Ga door naar hoofdinhoud
De smalle versie van de klassieke Xbox 360 met een harde schijf van 250GB en ingebouwde wifi. Reparatie vereist nauwkeurig wrikken en speciaal gereedschap.
Random freezing, restarting by itself
My xbox is freezing during gameplay, mainly at the first loading screen I come across, rarely at the dashboard and I have to unplug the power cord to shut it off. Sometimes the wifi card isn't detected as well. I can play Rainbow Six Vegas 2 for 10 minutes before it abruptly shuts on and off by itself.
I've tried cleaning and repasting it, didn't work and I can confirm temps are low. I've also reinstalled the latest update.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Did you also tried to replace the HDD?
I would do that first and install the software again.
Guide: Vervang de harde schijf van de Xbox 360 S
If it's still failing, try to replace the Wifi card and see if that solves anything.
Guide: Vervang de wifiprintplaat van de Xbox 360 S
I would try a new HDD first, you have some cheap ones at AliExpress and they do work fine.
Can you let us know how that goes?
Thanks!
Xbox 360 S Harde schijf Afbeelding
Handleiding
Moeilijkheid:
Zeer eenvoudig
1 - 5 minutes
Xbox 360 S Wifiprintplaat Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
5 minutes
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I've tried removing the HDD before and it didn't do anything, I can run it without the wifi card and I still get the same issues so isn't that.
door
If all the above didn’t worked, same for the HDD, then you most likely have motherboard issues. Most likely the internal memory on it.. I recommend to replace that. It won’t be easy as soldering is required. You can replace the motherboard but this will be expensive.
door
@dan0 I have the Trinity model so was able to remove the 4gb internal memory, which fixed freezing during loading screens. The games now just freeze later on. The dashboard also wont respond to my input at times, but I'm able to open the smaller menu with the xbox button which does work.
door
Okay! That’s a good thing!!
Please replace it for a new one and install it completely as new.
Does thet work?
Thanks!
door
Voeg je antwoord toe
MangosteenJuice zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 144
