 minuten
Gemiddeld
This guide shows how to disassemble and remove the scroll wheel of the Logitech MBJ58 optical scroll mouse. This might be necessary if the wheel is stuck, difficult to turn, or dislodged. If it becomes dislodged, it can cause additional damage to the mouse’s motherboard, which is located beneath the wheel.
The scroll wheel may become jammed if the support spring that holds it in place is dislodged. To see how to repair that, as well as how to deconstruct other parts of the mouse, see the Logitech MBJ58 mouse troubleshooting guide.
Wat je nodig hebt
Gereedschap
  1. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Top cover: stap 1, afbeelding 1 van 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - Antwoord
    There may be a sticker covering the screw hole.
    Eric Jensen - Antwoord
  2. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: stap 2, afbeelding 1 van 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: stap 2, afbeelding 2 van 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - Antwoord
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
  3. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 1 van 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 2 van 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: stap 3, afbeelding 3 van 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - Antwoord
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - Antwoord
  4. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: stap 4, afbeelding 1 van 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Support Spring: stap 4, afbeelding 2 van 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - Antwoord
  5. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: stap 5, afbeelding 1 van 2 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Attaching the New Spring: stap 5, afbeelding 2 van 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    h sh - Antwoord
  6. Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: stap 6, afbeelding 1 van 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: stap 6, afbeelding 2 van 3 Disassembling Logitech MBJ58 Mouse Scroll wheel from mount, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: stap 6, afbeelding 3 van 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    نحوه قرارگیری فلز سمت چپ چرخ اسکرول
    h sh - Antwoord
Conclusie
14 andere personen hebben deze handleiding voltooid.
238 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-14, Forte Winter 2013 Lid van Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Leden
23 handleidingen geschreven
7Gids Commentaar
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Antwoord
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Antwoord
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Antwoord
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Antwoord
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Antwoord
سلام، عالی بود، خیلی ممنون
hi, very good Education. very thanks
h sh - Antwoord
Guida utile e ben dettagliata che mi ha consentito di prolungare la vita del mio mouse e soprattutto capire come sistemare le molle !
Fulvio Serlenga - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 56
Altijd: 7,804
