Ga door naar hoofdinhoud
Dell XPS 15 9570 Battery Replacement
Clay Caldwell
Clay Caldwell en 12 andere bijdragers
Voor het laatst geüpdatet op February 4, 2025
10 - 20 minuten
Gemiddeld
Actiemomenten
Behoeft meer afbeeldingen
This guide will teach you how to replace the battery in your Dell XPS 15 9570.
This process will require a T5 Torx Screwdriver, an iFixit Opening Tool, Phillips #00 Screwdriver, and a replacement battery.
Batteries are what let your laptop hold power. A bad battery can lead to many problems. Here are some signs that your battery may need replacing:
  • The laptop will not stay on, or cannot run without being plugged-in. Constant shutting down is a major sign of battery issues.
  • The laptop will not charge properly.
  • If the battery appears to have become swollen or to have leaked, BE EXTRA CAREFUL.
If your battery is swollen check out this article below:
What to Do With a Swollen iPhone Battery
(It says iPhone, but the same process goes for any lithium-ion battery)
Before starting the repair, swollen battery or not, unplug the device and let the battery's charge reach 0%.
Remember that after you have successfully replaced the battery (which we are sure you will) please recycle it: How to Properly Recycle Your Old iPhone Battery
(Again it says iPhone, but the same process goes for any lithium-ion battery).
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
  1. Dell XPS 15 9570 Battery Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Battery Replacement: stap 2, afbeelding 1 van 3 Dell XPS 15 9570 Battery Replacement: stap 2, afbeelding 2 van 3 Dell XPS 15 9570 Battery Replacement: stap 2, afbeelding 3 van 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Battery Replacement: stap 3, afbeelding 1 van 2 Dell XPS 15 9570 Battery Replacement: stap 3, afbeelding 2 van 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Battery Replacement: stap 4, afbeelding 1 van 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Battery Replacement: stap 7, afbeelding 1 van 1
    • With your hands, pick up and remove the battery from the system.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Clay Caldwell
366 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 84
Afgelopen 30 dagen: 290
Altijd: 21,837
