Ga door naar hoofdinhoud
Asus Q525U Speakers Replacement
John Munn
John Munn en een andere bijdrager
Voor het laatst geüpdatet op June 25, 2024
15 - 30 minuten
Eenvoudig
This guide will show you how to replace the speakers of ASUS Q525U (model BI7T9). The speakers are responsible for playing audio when external speakers are not present. Damaged speakers may cause distorted audio, static, or a lack of sound from your laptop.
Before beginning this repair, ensure that your audio drivers are up to date and update them if necessary. If this does not resolve the issue, try uninstalling and then reinstalling the drivers.
If you have determined that your speakers need to be replaced, be sure that your laptop is turned off and disconnected from the charger. Wear cut-resistant ESD gloves or ground yourself to avoid damaging the internal components.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Asus Q525U Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 3 Asus Q525U Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 3 Asus Q525U Speakers Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Begin by powering off the device and flipping the device over.
    • Carefully remove the two longer 9.5 mm screws on the corners with a Phillips #1 screwdriver.
    • Remove the eight 7.5 mm Phillips #1 screws on the back of the device.
  2. Asus Q525U Speakers Replacement: stap 2, afbeelding 1 van 3 Asus Q525U Speakers Replacement: stap 2, afbeelding 2 van 3 Asus Q525U Speakers Replacement: stap 2, afbeelding 3 van 3
    • Use an opening pick to separate the back cover from the device.
    • For easiest removal, begin by prying at one of the front corners and sliding the tool under the cover in a counter-clockwise motion (to the left) toward the laptop hinge.
  3. Asus Q525U Speakers Replacement: stap 3, afbeelding 1 van 3 Asus Q525U Speakers Replacement: stap 3, afbeelding 2 van 3 Asus Q525U Speakers Replacement: stap 3, afbeelding 3 van 3
    • Once the cover has been separated from the device, carefully lift the back cover off the device (begin by lifting from the front of the cover first).
    • The back cover should be easily removable, allowing full access to all of the internal components.
  4. Asus Q525U Speakers Replacement, Speakers: stap 4, afbeelding 1 van 2 Asus Q525U Speakers Replacement, Speakers: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the four 2.6 mm screws that hold the speakers in place.
  5. Asus Q525U Speakers Replacement: stap 5, afbeelding 1 van 2 Asus Q525U Speakers Replacement: stap 5, afbeelding 2 van 2
    • To disconnect the speaker cable, try pushing on alternating sides of the connector, like small sliding connectors.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated.
  6. Asus Q525U Speakers Replacement: stap 6, afbeelding 1 van 1
    • Lift the speakers away from the laptop along with the wire that connects the two speakers.
    • Make sure to detach the cable from the cable hooks along the edge of the laptop to avoid damaging the speakers or the speaker cable.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
John Munn
97 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 39
