Ga door naar hoofdinhoud
Dell Precision 5510 Keyboard Replacement
Colin Hunter
Colin Hunter en 3 andere bijdragers
Voor het laatst geüpdatet op March 8, 2023
25 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
Heeft betere plaatjes nodig
Mislukte opmaak
Betere introductie
If the keyboard is broken, missing, or malfunctioning you can replace the keyboard of the Dell Precision 5510 in 5 steps by following this guide.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
    According to the owner’s manual at https://www.dell.com/support/manuals/en-..., most of the screws for the base cover are Torx #5 with a couple of Phillips #0 under the badge flap.
    KCMax - Antwoord
  2. Dell Precision 5510 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: stap 3, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement, Fans: stap 3, afbeelding 2 van 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: stap 6, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement, Battery: stap 6, afbeelding 2 van 2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: stap 7, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: stap 8, afbeelding 1 van 2 Dell Precision 5510 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: stap 13, afbeelding 1 van 1
    • Pull keyboard out and replace.
Conclusie
Colin Hunter
121 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-1, Harley Spring 2022 Lid van IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Leden
4 handleidingen geschreven
1Gids Commentaar
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 57
Altijd: 2,390
