Ga door naar hoofdinhoud
Model A1318 / 32 or 64 GB capacity
20 Vragen Bekijk alle
Vraag afgerond
Need Help Reataching Solder Pad For Battery- Need Help ASAP
Can someone help me? I accidentally deattached the middle solder pad for the battery trying to get rid of the old battery. Can someone give me a step by step guide on how to reattach it? I need to do this soon, I have information on there that is not backed up (don't ask, I have reason for being so).
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Thorhian, check this video for a decent tutorial.
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Should I use a small strip of copper? Saw your link in the enail, is copper tape a good idea?
door
It can work, just make sure you get a solid connection..:)
door
Thanks! Accepting answer.
door
Thank you for accepting my answer. Hope it will work out for you. Good Luck.
door
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 796
